Question about Garden
Got good spark run for sec then dies
Got part off other sled that runs?
    New Friend:
  • 30 Answers
It all comes down to spark and gas. If you have a good spark, then there is probubly a gas problem.
Posted on Jan 02, 2013
86 4.3 4BC 1500 Chevy Die rolling up to light Started up and ch of fuel and it died 3 times now no start smell fuel and quit yellow spark Have replaced cap rotor plugs wires EGR coil ECM Rebuilt carb
It sounds more like a fuel problem to me then a bad coil or spark ign the spark should be blue but its hard to see in daylight
You say you rebuilt the carb are you sure your main mixture jets are at least 2 to 3 turns out off the stops .
Try pouring fuel down the barrel fill the float bowl if it runs then dies its fuel don't let it catch unfire you should have 45 sec. of run time then adjust the the mixture screws 2 turns is base but when its is running good turn them in 1 at a time and give it 30 sec. to adjust until it starts to stumble then back it out a 1/4 two 1/2 turn then repeat on bank 2
Nov 23, 2016 | Chevrolet Cars & Trucks
Fuel problem. first time out ran for an hr now it wont start. have spark will run if i put gas down cylinders. fuel line and rail not plugged.
Fuel pump dead or dying. Injection systems need 110 psi, and a pump only doing 30psi will still not run .
Jan 02, 2016 | Cars & Trucks
Can plug wires be crossed?
I have the Same Sled and It runs pretty good. Love the fact that it can start with the push of a Button but to answer your question, the Wires are separated so that they should automatically go to the Right Cylinder and if I remember correctly, they SPARK identical so if they do fit (Mine Won't) it should start anyways. a DEAD BATTERY will not allow the sled to start, it is SDI (Semi-Direct Injection) and it requires power to Work....
Feb 24, 2015 | Ski-Doo 2004 Legend GT Sport 600 H.O. SDI
I have a 1993 arctic cat 700 efi that the battery keeps going dead in how do I check if its charging?
When a battery dies while the engine is running it is not being charged. When the charger is working the engine will run without a battery
Dec 13, 2014 | ATVs
Engine start then stalls
map censer i had that problem on oldsmob it is located on the thoutlebody
Jul 04, 2013 | 2001 Toyota Echo
I have a 2005 fusion 900 and ran great till the wire coming from left side of crank case wore threw and sled quit so I fixed the wires and sled would run good for 20 30 min shut it off and it would have no...
If still wired and starts then dies take a small hammer and tap on back of starter as a friend cranks it over if it fires up then the seilnoid is bad if all in one if separate try tapping on it you can also run battery cable to starter positive neg to batt positive to big nut on starter if starts then seilnoid basic all in one replace whole thing also check all grounds and terminals are tight also don't twist and tape use wire splices twisting is still a break in the wire hope this helps narrow it down for u
Feb 21, 2013 | Cars & Trucks
1999 XC SP 500 ,1,500 miles only----starts and runs - then at different occurences the sled will just die. SIt for awhile (minute of two) starts again and dies and then wait a few minutes, starts and...
WHEN THIS HAPPENS, CHECK FOR SPARK. IF IT HAS NO SPARK THAN IT IS AN ELECTRICAL FAULT. IF IT HAS SPARK IT COULD BE FUEL DELIVERY PROBLEM OR A INTERNAL ENGINE PROBLE.
Dec 28, 2010 | Polaris New Genuine Polaris Snowmobile...
My sled bogs down going up hill or hitting the break
i have 1996 ultra sp runs great till i hit 80 mph then it starts to bog .
Feb 21, 2010 | Polaris New Genuine Polaris Snowmobile...
Will run for 5 sec and then it will not run
Could be a number of things.
Fuel pump, pump relay, plugged fuel filter, bad spark plugs, plug wires, coilpack/or/distributor
Most reasons are car won't start or stay running is a bad sensor.
Jan 17, 2009 | 1995 Ford Windstar
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
