Question about Bosch AquaStar Propane Tankless Water Heater #125HX-LP
Which Bosch Tankless water heater replaces the AQ-125-X LP
Old AQ-125-X needs to be replaced, this model not made anymore, what model replaces it?
  • Grant McQueen Jan 04, 2013
    Which Bosch current model, and/or any other brand of tankless water heater is equal too the model stated above that is no longer manufactured?
3 Suggested Answers
gary1121
  • 332 Answers
SOURCE: Looking for Outdoor Tankless propane water heaters
it will tell you right on the box if it for indoors or out doors either way they have to have a cover over them,,
Posted on Jun 09, 2009
SOURCE: aq 125 blp Bosch tankless water heater, pilot
Natural Gas: Pilot burner or orfice may need to be cleaned. Pg 11 manual.
http://www.boschhotwater.com/Portals/7/TechManuals/125BL_English.pdf
Most tank and tankless gas water heaters today suggest annual cleaning and maintenance of burner.
Open following links for Bosch troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/125BLTechSupport/Troubleshoot/tabid/474/Default.aspx
Posted on Jun 14, 2011
Where can I download a Boschw14 b31 gas Heater Manual
Is this a water heater? Bosch site might have manual. And service bulletins, but I have not heard of that model.
http://www.bosch-climate.us/Bosch-Hot-Water/
Call local service technician who is qualified to work on tankless computer that heats water.
You can fix any brand tankless computer, any problem, same day, yourself by replacing 1 part: the whole thing:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
l
Aug 05, 2013 | Bosch ProTankless GWH 715 ES LP Tankless...
Bosch aq 125 no water preasure
Clean water filter yearly or monthly. Page 16 example manual.
http://waterheatertimer.org/pdf/Bosch-125BO-NG-LP-outdoor.pdf
Shut off the installer supplied cold water supply valve.
Disconnect water pipe going to the back of the water
valve. Remove filter from back of water valve. Clean the
filter and inspect for damage. Replace if the filter is at all
damaged. Inspect the top of the water valve for signs of
a water leak or corrosion. If present, rebuild the water
valve.
Bosch service bulletins:
http://www.bosch-climate.us/bosch-hot-water/aquastar-service-bulletins/38b-125-series-bulletins.html
Descale heat exchanger yearly.
http://waterheatertimer.org/pdf/Bosch_Descaling-heat-exchanger.pdf
Sep 29, 2012 | Bosch Water Heaters AquaStar 125 series...
I have a Bosch AquaStar AQ-125-BNG tankless water heater, and for some reason when it is heating the water, it seems to get exremely hot and the heat is radiated back into the cold water supply line and...
Tankless should never be installed with plastic pipe, PVC or CPVC etc.
Before calling service technician, open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 02, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
Our Bosch model AQ 125 Bong water heater pilot light will not stay on. We've tried numerous times. The instruction suggest a service technician. There are none available in our area. What the best...
It sounds to me like your thermocouple is bad . See if you can trace it from the gas valve to pilot light. Remove thermocouple and try to get a exact replacement part. If the length varies don't worry about that. Install new thermocouple and see if that doesn't solve your problem. Thanks
Dec 01, 2010 | Bosch & Tankless Water Heater
I have a Bosch AquaStar AQ-125-BNG tankless water heater. It has worked very well until recently. The problem: The hot water at the tap is turned off, the flame on the main burner keeps burning and...
there is a small dia copper pipe which has a thermal coupling on it the end of it sits in the flame of the pilot light,
if it fails which it does after about 25-15 months,it shuts down the gas burner
Jul 05, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Jun 09, 2009 | Bosch AquaStar Propane Tankless Water...
Bosch AquaStar Propane Tankless Water Heater #125HX-LP Logo
50 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
