Question about Buffalo Technology DriveStation HD-HC500U2 500 GB USB 2.0 Hard Drive
I cleared up my HD-CE500U2 earlier and deleted everything I didn't need and since then, I have restarted my computer and the light on the drive is on, but it isn't being recognised by my compu
I don't know if there's any pre-existing software on the device, but if there was, I probably deleted it by accident, and now there is no way to access the device and therefore no way to get to the files on it.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 71 Answers
There is only one way put another harddisk on your system and install the os which you have in old one after installing it and remember do not open any disk untill you didnot put any antivirus and update.
after that shut down your system and put that old hard disk with new one and before access that hard disk scan it properly .
Posted on Jan 04, 2013
SOURCE: Computer not accessing Buffalo HD
my Buffalo external hard disc can be detected by laptop, but my access is denied. When i click on the hard disc icon, it popped out a message box prompting me to reformat my hard disc. Is there any other way to retrieve my files before reformat or
is there any other way to recover my files after reformat?
Is there any other way to troubleshoot my hard disc other than reformatting it?
Please help me, I am desperate to recover all my files because they are too important/precious to lose it.
Posted on Jan 31, 2010
  • 10 Answers
SOURCE: My computer is failing to recognise it, therefore
Too Bad.
do this
take apart the hard drive enclosure. and try to connect the hard drive direct to the computer, if you can't do this, try with another adapter, if this fails your HD is Die. sorry
Posted on Feb 22, 2010
SOURCE: Can't access Buffalo HD-HB250U2-WR 250gb Ext. Hard
I think I have the answer, plug your cable in. If windows 7 shows the message unknown device don't remove the usb. instead turn the switch on the back of the external hard drive off for a few seconds then back on. Windows 7 should then for some unknown reason find the correct drivers and your buffalo hard drive will now work. This worked on mine.
Cliff
hotdesignerwear.com
Posted on Jul 26, 2010
technical114
  • 1851 Answers
SOURCE: i just dropped my buffallo HD-CE500U2-EU and now
Sorry to said that your description comes to a dead hard disk. Especially if the hard disk was at power on state the moment that dropped down there is no doubt that the clicking noise that you hear is a destroyed hard disk.
Sorry for the bad news.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Jan 29, 2011
bronk50
  • 27725 Answers
SOURCE: The Hardrive is now beeping and the blue light only flashes once. And my laptop isn't recognising it. Everything I have is stored on it?
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Posted on Apr 25, 2012
Black screen then blue screen with cursor
Unfortunately after trying to restore to earlier point and didn't succeed ,u have to reinstall a fresh copy of windows. Before you do that ,check whether you have added any new hardware or USB drive/mouse/webcam or keyboard and restart.
May 15, 2012 | Acer Computers & Internet
Lenovo y510 suddenly turns off and the funny thing is that it happens when it's actually COLD weather , first you can hear the fan working really hard and then it suddenly turns off i tried cleaning it...
Go to 'Start' and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'System configuration utility' window click on 'startup' tab then uncheck all the applications except your current antivirus and press apply then 'ok' and then 'exit without restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
go to 'Advanced' click on 'change' and increase your virtual memory to 2048 in both spaces.
Now restart windows.
Just do the following steps and your issue will be resolved.
1) Delete all unwanted data from Drive C.
2) Delete all data that you have copied from Drive C to External HDD
3) Open My computer and go to Tools---> Folder Options---->Click on View Tab----> Check 'Show hidden files and folders' and select OK.
4) Go to C:\Documents and Settings\Administrator\Local Settings\Temp and Delete everything that you see inside Temp Folder
5) Go to C:\WINDOWS\ here you will find folders like $hf_mig$, here you will have to Delete all the folders starting and ending with $ sign.
6) Empty Recycle bin and restart the PC and your issue will be resolved.
Oct 28, 2011 | Lenovo IdeaPad Y510 - Intel Core 2 Duo...
Hi I want to restore my computer to original factory settings. I can only find the F2 option into the BIOS menu and there is recovery centre. Plus it didn't come with a recovery disk. Do you have any...
Restart your Sony Vaio if it is already on. If it's off, turn it on
  • Press the F12 key on your Sony Vaio keyboard. This will enter the computer into the built-in restore mode. Note that depending on the model of Sony Vaio, you may have to press either the F11 key or the ESC key to enter this restore mode. This must be done before your operating system begins to load. If you see the Windows logo appear on screen, you'll have to restart and try again.
  • Choose the option on screen that is most appropriate to your needs. You will be presented with three options: you can either create a set of recovery discs, attempt to repair your operating system's installation, or restore your operating system. Repairing your operating system will attempt to fix your computer without deleting any of your personal files. Restoring your operating system will delete everything on your hard drive and return your computer to its original factory settings.
  • Wait for the restore process to complete. Depending on the type of restore you've tried, you may have to wait as little as a few minutes and as much as an hour or more. When the process is finished, the computer will automatically restart itselff
  • Sep 02, 2011 | Sony VAIO PCV-RX403N PC Desktop
    System start automatic restart
    Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
    Let windows boot in Safe Mode and log in to windows.
    Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
    Here you will have to check "Restore computer to an earlier time' and click Next
    Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
    The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
    Now, Click on Next and System Restore will start and windows will take a reboot.
    After reboot Go to 'Start' and then Run
    Jun 10, 2011 | Microsoft Windows XP Professional
    It goes to sleep and i cannot wake it without a hard shutdown/ start . it is a Aspire 5336-2634
    If you feel that my answers have helped you getting solution to your problems then please give a vote.
    Thanks.
    May 31, 2011 | Computers & Internet
    I have an acer aspire one netbook . just this day it started to not work when i turned it on up to where it asks me if i want to start windows normally after i press enter it hits a blue screen then...
    When you turn your laptop on start taping f8 at the same time.The screen will come to a screen that gives you some different options.Use the the up arrow button And highlight safe mode.Hit the enter key.The next screen will give you the option to go into safe mode by choosing yes or doing a system restore if you chose no.Once your in safe mode You need to go to start >control panel >system> advanced>start up and recovery>Settings >and clear automatically restart.Come out of safe mode with the start button.After your PC shuts down reboot it and preform a system restore.Start> All programs > Accessories > System Tools > System Restore. It's pretty straight forward from there,you can reverse any thing you do here.If you want I can give you some free utilities that will help you keep your PC running smooth .Thank You for choosing FixYa.com
    I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
    May 23, 2011 | Computers & Internet
    Formatting a buffalo hd-ce500u2
    hi there, if you would like to format it, all you have to do is plug it into the computer, go to my computer, and right click on the drive. Then, click format. After that, click on the format button and let it be for about a hour or two. After it is done, the drive will have been formated.
    Jan 30, 2010 | Buffalo Technology DriveStation HD-HC500U2...
    Hard Drive doesn't show up
    Try doing flea power & the power cycle.
    1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
    And press & hold the power button for 2 min, it will release the flea power from the mother board.
    Restart the system & check.
    2. Disconnect everything.wait for 5-10 minutes and then connect every thing.
    Restart the system.
    If it does not resolve the issue then you can try this :
    Just remove the registry key it happen when this key is corrupted.
    HLKM\System\CurrentControlSet\Enum\USBSTOR
    And delete all references to the external hard drive.
    And also HLKM\System\CurrentControlSet\Enum\USB
    and found the keys associated with the USB to IDE value.
    After restarting the system, the drive shold be detected & configured automatically by the computer.
    Good Luck.
    Live, Love, Laugh.
    Mar 30, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
    Buffalo Technology DriveStation HD-HC500U2 500 GB USB 2.0 Hard Drive Logo
    76 people viewed this question
    Top Buffalo Technology Computers & Internet Experts
    Prashant M
    Prashant M
    hellics
    Level 1 Expert
    Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
