SOURCE: RATTLING NOISE AT OIL PAN AREA ON 1998 DODGE RAM 1500 5.9 LITER
rod bearing , engine needs rebuilt
SOURCE: engine is making loud noise from rocker cover area. oil pressure
tapets or camshaft has gone, check them out before you start it again
SOURCE: Engine rattle noise
Uh oh.
Is it leaking oil?
I recommend not even trying to start it until you at least find out if it has enough oil in it...it may be too late already.
SOURCE: number one injector came loose
REPLACE THE FUEL INJECTOR CANT REBUILT IT.IF YOU REMOVE FUEL INJECTORS FUEL RAIL YOU HAVE TO REPLACE GROMMETS AND O RINGS ON ALL THE FUEL INJECTORS IF NOT YOU WILL HAVE A INTAKE LEAK AT THE OLD FUEL INJECTORS SEALS.REPLACE THE FUEL INJECTOR YOU REBUILT THEY HAVE TO BE REPLACED.
