Question about Optics
Western field telescope manual - Optics
Pieces in Wide Field Finderscope are loose. Telescope 78-5660 60MM
PDF]Telescope Instruction Manual - Bushnell
bushnell.com/getmedia/...5f19.../78-9500.pdf?...
Bushnell CorporationParts Diagrams. 4. 1. Red Dot Wide Field Finderscope. 2. Eyepiece. 3. TelescopeMain Tube. 4. 60mm Objective Lens. 5. Latitude Lock Knob. 6. Tripod Leg. 7.
[PDF]voyager® 6 inch dobsonian telescope model 78 ... - B
Jan 01, 2016 | Bushnell Optics
I need a user manual (instruction book) for my telescope i bought off of a friend
I'm glad to provide the manual. Please click hear to download the manual for the Telescope.
Please let me know if you require further assistance.
Jun 20, 2011 | Meade 12 Inch LX200ACF Advanced Coma Free...
I need instructions for Jessops 800x80 astronomical telescope please
This is a refractor style telescope. You did not say if it is on an equitorial mount or an ALT AZ mount.
Read my TIPS on my profile page. You will not find a manual for that telescope. Objects in the night sky are tiny and many are very dim. Your scope has a VERY small field of view so the telescope must be pointed directly at the object or you will see nothing. Start by using the eyepiece with the largest number written on it. This is your lowest magnification and will have the widest field of view.
Join a local astronomy club and the members will help you.
Jan 29, 2011 | Optics
How do you get around the small field of view
You can't. This is a toy, not a real scope. The largest FOV is with your lowest power (biggest number) eyepiece.
If interested in wide field views, buy a GOOD telescope with a low focal ratio (below f/8)
Oct 10, 2010 | Bushnell Tasco Telescope Galaxsee 525x60mm...
No manual for telescope
You will not find a manual for this telescope. It is imported from overseas,
Here is a PICTURE of the telescope setup-
http://www.binoculars-uk.co.uk/acatalog/Farvision_300_70_series.html
This is a very small refractor style telescope. The 60mm aperture is about the same size as a pair of 10x50mm binoculars. The binoculars would have been better for Astronomy than the small scope, since the binoculars have a wider field of view.
Jul 27, 2010 | Optics
Need a manual for tasco 56t sd don't know how to use it
Here is the manual:
http://docs.google.com/viewer?a=v&q=cache:ANsyqHrcy1UJ:www.tasco.com/products/manuals/Tasco56TN-57TN-301051N-301004N-301005N.pdf+tasco+56tn+telescope+manual&hl=en&gl=us&pid=bl&srcid=ADGEESiCAxnIsokVaYsESKffWHIqbDg7h3VF-AFm2iMHA2-oqpTo3PvVxpRjpalSqaBGlyl8BlkJZb049t8Ooz6AHNKb09ssXUCNiaRi4C2QND2EanE_73ROmmNcjC_KnD-RJOimbSpx&sig=AHIEtbT5bdFoxKc2OD1wUa-4xOHbz9fbqQ
This is a very small 50mm refractor telescope. The same aperture as a pair of 10x50mm binoculars, which would have been better for viewing sky objects. The maximum possible magnification is about 100 power (50 times aperture of 2 inches).
The field of view is very small you must be pointed directly at the sky object to see it. This is why we recommend a pair of binoculars as your first telescope. Binoculars have a wider field of view which makes finding things easier for the beginner.
Read my TIPS on my profile page, and read this:
http://www.texasastro.org/telescope.php
Jun 11, 2010 | Tasco Specialty 56TN (200 x 50mm)...
How do you mount an ext 90 telescope (meade) to its tripod (ext field tripod). both are unused out of the box
There are two holes in the base of the telescope that match up with the two thumb screws on the tripod. It's easier if you lift up the base of the tripod a little using the latitude scale shaft.
Read the manual front to back before you use the scope.
Nov 19, 2009 | Meade Optics
Bushnell 114mm reflector telescope, can't see a thing
Probably NOT actually pointed directly at the moon-- you should have moved it around a little -- the moon was probably just outside the field of view through the eyepiece. ........................ telescope must be pointed DIRECTLY at the sky object-- also use the eyepiece with the largest number written on it=== this gives the LOWEST magnification..... and a slightly wider field of view.
Mar 07, 2009 | Fieldvision 114mm Reflector (114 x 114mm)...
Autostar software
Check the operating manual for the camera - you may be saving the image with the wrong selections. Most astronomical cameras have 'dark field' and 'flat field' exposures that are used together to compensate for sensor and telescope variations. The 'dark field' is to find hot pixils and the 'flat field' is to get the uniformity of the telescope/camera combination. Together, they are used to correct the image and produce a final image.
Oct 25, 2008 | Meade Autostar Suite Autostar Suite...
Optics Logo
231 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you an Optic Expert? Answer questions, earn points and help others
