Question about Durabrand DUR7 Portable DVD Player
Battery i dont know how to charge my battery
  • 1 more comment
  • albee52 Feb 11, 2008
    the battery won't charge even with the ac adapter
  • Anonymous Mar 01, 2008
    my battery holds a charge for about 5 minutes even if i have it plugged in for hours.
  • moseleyd1 Nov 23, 2008
    No kidding - it SHOULD charge when plugged in. It doesn't - thats the problem.
    Problem Solver:
  • 14 Answers
Battery should charge with the ac adaptor plugged in seemanufacture site for more info http://www.alcosupport.com/products.aspx?view=88&p=49&sc=5 product manuel pdf (see page 1 for visual instructions)http://www.alcosupport.com/productdocuments/DUR7.pdf God Bless
Posted on Jun 26, 2007
SOURCE:
My sony handycam DCR-TRV340E is not charging at all, dont know if its to do with the battery or the AC power adaptor
First, check that the camera switch is in the off (charging) position.
If this is OK, Check the battery output connections for voltage: use a multimeter.
To check the charger, put a load resistor across the output terminals (about 1000 ti 2000 ohms) and again, using a multimeter, check there is a charging voltage. Alternatively, if the camera operates OK with the charger attached and switched on the charger is OK, AND, the problem is then in the charging circuit from camera to battery. If the battery checks OK as in the beginning, then you will need a Sony repair man who needs to know all the results from your testing above.
May 27, 2014 | Sony Handycam DCR-TRV340E Digital...
Dont know how to charge the GE X500 Digital Camera
Remove the battert from the camera and charge the battery with the mains battery charger that came with the camers.
Apr 05, 2012 | GE X500 Digital Camera
I dont know what happend but my 4th gen ipod was working perfectly fine then i got an ipad so i was addicted and i put my ipod aside for about a week. Of course it ran out of battery so i charged it, you...
Attempt a hard reboot of the device by holding the home button and the power button at the same time. Contact AppleCare if the problem persists. Also, don't use the iPad's charger on the iPod or an iPhone. It doesn't play well with it.
Jun 02, 2011 | Apple Audio Players & Recorders
Battery does not work more than 4hrs even i do not use multimedia files too.....
If a recharable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Mar 09, 2011 | Cell Phones
I have not used it for a long time. Now it will not switch on
HI, have you tried charging it for at least 2 hours if the battery has gone totally flat then it wont switch on until has been charged for at least a couple of hours.
if it is charged and you have charged it up and its shows you its charging then try removing the battery for few minutes then put it back in and give it a try, if after doing this it still dont work then the problem could be the on/off button or it could have got damp or knocked about.
let me know what you have done so far and let me know if it shows you it is charging, if it dont then the chances are the battery has got bad cells and this is causing it not to hold a charge and if this is the case then your going to need to get a new battery.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 15, 2010 | Palm Vx Handheld
I dont know how to charge my mp3?
IS IT A USB TYPE OR SIMPLE ONE IF ITS NOT USB TYPE THEN U MUST HAVE A PINHOLE FOR CHARGING WITH CHARGER
Dec 16, 2008 | Coby MP-C858 MP3 Player
My Sidekick 3 wont turn on.
the phone needs a new main-board or reflash the board to get it up and running again.
Jun 20, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Charging battery
Take it back to the store get your money back and then go out and get a real camera. The m853 is a piece of junk. I had the same / similar problems and Kodak is clueless about the problem.
Nov 20, 2007 | Kodak EasyShare M853 Digital Camera
My phone dosent turn on or nothinq
When the battery is totally depleted, you will need to use a charger that came with the phone. Sometimes it will take a few mintues (give it 10) for the battery/charging circuit to come on.
Sometimes you can charge from other sources than the charger that came with the phone. You generally will need enough charge on the battery to start the phone.
Example: If I have enough battery to where the boots and turns off, I can generally get it to charge from USB or my car adapter. You will need to get the phone to turn on and boot most of the way up before it will take a low current charge. If my phone is so dead it will not even turn on, I must plug it into the AC adapter. Sometimes even then the light does not turn on right away.
The problem is probably due to the number of amps provided by the charger. When the battery is totally dead, the charging circuit is drawing so many amps that it will prevent low amp chargers from being able to do the job. That's why these phones have such heavy duty AC adapters.
Apr 28, 2006 | T-Mobile Sidekick II
Durabrand DUR7 Portable DVD Player Logo
149 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
