Question about NKOK Halo Remote Controlled Hornet Banshee Helicopter
Nkok banshee helicopter
Top rotor doesn't turn
How long should i charge halo banshee'
It should be given in instructions or you can charge it for 3 to 4 hrs.
Mar 01, 2013 | NKOK Halo Hornet RC Helicopter
Syma s107 hit a dangling string that got tied up instantly and seized the rotors. now lights up but blades don't spin when throttled. What can I do besides replace the helicopter?
I was flying my syma s800g and hit the ceiling fan chain. When I attempted to fly it would spin and fall over. The problem was I broke the two small plastic pins on the top rotor holder. Ordered a new top rotor and flies fine. Then on my s107 I flew into a door and the top rotor had zero spin although the motors worked. In that case the screw that sets the top rotor onto the middle shaft loosened resulting in no lift and also tilted and fell over. This was fixed by securing the set screw properly. So in both instances it was similar effects due to the top rotors not spinning in sync with lower blades.
Jun 03, 2012 | SYMA Toys industrial Syma S032 Ready to...
On my rc volitaion remote on the top the gauge what dose it mean when it flashs
It's in a safety start up mode so there is no accidental start up of the helicopter
while holding model in your hands to turn it on or plug battery in. When ready to fly move throttle
gimble to full up then back down to stop. Light should then stop blinking and the
next time you move throttle gimble up the helicopter rotors should begin to turn.
Oct 06, 2011 | xheli 9053 Outdoor Volitation Metal...
SYMA S107 Helicopter. Advertised as 3 channel. Remote has channel marking of A B C, but the switch is only 2 position. How do you achieve 3 channels with only 2 position switch?
This helicopter have 2 channels I see.
Maybe A-B is first position and B-C is secound position channel. Helicopter have not switch ABC, simply turn off and turn on for change channel.
Jan 14, 2011 | SYMA Toys industrial New Syma S107 Mini...
Brand new unit forward and reverse seems very slow moves a little then just hovers.
Make sure you're charging fully, until the light on the charger doesn't get ANY brighter when you unplug the helicopter. Also, battery must be allowed to cool 10 minutes after flying AND another 10 minutes after charging.
Most crucial is that you must never fully discharge battery. Fully draining a Li/Po even once (especially when it's new) can cripple or ruin your battery. As soon as you are unable to maintain altitude, land copter and power it off. Also, there is a button on the remote, labelled "tail motor speed switch" located near the trim control. With it in the "off" or up position the tail motor is much slower allowing for more precise control. When button is pushed to the down or "on" position, tail motor moves faster giving more tilt, and thereby much more forward/reverse 'thrust'. Verify that tail rotor is moving when right joystick is actuated (and that it reverses when right stick is pulled in opposite direction) and that it isn't loose on it's shaft... this can be tested by verifying tail rotor spin in one direction then reversing joystick... tail rotor should instantly start spinning in the other direction with NO hesitation, if it slows and then starts spinning in other direction or anything like that then it's loose. Turn helicopter upside down then VERY CAREFULLY apply a small drop of super glue where the shaft meets the tail rotor, be very cautious to not get any glue near where the shaft comes out of the motor, and do not turn right side up until glue is fully dry.
Hope this helps,
r
Jan 07, 2011 | SYMA Toys industrial Syma S032 Ready to...
One rotor spins faster than other, so chopter flies only forward
We are a family that bought one of your helicopters. We immediately had a problem, the top rotor stopped spinning after a crash. We found out that when the helicopter crashed I wasn't paying attention(I am 10 years old)and I was still pushing the throttle while it was on the top rotor. Big mistake,when I tried again it Didn't lift off the ground. We then put crazy glue in between the top rotor and the shaft and tried it again. It worked! Both rotors spun! Good luck!
-Bryce
Dec 25, 2010 | SYMA Toys industrial Syma S026 Chinook Rc...
I bought 3 of the Syma S107 RC Heli's because it said the remote had 3 different channels. I see the Channel a,b,c on the transmitter but I don't see how I assign different channels to the 3 heli's and...
For one thing, there are only two channels. Although the transmitter shows a,b,c the switch has only two positions. The way to assign a channel to a heli is to turn it on and then simply operate the transmitter. The heli will lock itself onto the first frequency it receives, and start working. Before turning on the second heli, make the first transmitter is OFF, and set the second transmitter to the other channel. Turn on the second heli and simply operate the transmitter. The heli will lock itself onto the second transmitter's frequency, and start working. Then you can turn the first transmitter back on.
Oct 31, 2010 | SYMA Toys industrial New Syma S107 Mini...
The bottom blade has stopped spinning. Help
ok this is what you got to do you have to take apart the helicopter and in it try to turn the bottom blade you will hear a clicking sound from there you should see whats wrong i had the same problem hope this helps
Aug 30, 2010 | NKOK Halo Hornet RC Helicopter
NKOK Halo Remote Controlled Hornet Banshee Helicopter Logo
20 people viewed this question
Top NKOK Toys Experts
Andrew Taylor
Andrew Taylor
Are you a NKOK Toy Expert? Answer questions, earn points and help others
