Question about BlueTrek G2 Consumer Headset
Nokia 6680 wont connect to Bluetrek G2
Hi there, i have a nokia 6680 and have borrowed 2 sets of Bluetrek G2n's of which Neither will connect with my nokia, the phone just will not find them, i dont have instructions with the sets so i am guessing that i just hold the main button until it turns on then just try and connect the phone? no joy , i have tried everything and am getting pretty fed up to be honest thanks Jim
  • 4 more comments
  • Anonymous Nov 14, 2007
    had the same promlem but the solution offered was very helpful and it did end up working!! the solution worked for the samsung A640 mucho thanks!!
  • Anonymous Jun 01, 2008
    I tried holdimg some buttons
  • Anonymous Sep 01, 2008
    i have same problem i knowhow 7 secs.
    its not working know
  • Anonymous Jan 28, 2009
    I had the same problem with my N95, but that solution solved it. It is important to hold the speaker button for 7 seconds or until the lights flash red and blue, I was trying it but the light was only blue (that is only for connecting it once it is paired), i was not holding the button enough time for the pairing to start. I hold it for 7 seconds and the lights started and my phone then discovered the device. It works at least for me. Thanks
  • Anonymous Feb 22, 2009
    i have a blackberry curve and the phone wont or cant find the headset
  • Anonymous Apr 05, 2009
    Thanks dude..this holding 7 seconds formula worked for me..keep posting u r valuable solutions..
Just had the same problem.
But I found some bluetrek instructions on the net & it works
Pairing the BLUETREK® G2
Before using the BLUETREK® G2 headset, you must pair it with your Bluetooth® mobile
phone. Pairing is the process of linking 2 Bluetooth® devices, so that they can
communicate.
To initiate pairing:
1. Place the BLUETREK® G2 and your mobile phone within 0.3 meter (1 foot) from
each other.
2. Switch on your phone and select its Bluetooth® discover mode (refer to the
Bluetooth® mobile phone user manual).
3. When the BLUETREK® G2 is switched off, press and hold the TALK button for
about 7 seconds until the indicator light flashes red and blue alternatively. And a
sound can be heard in the speaker.
4. Once the mobile phone detects the headset, a “BlueTrek G2” message will be
displayed. Follow the phone instructions to accept the pairing. The PIN code (or
passkey) is 0000, then press “yes” or “ok”.
If pairing success, the indicator light will switch to blue and flashes slowly.
If you haven’t started the discovery mode within 5 minutes, the headset
Posted on Oct 19, 2007
  • samzymo Jan 06, 2011
    this is very true the prob i had was just to have held the talk bottom for ten secs and my phone discorverd it, am very thankful for the assistance
SOURCE:
I have nokia 6680 I I forgot screen lock code when I turn my phone on it asking for lock code so now how I can open it ?
How can you forget a code you set and have been using multiple times a day? The default code is 12345. If you 'found' the phone, perhaps it is still set to the default.
NOKIA 6680 - How to Hard Reset my phone - HardReset.info
www.hardreset.info/devices/nokia/nokia-6680/hardreset/first-method/
Hard Reset NOKIA 6680. First method: Power on your handset. Hard Reset NOKIA 6680. Then please press and hold * key + 3 key + Call button + Power button, until you see Nokia logo. HardReset NOKIA 6680; After that enter your lock code. * The default lock code is 12345; Now your phone will reset and restart.
www.hardreset.info/devices/nokia/nokia-6680/hardreset/third-method/ Hard Reset NOKIA 6680. Third method: Switch on your phone. Hard Reset NOKIA 6680. Next press Menu button and goto Settings -> Phone -> Phone management -> Factory Settings -> Delete data and restore -> Yes Factory Reset NOKIA 6680; Then your device will reset and reboots. That's all. See the Previous method!
www.hardreset.info/devices/nokia/nokia-6680/hardreset/second-method/ Hard Reset NOKIA 6680. Second method: Turn on your cell phone. Hard Reset NOKIA 6680. You should now type this code: *#7370#; Then press your lock code. * The default lock code is 12345; After that your phone will reset and restarts. Success! See the Previous method! See the Next method! How to Hard Rest NOKIA ...
Nokia 6680 hard reset
www.hard-reset.com > Nokia hard reset Apr 3, 2010 - Nokia 6680 hard reset: Press these buttons * + 3 + call + Power on your phone. Before the device is reset, you need to provide the lock code. The default lock code is.
Nokia 6680 Hard reset - How To Factory Reset
https://www.hardreset99.com/nokia-hard-reset/nokia-6680-hard-reset-factory-reset/ Feb 18, 2017 - Nokia 6680 Hard reset and Factory reset. Forgot your android mobile Password or PIN or Pattern, Here you can get recovery solutions for free.
NOKIA 6680 Hard Reset - IMEI.info
www.imei.info/hard-reset-1350-nokia-6680/ Are your looking for a way to make your NOKIA 6680 work faster? Do you wish to clear all of the data on your NOKIA 6680 before selling it to someone else? Well what you need is the factory reset. What is it? Factory reset (aka hard reset) is an operation which deletes all data (including settings, applications, calendars, ...
videos
nokia 6680 hard reset Google Search
Mar 24, 2018 | Nokia Cell Phones
Nokia 6680 imei code 357617-00-385577-2
You can get the IMEI Unlock code for Nokia 6680 at Simpleunlocking.com and get Free Unlocking instructions for Nokia 6680 at Mobileunlockguide.com/nokia-6680 unlock it step by step.
Aug 25, 2012 | Nokia 6600
Have lost the manual to bluetrek and have an iphone 3 now and need to get the bluetooth working with this new phone
First, here is the link to the manual:
http://www.bluetrek.com/getfile.php?source=/download/product_download-manual63.pdf&filename=CompactClassic+Manual%2C+English&file_extension=pdf
Here are the instruction: 1. Switch on your Bluetrek and press and hold Talk button and Vol+ button for about five seconds untill indicator light flashes red and blue alternatively and you will hear a sound from speaker.
2. Open bluetooth in Iphone 3 search for bluetooth device. You will see Bluetrek Compact Classic. Click on name to pair and enter "0000" as pin code.
Bluetrek will be connected to iPhone.
Jun 02, 2011 | BlueTrek Compact Classic Ultra Slim...
How to use the video call in nokia 6680?
For Video call you need - 1) A phone with 3G compatibility, 2) A 3G active connection to your no. ( For this call your customer care) 3) to whom you are calling..he also must have these requirements.
Oct 20, 2010 | Nokia 6680 Cellular Phone
Instructions please
Hi - You can download the manual from the link underlined in blue below:
BlueTrek > G2
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 06, 2008 | BlueTrek G2 Consumer Headset
Reprogram my nokia 6680
Full phone formatting on a 6680!
If you encounter situation like below on your 6680,
1. Blank screen phone unable to reboot.
2. Phone only able to boot-up to "Nokia" word screen.
3. Install some program but not able to uninstall it after that.
4. Error messages such as "Child Installer" keeps popping-up.
Do a Full phone formatting on your 6680! as steps below,
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your 6680 phone.
4. Press and hold 3 keys;
Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the 6680 phone.
Remember, do not let go all of the keys and hold keys until you see a Nokia turns to white and blink' and nokia logo!
5. After a few minutes when the Full phone formatting completed, your 6680 will back to original system and factory settting.
All apps installed & not of the phones' default will be lost. If you did a backup on your mmc, you can restore it back to the C drive again.
Thank you for rating this Tip.
Dec 26, 2007 | Nokia 6680 Handheld
Nokia 6680:Handsfree Mode problem
problem is inside ur phone, on its pcb, may be ur phone contacted with moisture which is creating problem over pins of ur headphone connecter on ur phone. u need to take it to technician.
Dec 12, 2007 | Nokia 6680 Handheld
BlueTrek G2 Consumer Headset Logo
770 people viewed this question
Top BlueTrek Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a BlueTrek Radio Communication Expert? Answer questions, earn points and help others
