Question about Samsung Hl-s5686w 56-inch Dlp Hdtv
Hdmi2 says weak or no signal
Hdmi 1 works however when anything is plugged into hdmi 2 it reads weak or no signal
SOURCE: hdmi input
What are you attempting to use HDMI for? Sometimes you have to adjust the settings of the system that is using the HDMI connection. The tv needs to reset to HDMI
Posted on Apr 10, 2008
  • 93 Answers
SOURCE: Samsung HDMI issue
Have you try to replace your HDMI cable?I recommend you to pick up a good Monster HD700 HDMI cable from a local retail store like best buy or circuit city.In case it isn't the cable problem,you could return it.
However,when you are a using the HDMI cable,it is normally either have both picture and sound or nothing at all.Are you sure you didn't hook up the audio OUTPUT from your TV back to a receiver input?
Or even an optical output from the TV to the receiver?
solutiondoct
Posted on Nov 06, 2008
SOURCE: digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Posted on Apr 01, 2009
  • 453 Answers
SOURCE: HDMI outlet seems to be bad/ no picture
u need a main signal board replacement
Posted on May 08, 2009
sabreusa
  • 271 Answers
SOURCE: HDMI failure Samsung HL-R5087W 50 in HDTV
After reviewing the service manual for this set, the problem is is in the DIGITAL BOARD. To get the right Digital Board you will need the Version number of the TV.
Good luck
N Sabre
Posted on Nov 09, 2009
Sony KDL-40NX711 HDMI PORTS STOPPED WORKING. EVERYTHING ELSE WORKS FINE. WHAT WOULD CAUSE THIS TO HAPPEN?
Sounds like everything works. Your remote has an input menu. Have you cycled it around to the right component? i.e. HDMI1 or HDMI2, or DVD, even PC?
If not, try that.
Feb 09, 2016 | Sony Televison & Video
The light just blink green it doesn't let me do anything but blink green.
If you plug the Roku into the back of the TV in an HDMI port, you need to hit the Input button on the TV to change (probably) from HDMI1 to HDMI2. Once you are on HDMI2, you should see the Roku emblem. Then you need to set up the Roku to see your wireless signal.
Dec 16, 2015 | Roku Streaming Stick HDMI Version
My emerson tv say device control inactive
John, I've ran into this issue a couple of times myself. In most cases, there are easy fixes to the issue. #1, Does your TV have multiple HDMI inputs? They may be labeled HDMI1, or HDMI2, etc. I know this sounds strange, but many people don't realize that the signal source is important. #2, Connect the cord, from another device that you know works(laptop-monitor) to eliminate the possibility that your HDMI cord is bad. #3, (Probably most common) The PS3 is not the most stable platform when using the HDMI cord. Remember that the PS3 was one of the "pioneering" platforms using the HDMI connection.As such, the "auto-detect" feature is sometimes confused when switching between RCA inputs, and HDMI input. (Happens every time actually) To fix this, try a video reset on your PS3 system. It's fast, easy, and doesn't effect anything except the video/audio settings. I'll put in a link to get you started in that direction. It is the same with all models of PS3. Good luck! ^^
How To Reset PS3 Video Settings PS3
May 06, 2013 | Sony Playstation 3 (PS3) Console
Im trying to connect my presario cq60 to my lg 32hl3000 tv through the hdmi ports but no picture shows on my tv. It says there is no signal?
Your television may have multiple HDMI ports. When going through main menu on the television, look to see more than 1 HDMI entry (typically numbered HDMI, HDMI2 etc). Try all HDMI available on the television until you see a picture of your notebook's desktop on the television.
Aug 20, 2011 | Compaq Presario CQ60-220US PC Laptop
On my tv it has 3 hdmi connections and only the hdmi 1 is working after plugging the device in it you can change channel to the other 2 and it shows what is on hdmi 1 and the others will not recieve a...
check your avsource setup, it should be hdmi1, hdmi2 and hdmi3 selection on your audio video source programm.. othe wise it will auto detect signal.
May 30, 2011 | Televison & Video
We have a Polaroid 4241-TLXB television. This evening we turned on the TV and the Video6 (HDMI1) is not accepting sound. The picture is fine when that input is selected. We had our STB attached to HDMI1...
I am having a somewhat similar experience. The HDMI 2 is a little flaky on these TVs, try turning the input device that is attached to HDMI 1 OFF then reboot the TV. For some reason, if there is a signal going to both HDMI inputs at the same time there are major problems. I also found that if I input L/R audio into the HDMI 2 analog jacks, that sound also goes to HDMI 1(if no digital sound signal is going there).
Feb 16, 2011 | Televison & Video
Turn hdmi2 on
hdmi is auto detecting and shouldn't need to be turned on. try plugging your hdmi1 device into the hdmi2 slot. if switching devices around doesn't get hdmi2 working, that jack is likely broken. all the hdmi ports go into the 1 main board inside, and a lot of times you would have to replace that board to fix. if only 1 jack now works, you could also get an hdmi switcher, and then plug all your devices into that, and then just plug the switcher into the working jack. let me know if I you require further assistance.
Sep 09, 2010 | Samsung LE32A457 32 in. LCD TV
No signal on HDMI1. Had to switch to HDMI2
Ur HDMI/1 might be shorted,will not work again.But u can tries unplug,replug the tv an hour later,let it reset it self back to factory setting.Who know might get lucky,it work again.
Apr 24, 2010 | LG 50PC5DC 50 in. Plasma HDTV
Audio on HDMI(2) output with external audiocord?
The audio from the hdmi out on your computer is turned off. Try connecting another device such as a dvd player to the hdmi input on your tv . If audio works on tv then you know no audio is not available from the hdmi output on you computer.
Nov 21, 2009 | LG 42PC1R 42 in. Plasma HDTV
Vizio vw42lf hdmi problem
The factory menu won't help you diagnose anything. If you are having issues on both HDMI ports, definitely check the cable and that the output works on the DVD player, try this on another TV if possible. If all else fails, call Vizio @ 1-877-MYVIZIO and they will send one of us techs out to replace the main A/V board, that should resolve your problem.
Aug 13, 2008 | Televison & Video
Samsung Hl-s5686w 56-inch Dlp Hdtv Logo
20 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
