Question about SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive
I cannot eject it from my computer, it keeps saying there is a program open that's using it. I have shut down everything and it still says this...help
It works fine but when I'm done adding pictures, it won't let me "eject" it as it states there are other programs using it. I have shut down all programs and short of shutting off the computer, I can't get it to eject.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 71 Answers
Put ccleaner on your system and check the startup programs
it may be resolve your problem
Posted on Jan 04, 2013
4 Suggested Answers
flapjack937
  • 129 Answers
SOURCE: simpletech 250GB removing it from a pc...
Shut down your pc and it will auto shut down the drive, then plug it out and you will be fine
Posted on Sep 25, 2008
SOURCE: Everything was working fine until I shut down my
Please Change the Cable
Posted on Mar 30, 2010
  • 11800 Answers
SOURCE: Simpletech 160GB has a constant
Last hope attempt: dismantle the casing and extract the actual disk from inside it; put it in a desktop and see if it's recognized there. If even that fails then the disk is dead, time for a new one.
Posted on Jul 07, 2011
How to eject
just shut the laptop down and remove it
Dec 31, 2013 | Computers & Internet
Shuts off when eject button hit.
does it open when you when you connect it direct to the wall scoket.
Jun 04, 2008 | Quasar VM-L153 VHS-C Camcorder
Cant eject my toshiba external drive
Is it listed in Computer? if so, right click, scroll down to Eject. If that fails shut down computer, unplug external drive USB and pry the door open or disassemble the case.
Dec 25, 2012 | Toshiba E05A050CAU3XW Canvio Hard Drive...
It keeps running and doesn't shut down. Freezer
Check condensor for clogged coils and make sure the back is on it. (The pasteboard covering over the Service Opening on Bottom Rear)
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 17, 2011 | Whirlpool Refrigerators
I just bought a used pontoon boat with a Clarion Marine M235 radio/cd player. The previous owner said there is a cd stuck in the player and won't eject or play. The display says "no cd" but I...
you have to open the unit cover to remove the CD, its probably tried to eject it and its past the point that shows one in the slot which is causing the player to say NO CD , once opened, use great care in moving anything, and keep track of where everything goes,
Jul 04, 2011 | Audio Players & Recorders
I can't eject a dvd from my mac pro desktop
Try these tips.....usually holding down the touchpad buttton while tapping the eject button during bootup works.
picexporterror Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared.
picexporterror If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar.
picexporterror Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder
picexporterror Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button.
picexporterror Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism.
picexporterror Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray.
picexporterror Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. )
picexporterror If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Oct 24, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
DVD tray won't open.
Opening a CD or DVD drive to retrieve a disc
  • Use Windows to open the drive door:
    1. Double-click the My Computer icon on the desktop (or click Start and My Computer in Microsoft Windows XP).
    2. Right-click the CD, CD-RW, or DVD drive , and then click Eject .
  • Restart the computer and press the EJECT button on the front of the drive when the first screen appears (before Windows launches). If the drive door opens this way but does not open in Windows, another software program is taking control of the CD drive. Try shutting down or configuring any programs that write discs or monitor the CD drive.
  • If the door still will not open, do the following:
    1. Close all programs and shut down the computer.
    2. Unplug the PC from the power outlet and remove the battery.
    3. Locate the manual release hole in the front faceplate of the optical drive tray. This is a small hole under the door that is a little bigger than the diameter of a paper clip. The location of the manual eject hole will vary.
    4. Insert a straightened paperclip into the manual release hole until resistance is felt.
    5. Once the resistance is felt, keep pushing the paper clip until the drawer comes out about a quarter of an inch.
    6. Remove the paper clip and gently pull out the drawer until the disc is accessible.
    7. Remove the CD and turn on the computer.
May 21, 2009 | Daewoo DVG-3000N DVD Player
It wont recognize files and i cant eject it
Just restart your computer, this should fix all problems, don't worrie it will shut everything down and won't break anything. Can't say for sure on the files though they should be fine, if your computer froze however this is a different story.
If your in a program that is writing to your hard drive it's a good idea not to plugg hardware in as this can overload you ram or interfear with other prosseses. Just think if you will want the thing before you start your project.
Feb 25, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
E500 won't shut down
It is probably not shutting down because there is a program running that will not shut down. Unnstall programs you no longer use and do a virus scan, often the programs that refuse to shut down are malicious. Holding down the power button for 5 seconds should shut down the computer (it signals the motherboard to power down). As for the black screen, not enough detail for me to say.
Jan 02, 2009 | Compaq Armada E500 Notebook
Down load
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Mar 31, 2008 | Kodak EasyShare C340 Digital Camera
SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive Logo
142 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Ricky Ostrom
Ricky Ostrom
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
