Question about RCA R52WH73 Projection Television
High pitched noise related to the color shifts. RCA 52"
I had a problem with the convergence fuse. I replaced it as per suggestion here. And it got the RCA 52" working. Thanks
Now the TV makes a high pitch noise as it did prior to the convergence problem.
Any suggestions on how to fix this problem. Which I am sure has something to do with blowing the fuse.
  • RCA Master
  • 5,138 Answers
Coil LL037 resolder then glue top with stick glue or replace coil.
Posted on Feb 19, 2009
Loud whinning, high pitch noise coming from TV when turned on.
The color wheel is likely bad and needs to be replaced.
Check this link it is for a samsung TV but the same principals apply
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Oct 17, 2009 | RCA R52WM24 52" HDTV Projection Television
RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Aug 30, 2009 | RCA P52926 52" Rear Projection Television
RCA D52W19 52 in When my set is Immed, turned
WHAT ISTHAT WHEN MY TV MAKE NOISES THEN STOP FOR AMINUTE ONCE THE PICTURE IS THER THEN 10 MINUTES IS CUTOFF LIKE ITS TRYING TO COME BACK ON WITH THE SAME NOISES
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
52 in. rca high def. rear proj. making high pitch noise
the set probably has lots of bad solder connection on the flyback and in the horizontal deflection circuit.
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sometimes screams a high pitched noise when turned on
the high pitch noise is from the HV. arcing acrss each other.
( the screen comes up at a pop).
I suggest get a better one. ( sorry! no domastic brand).
Oct 27, 2008 | RCA HD52W56 52" Rear Projection HDTV
High pitch noise...
replacement of the color wheel is an option.. as a technician i dont find replacement all that difficult. finding one too replace it with is the most problem...
May 19, 2008 | RCA HD52W56 52" Rear Projection HDTV
TV making high pitch sound
Hi, There are usually 1 or 2 fans inside the TV's. Could be worn bearings, or fan blade interference. Sorry, without my electric ear working, I can only guess.
Apr 21, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA R52WH77 convergence missing from menu
THis is very common on these sets. there is a special fuse thats cause this.. kinda hard to get rca part number 259213.. .4 amp. the reason this blows is there is bad solder connections on the flyback. so when you replace this fuse you have to resolder these connections. so if you know how to solder and can find this special fuse. it is a fast and easy repair
Apr 08, 2008 | RCA P52937 52" Rear Projection Television
52 in RCA widescreen HDTV Monitor
high pitched squealing noise >> im thinking is the color wheel which will also give you the yellow color, don't know if that would also cause your screen to blank.
mcm carries RCA
Feb 01, 2008 | RCA HD52W59 HDTV Projection Television
RCA D52W19 52 in. Rear
open it up and see if any liquid is spilled on the boards, most squeals are from the high voltage transformer and or splitter
Jan 17, 2008 | RCA D52W19 52" Rear Projection Television
RCA R52WH73 Projection Television Logo
78 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
