Question about Angelcare Baby Care
How to change the channel on an angelcare ac420
2 Suggested Answers
SOURCE: Angelcare monitor Model #AC420-P no
Had exactly the same problem but this worked. Never even realised there was a button on the top of the unit!!! It looks like a little LED at the base of the hoop. Happy monitoring.
CONNECTING THE PARENTS UNIT TO THE NURSERY UNIT:
If you lose the connection between the 2 units,turn them both off. Turn ON the parents unit and
press and hold the MENU button ,the "out of range"indicator will flash and you will hear a
beep.Turn ON the nursery unit and press and hold the top button of the nursery unit to reconnect.
The Tic light flashes.This normally happens within a few seconds and you will hear a bleep
to confirm it. If successful, the parents unit display will first show the channel of transmission (C1
to C8), which will be replaced by the room temperature and icons for all activated functions.
Note : The connecting process should be done within 30 seconds. If longer, the operation will be
ignored and you will have to start over.
• PAGING: If you want to locate the parents unit, press the top button of the nursery unit.
Posted on Aug 13, 2010
Can you pair a angelcare ac401 parent unit with a different nursery unit?
No the angelcare parent unit is only suitable for use with the angelcare ac401 it is designed for use with
Nov 05, 2014 | Angelcare Ac401 Single Baby Movement Sound...
Hello, my angelcare monitor is not charging, what can I do?
My Angelcare baby monitor stopped charging as well. I found that one of the terminals in the charging dock had broken the wire that connects it to the power cord plug. I re-soldered it back on and it works again!
Dec 24, 2010 | Angelcare Baby Sound Monitor White
Angelcare monitor Model #AC420-P no transmittion between base and monitor. no battery problems in either
Aug 10, 2010 | Toys
AngelCare Baby monitor and movement sensor AC401 mike problems.
Press Menu, then press Menu two more times until the icon on the far top left of the little display shows up, then you'll see the on/off option if you use the arrow keys. Use the arrow to select OFF and then press Select. Then press Exit.
Apr 08, 2010 | Angelcare Deluxe Movement Sensor & Sound...
The base unit is turning on and operating, but the parent's unit all of a sudden just won't connect. I know the base unit is working because it is still detecting movement and the alarm goes off when...
Try the manuals: http://www.angelcare-monitor.com/Canada/en/help#tabs-2
The picture showing looks like the AC201 which has a hard switch for the channel selection, but you describe a menu screen which sounds like the AC401 or similar. If it is the AC201 - ensure both units are on the same channel. If it is the AC401 or other unit where there is an LCD, then try the following:
CONNECTING THE PARENTS UNIT TO THE NURSERY UNIT: If you lose the connection between the 2 units,turn them both off. Turn ON the parents unit and press and hold the MENU button ,the "out of range"indicator will flash and you will hear a beep.Turn ON the nursery unit and press and hold the top button of the nursery unit to reconnect. The Tic light flashes.This normally happens within a few seconds and you will hear a bleep to confirm it. If successful, the parents unit display will first show the channel of transmission (C1 to C8), which will be replaced by the room temperature and icons for all activated functions.
Sep 19, 2009 | Angelcare 2009 Movement Sensor Baby...
Baby Care Logo
135 people viewed this question
Top Angelcare Baby Care Experts
masud
masud
Tom Chichester
Are you an Angelcare Baby Care Expert? Answer questions, earn points and help others
