Question about Sewing Machines
The feed on my janome 2139n only sews with very small stitches. how can i regulate it to sew on the #4 setting length?
Trifect7
  • 57 Answers
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Posted on Mar 08, 2008
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
Posted on May 27, 2009
  • 55 Answers
SOURCE: bernina 1080 stitch length and needle jumping problem
you will most likely find that just adjusting the stitch length and width controls for a while will correct the problem (if the machine has been sitting idle for some time the stepper motor linkages seem to stiffen up a bit but i have good success with continual adjustment until they free-up.
also try switching machine off and on again to ensure it resets correctly.
the combination of both above fixes works 95% of the time - otherwise, as you mentioned circuit board and or stepper motor replacement may be necessary (however if both length and width are playing up it is unlikely to be an electrical fault).
scott
Posted on Jul 27, 2009
  • 980 Answers
SOURCE: Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Posted on Nov 06, 2009
sewinsnap
  • 135 Answers
SOURCE: I can't drop feed dog on my Husqvarna viking 230
It sounds like maybe you have it set up to make button holes.
Posted on Aug 14, 2010
I have been given janome 525s the material not feeding through the foot. Unless i pull material it wont move
Make sure the feed dogs have not been dropped, ie for darning or free motion quilting. Also, make sure the stitch length is set high enough to actually create a forward stitch.
Mar 18, 2017 | Janome Sewist 525S Mechanical Sewing...
Stitch length will not change
Setting Stitch Length: A Quick Look at How and Why ...
www.sew4home.com/.../sewing.../setting-stitch-length-quick-look-how-a...
Mar 3, 2015 - The majority of sewing machines indicate stitch length in millimeters. A 2.4 stitch length means each stitch will be 2.4 mm long. ... When you adjust the stitch length, it's not the needle that is changing, it's the feed dogs (those ...
How to Select Stitch Length ' Sewing Lessons - YouTube
? 2:40
https://www.youtube.com/watch?v=YqwHtYpKBzo
May 31, 2011 - Uploaded by HowcastArtsRec
Learn how to select stitch length when using your sewing machine for ... also not so small that it will take forever to get through your machine.
How Do I Fix My Sewing Machine: Troubleshooting Your ...
www.craftsy.com > Blog Home > Sewing Blog
Jan 24, 2016 | Sewing Machines
Janome sewing machine dial moves
I have exactly the same problem. Did you find a solution? If so I'd be really grateful to hear it ... Thank you.
Oct 23, 2012 | Janome Sewing Machines
Stitch regulator not working properly
it would be a good idea to have the machine checked, the stitch
length regulator need to be checked to see if it's worn or a gear
that move the part is worn and may need to be replaced.
Dogs motor?
Does it have a stitch length dial which ranges from 4 down to 0 and then into negative numbers? If so, the negative numbers will be reverse stitches. Some machines have this functionality and its very happy for doing mending or stitching in awkward places to sew backwards without having to hold the reverse button.
However, if yours is only sewing backwards when stitch length is set to 2, 3 or 4, then its probably a drive problem internally. Don't think your machine has a seperate motor for the feed dogs, probably a gear driven shaft in the free arm.
Dec 06, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Model 385-15343600 Serial 71073690 The stitches are very, very small all the time regardless which of the tension used (bobbin and needle).
The stitch length dial needs to be set to a lower number (number of stitches per inch) to give you longer stitches. The tensions do not regulate the stitch length, the feed dogs regulate the distance the material is advanced between stitches. Also, make sure the pressure foot is applying enough pressure to keep the material in firm enough contact with the feed dogs.
<Ray>
Nov 11, 2010 | Sewing Machines
Stitch problems
You can adjust the pressure foot(not footpedal)which puts the prsure on the foot by the needle. Also try altering the stitch length. If the stitches are skipping on silky fabric or knitted fabrics try using tissue and sewing onto that directly then tearing it off afterwards.
Nov 12, 2008 | Janome Sew Precise Mechanical Sewing...
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
