Question about Thermador 19.6 Cu. Ft. Stainless Steel French Door Refrigerator - T36BT71FSE
Door handle loose on refrigerator stainless steel french door
3 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: Stainless Steel Cover for Grill
Yes the parts are available .As for the removing the material left on the cover,I would use a very light 400 sandpaper first to see if that makes progress.Without seeing the cover it's not advised to give any advice, only because without the right pressure and tool used it will vary on how this will be removed.
Posted on Jun 24, 2008
  • 41 Answers
SOURCE: stainless steel door panel came loose on my double Thermador oven
GOOGLE HEAVY DUTY GOOP
Posted on Nov 06, 2016
The freezeer door handle on a Gx5fhtxvado came loose . How do i remove it and tighten it and put it back on?
grab the handle and lift. it will slide up and then you can pull it off od mounting screws. then tighten the screws on the door and reinstall. don't be afraid to put a bit of muscle behind the lifting aspect.
Apr 09, 2012 | Whirlpool GX5FHDXVY Stainless Steel (248...
The handle for the freezer door came off on the right side. It is now dangling, and there is a loose black plastic part that fits in the handle, and a loose screw. Can you tell me how to re-attach it?
Click this link http://c.searspartsdirect.com/lis_png/PLDM/M0606060-00001.png this is the diagram for the door handles on your unit. The loose black plastic part is that part number 3 in the diagram that you are trying to describe part 3 would go into the door itself although in order to turn the screw to go into part 3 and the door at the same time you may have to call maytag there is a special tool they use to attach the handle. If you have any further questions message me back Thanks Rick
Aug 23, 2011 | Maytag MFC2061KES Stainless Steel French...
How do you tighten the door handle?
Door handle is mounted on two metal pegs. There is a set screw (metric) in the side of the handle at top and bottom.
Dec 26, 2010 | LG LFX25960ST Stainless Steel French Door...
GE GFSL6KEXLS Stainless Steel (2585 cu ft) Bottom Freezer French Door Refrigerator Problem: Freezer handle is all stainless steel is loose. How can I tighten it? I looks like I would have to go through...
look for a small hole on one side of the handle. There should be a set screw there you can tighten. (the handle attaches to a ball shaped peg under the handle, and does not attach from the inside of the door)
Nov 28, 2010 | GE GFSL6KEXLS Stainless Steel (2585 cu ft)...
Whirlpool stainless french door refrig...need to take handle off bottom freezer door so I can move it out of house. Is this possible without taking off the whole door?
it is much better to remove the complete door instead of handle . there are 4 screws inside that will release the complete door . if your want to do the handle use a credit card and insert it between the handle and door to release . but if stainless it some times leaves marks on door . i always remove the doors as one door is ever and i mean very costly.. mm hope this helps mm feed back pls ..
Nov 08, 2010 | Whirlpool GX5FHTXTS Stainless Steel Bottom...
GE Profile SS refrigerator Handle is off on one end.
the screw must have fallen out they are small allen screws that hold it on
Jun 11, 2010 | General Electric PFSS5NJXSS Stainless...
GE Energy Star French Door Bottom Freezer handle popped off
You cant find a hole to insert screw from outside. It is true, and you can't fix it yourself to what it looked like earlier. The company first screws in through the handle and then covers the hole made by it with the material of the handle. If you have to fix it yourself, you can only pierce those screws through the handle leaving the mark behind. If you don't want that, contact your company or dealer.
Apr 22, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
Freezer door handle loose
Can you give me the model number? Ther are alot of variation of handles.
Nov 14, 2008 | GE Profile PSW26P Stainless Steel Side by...
Handle to freezer on french door fridge
if the butter fly clip is brroken . you need to change the door. other than that you can replace the handle only. with the butter fly clip. parts cast only 100.00
Feb 07, 2008 | Maytag MFD2560HES Bottom Freezer French...
Thermador 19.6 Cu. Ft. Stainless Steel French Door Refrigerator - T36BT71FSE Logo
21 people viewed this question
Top Thermador Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Thermador Refrigerator Expert? Answer questions, earn points and help others
