Question about Dryers
Getting to hot
Getting way to hot and melting clothes
  • Dryers Master
  • 8,220 Answers
Control thermostat mounted on the blower housing I would replace. Obviously it is overheating. Don't know what brand you have but they all basically work the same. Nice video:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 02, 2013
How to remove paraffin? Thanks.
hot water, hot air drier, anything that is hot enough to melt the parafin
dab with clean cloth when hot
Nov 11, 2017 | Health & Beauty
A plastic hair clip melted and hardened in my clothes dryer. Can I remove it with a hot hair dryer or, would a hot air gun be better?
Melting it will create more of a mess. Since it has hardened why not try introducing a sharp object at the base of the blob and un sticking it from where it is attached.
Apr 04, 2017 | Refrigerators
Why is the metal screen with round holes located in my dryer drum melting some clothes and leaving its impression on those clothes. My appliance is a Frigidaire gas dryer model # LAQG7011KBO.
The metal screen is the place where the heat from the dryer enters the drum. If the dryer is melting items, you have one of two possible issues:
  • The dryer thermostats are allowing the dryer to get too hot.
  • You are drying delicate clothes on too high of a heat setting.
Jan 14, 2015 | Frigidaire Dryers
Our clothes come out with a black hardened materiel. The rear screen on drum has materiel melted onto it that appears to be melting during drying cycle and transferring to clothes. Does the screen come...
No it does not and even if it did the dryer's internal temp should not exceed 230 degrees and that would not be hot enough to melt any part of that dryer. Any warmer and it would scorch your clothes. Check for something that came out of a pocket, or some other way was introduced to the dryer.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gary_58e9c3508cafe590
Aug 04, 2013 | Frigidaire Dryers
Bosch iron TDA8320/01 soleplate marked
pan scrub or brillo pad soft wire wool you could heat the iron up and use hot soapy water on a dishcloth but be careful not to burn fingers as the cloth will get hot aswell
Apr 01, 2013 | Bosch TDA8340 Iron
We have a gas dryer purchased in 1996, Model #CDG800W. The dryer has started to make a strange grinding sound when we're drying clothes. Any suggestions?
Most likely a bad blower wheel. Over time the hub gets hot, melts, wobbles out, and start to rub the blower housing. The wheel slips and makes it take a long time to dry the clothes. This causes the filter to warp and the top to get extremely hot.fdd151b.jpg513b315.jpga1f312f.jpg77fbb60.jpg
I have posted more repair photos here
Nov 01, 2010 | Crosley Dryers
Dryer does not dry clothes but seems to be hot inside when i open the door
Most of these guys get a bad blower wheel. The heat melts the hub causing it to spin free and airflow is reduced. This makes it take fifty forevers to dry a load of clothes. More Here
Aug 18, 2010 | Crosley Dryers
Orange crayon melted all over the drum of drier and I cannot get it cleaned. Any suggests?
You now have hot melted wax coating EVERYTHING, I bet.
First, unplug your dryer, for safety.
Now take some turpentine or wd-40 and dampen a cloth with it.
Scrub, scrub away.
once it's clean(will take a LOT of elbow grease), you'll want to clean up the solvent.
A wash-cloth, dampened with soapy water, will do a pretty good job here.
Finally, leave the machine OPEN for a good solid day/night.
This lets any fumes remaining from the solvent escape.
this is important, if you don't want to blow up your dryer when you next start it up.
Jun 01, 2009 | Whirlpool Dryers
No longer melts solder with tip....
You have burned out residue on the tip. Clead it off with a damp cloth when the iron is hot. If this doesn't get it all, use steel wool. Immediately afterwards, get flux & solder onto the tip or it will get coated again.
Jan 24, 2009 | Weller BP860MP Dual Heat Battery Powered...
Dryers Logo
27 people viewed this question
Top Dryers Experts
