The volume is at 20 when you turn the unit on.
If you have the volume at 8 and you turn the unit off, the volume will be at 20 when you turn it back on.
  • 71 Answers
This is the default volume level set by the factory for the player. I too experience this on many stereos and cd players. It cannot be changed.      Very sorry.
Posted on Jan 24, 2009
When I set the effects to the channel for the mic, It kills mic volume
Check your mic input settings, click the "VOLUME" control (and/or sounds fron control panel)... also check and PLAY with "GAIN +20" on the settings..
Write me back on your results..and tell me your OS... question was vague..hope it helped.
Oct 18, 2012 | Tascam DP-02 8-Track Digital Recorder
How to set up Panasonic Answering Machine KX-TG4391
Recording your greeting message You can record your own greeting message (2 minutes max.). 1 {GREETING REC} 2 Within 10 seconds, press {GREETING REC} again. 3 After the base unit beeps, speak clearly about 20 cm away from the MIC. 4 Press {?} (STOP) to stop recording.
Playing back the greeting message Press {GREETING CHECK}.
You can also operate the answering system by pressing dial keys on the handset
Key Operation {^} or {V} Adjust the receiver/speaker volume {1} or {<} Repeat message (during playback)*1 {2} or {>} Skip message (during playback) {4} Play new messages {5} Play all messages {8} Turn answering system on {9} Stop playback*2
Oct 17, 2010 | Panasonic DECT 6.0 Expandable Cordless...
I plugged in the CD Player Out into the Phono In jack on the back of my Receiver Yamaha RX V382 and turned up the volume to 1/3 at what point I heard a bang out from one of my loudspeakers. From that...
The first thing I can say is that the CD player should not have been connected to the phono jacks as this is for a record player, therefore you amplified the CD player output greater than what it should have been!
Next a damaged loudspeaker could cause problems to the amp. A simple test is to connect each speaker (disconected from the amp) for a second to 1.5 volt battery. You should hear a pop sound from each of the speakers and make certian that each unit inside the speaker pops too. If the speakers are 8 ohm set that switch at 8. Never connect 6 ohm speakers with it at 8! Check the cables are good and are not shorting out.
If I was you I would have a look inside the unit and have a look at the semi-conductors on the heat sink. You might see damage! If they are transistors you can put an ohm meter on the transistor terminals (B,C,E) (amp power off). If any act like you have just touch the test probes together, you have a shorted part and the reason it shuts down.
May 01, 2010 | Yamaha RX-V392 Receiver
Kenwood VR-209 turns off after 20 minutes
Overheating is likely your root cause. Move the unit to make sure it is getting enough air around it and remove anything that you have sitting on top of it ESPECIALLY any device that produces heat of it's own such as your CD player. If that does not solve the problem, listen at a lower volume and/or defeat any equalization or bass enhancement circuitry.
May 09, 2009 | Kenwood VR-209 Receiver
Hum in sound volume
It could be a few things. The first thing you want to look at is make sure that the microphone is muted in the mixer controls of your audio cards. These settings are located in the control panel. If you need the mic, look under the advanced settings under it and disable the 20 db option for it.
If that doesn't work I have a few other ideas.
Mar 17, 2009 | Proscan 32LB30QD 32 in. LCD TV
Sub volume stays the same
in the back of head unit u might have 2 pre outs try swicthing them if u dont then on the amp u should have nobs turn them all the way up
Jun 16, 2008 | Kicker CVR12 Car Subwoofer
Amplifiers
The unit is shutting itself off because it has detected a problem in the output stage. In many cases the problem is in the front end. That front end stage is allowing some DC current to pass on to the output stage. DC on the outputs is bad. This unit requires service. Expect a parts cost in the range of $10-$20. Add in the local labor rate for the total repair cost.
Dan
May 05, 2008 | Audio Players & Recorders
Volume control unstable
You may have an over heating problem as it the Integra has anautomatic cut out. The unit generates a huge amount of heat and needs to be positioned in a very well ventilated position.
Linian
Dec 11, 2007 | Integra DTR-5.1 Receiver
Unlock volume on jvc tv
I've never really heard of the audio being locked in these units.. I do know there is a back-door code to unlock the channels, just press 8-8-8-8 for that...
It is possible that the auio amp is out, in this unit it's a TB1253an and a simple repair for a shop...
Hope this helps!
Bill
Nov 19, 2007 | JVC AV-27230 27" TV
90 people viewed this question
 Grubhead
Grubhead
