Question about Hampton Bay 54 In. Flemish Pewter Ceiling Fan with Heater
Hampton Bay Covington 54" Ceiling Fan Light Does Not Come On
Fan still works but the light will not come on, i tried replacing the remote box inside and the problem still persists. I have changed bulbs as well and the light will still not come on. Any suggestions? Do I need to replace the part that the bulb actually connects and fits into?
  • 323 Answers
Try taking the lighting kit completely off it make sure the blue wire and white wire are both firmly connected.
Does the remote work on the fan part ok? Do you have the black, white, and green wire on the house side connected to the side of the receiver with the same wires?
You know the black and blue are hot for the fan and lights (blue for lights). If the wiring connections are ok it had to be either in the remote or receiver. Are the dip switches set for the same on each?
Posted on Jun 02, 2009
Hunter fan 2 yrs old-light won't work.fan discontinued was told need switch G234686000 but no longer stock it! fan not used long enough to replace bulb & now have to trash it. what to do?
Been There, there is a small remote box inside the case,, if you buy Harbor Breeze 3 speed fan switch with dimer light they come together,,, but Heck,,, it's $60.00 US !!!
Nov 07, 2017 | Hunter (25417) Ceiling Fan
Minks aire mojo ceiling fan light will not come on
Try changing the bulb. Make sure the bulb is touching the connector in the bulb socket.
Aug 15, 2014 | Minka Aire Ceiling Fan
My Hunter fan with light kit has a problem, again. The remote control works for the fan but not for the lights. One bulb burned out. Then the remote stopped working. Replacing the burnt out bulb did not...
this sounds like the remote in the fan went out the diod will burn out and cause this issue if you go in the fan by the breaker box and see the board you will see a burnt out diod you just need to replace the remote at lowes there about 45dollars good luck
Aug 04, 2011 | Hunter Ceiling Fan Remote Receiver...
I have a Hunter fan with remote and the light flickers without coming on completely - and you can hear a clicking noise coming from the fan. The fan works and the bulbs and batteries were changed
The pins inside the remote could have been switched or the wiring inside the fan could have come loose. Check the wiring at the fan first. The vibrations of the fan could have worked the light conrol wire loose.
Oct 10, 2010 | Hunter 27185 Remote Control
A light bulb in my ceiling fan burned out the other night when I turned it on with the remote. I changed the bulb, but since then the remote will not turn the light on or off. The wall switch will, and...
Sometimes all you need to do is switch the wall switch on and, off a few times while you press the lamp button (off press the button then: on press the button) no go? then: check or, replace the hand remote nine volt battery. still no go? then:
Check the wattage of the replacement bulb; some high wattage bulbs will rob power from the remote unit. didn't work? OK,
next turn off the power to the lamp and, open the lamp cover: you will see a large plastic rectangular box (the reciever) open the cover on the box and, you will see a block of tiny switches then: open the hand remote battery case it too will have a block of tiny switches these must match i.e. 1,3,5,= on 2, 4, = off both the remote and, reciever box. Barring that ...you'll need a new reciever for your fan.
Jun 01, 2010 | Hunter 27187 Remote Control
Fan works, light works, but won't turn off
Sounds like that part of the multi-switch in the remote is either dirty or shot. Google for new remote for you model of fan
Oct 01, 2017 | Hunter 22460 52'' The Astoria Brushed...
Remote control problems
Hello :
The problem here is not with bulbs neither the remote but it must with the PCB [ printed circuit board ] inside the fan .. for more information please check this link .
I hope this will help .
PLEASE RATE !
May 14, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Fan works, light doesn't on Hunter ceiling fan
I would begin by testing each bulb in a different socket somewhere in the house.
Apr 06, 2009 | Hunter 27187 Remote Control
40w candleabra bulb blew now can't turn lights off with remote
There is a receiver in the fan that when the light blew might have damaged that part of the receiver. I think you can buy them,but you will have to get into the base of the fan(ceiling cover).
Jan 02, 2009 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Hampton Bay 54 In. Flemish Pewter Ceiling Fan with Heater Logo
521 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
