Question about Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated
No power tried switching out reset
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 142 Answers
Bad cord or pressure switch maybe
Posted on Jan 04, 2013
My RCA 7" tablet will not turn on. Just cycles through the power up mode
Try a tablet reset. First check for a pin hole reset switch location along the sides or the back of the tablet. If you have one, from the off mode depress the switch with a paperclip and power on.
If no reset switch: From the off mode, press and hold the power and volume+ buttons until the tablet recycles into the reset mode. Then follow any instructions.
Apr 01, 2015 | Tablets & eReaders
My Kindle Fire HD won't turn off. I was watching a movie on Netflix and the picture just froze
Turning Off the Kindle
Quickly sliding the power switch on the Kindle enters and resumes sleep mode. If your Kindle enters a non-responsive state when sliding the power switch, you've likely entered sleep mode. Try sliding the power switch and holding it for four seconds to shut down the device. If it still does not shut off, you may need to reset the Kindle.
Resetting the Kindle
The power switch also serves to reset the device. Before resetting the device, disconnect it from any power sources, such as an AC outlet or your computer's USB connection. Sliding the power switch and holding it for 20 seconds forces the Kindle to reset and power down. However, a nearly depleted battery may prevent this action. If the Kindle still doesn't shut off, try charging it for several hours and resetting it again.
Mar 17, 2015 | Amazon Kindle Fire HD 8.9"
How do I reset the Toshiba E-Studio 3055 copy machine? It isn't turning on.
There is no reset switch on this model. Make sure the power cable is connected properly (working) and turn on the power switch. Is there any LED lid when power is connected?
Dec 24, 2014 | Toshiba Office Equipment & Supplies
Error code c4801 For C284e
You may have main board issues. Maybe Try error code reset.
Open front door and locate main power switch on the bottom left and turn off.
Press and hold the reset button , button on control panel.
Turn main power switch back on whilst pressing reset.
after 1 - 2 min a white screen with 1 button saying"error code reset will appear , let goo of reset button.
Press error code reset and then turn main power switch of for 20 seconds. turn main power switch.
If code returns contact me on my phone to discuss
Sep 02, 2014 | Konica Minolta bizhub Office Equipment &...
Troubleshooting
Is it plugged in ?
Is the wall switch turned on ?
Is your power supply functional ?
If no lights or fans look at the power supply.
Oh Yes, a small switch near the power cord at the back of the computer, is it on ?
Do you have a reset switch, turn off all power and press the reset switch then try again ?
For some strange reason the reset function gets mucked up.
Like a bleeder resister or pullup resister is not doing its job.
Oct 19, 2013 | Sony VAIO VGC-JS210J/B 20.1 in. PC Desktop
How do you reset a Magellan 1700 GPS?
FAQ on your unit says this.
Depending on the power switch your unit was designed with follow the instructions below:
Slide Switch If your unit has a Slide power switch then slide and hold the power switch in the off position for more than 8 seconds.
Push Down Power Button If your unit has a Push Down Power Button for a Reset pin hole on the bottom or on either side of the unit. Take a pin or an end of a paperclip and insert it into the hole and push in until you feel it pop slightly, hold it for 10 seconds. Your unit will reset itself.
Reset Power Switch If your unit has a Reset Power Switch then it will have a three position power switch (Reset, Off, On), if this is the case slide the switch to the reset position and hold it for 10 seconds to perform the reset.
If that doesn't work, contact them direct. sometimes they have to install clean firmware.
MagellanGPS Technical Support Consumer Sales Customer Service
Apr 08, 2017 | Magellan Roadmate 1700
My motherboard wont power on when i press the power button, all cabels ok, button ok, but still wont power on, sometimes after 10-80 pushes it powers up, need help, thanks...
please remove first the bios memory to reset your system if thats not fixed the problem try to remove the memory card and clean it with an eraser if it still not work, try to remove the video card and clean it also.
Aug 01, 2011 | Asrock K7VT4A-Pro Motherboard
Prs 350 not responding to anything. tried power switch, soft reset button, and connecting usb cable. stuck on page of book i was reading.
Welcome to Fixya
Try to reset the device. Reset the Reader by pressing the RESET hole with a small pin or clip. After 5 seconds, slide the POWER switch to restart the Reader. The content and settings stored on the Reader are not affected by resetting.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Jul 31, 2011 | Sony PRS350
Robinar Cooltech 342000 - on start up stops on the "Initalizing System" screen. Is there a reset procedure available?
You can try the following : 1# Check main 15 amp circuit breaker (located on back of the machine), reset the circuit breaker. If breaker tripped again after reset, the circuit breaker need to be replace.
2# Verify line voltage is present at input of main power switch & output at switch turn ON. If line voltage is not present at power switch input, check connections between power switch and AC plug. If line voltage is present at power switch input, but not at output with power switch turned ON, replace power switch.
3# If all proceeding steps tested OK & problem still exist, you may nee to replace The main control module.
Hope this will help you, if so please vote for it.
Mar 07, 2011 | Robinair Cool Tech 34700Z Recovery,...
Compaq V5201US Notebook Will Not Start/Boot UP
Remove the power adapter and the battery. Hold the power button in for up to 60 seconds to discharge the laptop. Re-apply power and try booting the laptop.
Jul 20, 2008 | Computers & Internet
Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated Logo
19 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
