Question about Frigidaire Electric Dryer
Frigidaire dryer gallery series is making a grinding sound. I believe the drum has come loose because its missing screws! How do i fix this?
AlmostBob
  • 550 Answers
SOURCE: I have a Frigidaire gallery
the dryer circuit will be clearly labelled in the house box, there will be two fuses or a single two phase breaker for this circuit.
there are not usually electrical fuses as such IN a dryer, there are thermostats to regulate temperature, and a thermal fuse, that cuts the power totally to the heat element if air temperature rises above its melt point.
the element itself has a limited life span and may fuse/burnout.
to test electrical components.
Unplug dryer
open case, by removing the front,
described elsewhere in any of the 'changing belt' threads
locate the thermal cutouts, on the fan housing or exhaust duct and disconnect one wire to isolate it from the rest of the circuit, test with ohmmmeter, no-continuity replace, continuity reconnect wire
3aca526.jpg5d18df6.jpg thermal cuttouts look like these ~1inch accross.
locate the heat element and disconnect one wire to isolate it from the rest of the circuit, test with ohmmmeter, no-continuity replace, continuity reconnect wire
while you have the dryer open de-lint the fan and exhaust ducting, most common cause of element or themal fuse failure is air flow restriction
7713ef8.jpgce0732c.jpg you get a lot of lint out of the fan even when proper cleaning is done, and clean out the ducting right to the exterior walls
95b69b0.jpgthis was the rather extreme result of not cleaning the duct (brainiac placed a wire across the terminals of the burnt out thermal fuse)
Posted on Oct 23, 2008
onthejob5130
  • 640 Answers
SOURCE: Need to know how to reattach the dryer drum
ouch budddie...happy new year ...looking in the dryer are you taking about those there center mass,,,if that attactes the back bearing surport to the drum...,,if that the two parts which i think your talking about ..you have to take the drum all the way out,,because those three screws are shape like a piece of pizza....it will never line up with drum in...
Posted on Jan 01, 2009
  • 104 Answers
SOURCE: Our four year old frigidaire gallery series dryer stopped drying.
knackered
Posted on Feb 01, 2009
TheMobilian
  • 8220 Answers
SOURCE: Wire Scraping sound and sparks inside rear dryer drum area.
Probably the rear bearing has failed and caused the drum to rub against the heating element. Hey, is this the guy that said he heard a noise last month? LOL
Posted on Feb 04, 2009
hunter19_46m
  • 7482 Answers
SOURCE: GLER341AS1 Frigidaire electric dryer, was grinding, now not work.
Sounds like you have two problems with your dryer, both are fairly easy fixes if you are mechanically inclined and cheaper than buying a new dryer.
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
1...Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley. 2..Sounds like the front seal between the drum and the door needs to be replaced
If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt and front seal. You can now replace or reposition the drum seal if it has moved from its normal position. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Posted on Jan 11, 2010
Frigidaire Gallery Series GLEH1642FS loud noise on final spin
It sounds like something has come loose or some item was placed in the unit accidentally and it got lodged in the drum. You will need to start by taking the front cover off and looking around the drum.
Jan 27, 2013 | Frigidaire Gallery Series GLEH1642FS
My Gallery Series dryer makes an intermittent noise when i turn on the dryer. It sounds like the drum is getting caught up on something. It sounds like grinding gears. The noise comes and goes
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 08, 2011 | Dryers
I have a Frigidaire Gallery Series dryer that has developed a squeek when drying. The dryer is about 3 years old.... and doesn't do it all the time
heatman101
Jul 27, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
My Frigidaire Gallery front loading dryer seems to be out of balance. It has become louder and makes a rhythmic grinding noise as it spins. Sometimes it starts with grinding noise that stops after a...
YOUR DRYER DEFINITELY HAS A BEARING RUNOUT PROBLEM (THATS THE GRINDING NOISE YOU HEAR - THE DRUM RUNNING ON THE SIDE OF THE CABINET ) . IT WOULD ALSO GRAB CLOTHES AS YOU SUGGEST . COST TOO MUCH TO FIX = GO AND SHOUT YOURSELF A NEW ONE IF U CAN .
Jul 26, 2011 | Dryers
Dryer problem
Your dryer drum front support glides and rear drum bearing needs to be replaced, parts are not expensive but labor to do the job may be $50 to $100 dollars.
You should call Frigidaire customer help line just to gather some info from them. 1-800-FRIGIDAIRE
Good luck !
Jan 05, 2010 | Dryers
FWT445GES1 Washer makes loud banging noises like it's going to explode.
Washer- you need a complete tub and bearring kit. this is a common problem for people who have well water. (also just happens) the rear yoke has become corroded and broken. its a costly repair.
dryer - you would need a new front slider seal. very simple to install.
May 28, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Lg dryer - front load - making a grinding noise
I also have the same problem as klrlesimmons, exactly as described. Sounds like sand is rubbing as the drum turns, and also sounds out of balance.
Repairmen replaced upper and lower glides and also the plastic bearing but not the entire bearing assembly.
Frigidaire Gallery, Model Number 417.49012890
Mar 22, 2009 | LG DLE3777 Electric Dryer
Feb 01, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire Front Load Dryer
Reach inside the drum and feel the drum inserts to see if one of those has come loose. Sometimes you can have one of those screws back out and hit something on the inside. Could also be a bent drum (doubtful unless its been overloaded or abused real bad) a front slide is bad (would probably cause squeeking or grinding noise) or rear bering (also should squeek or grind). Good Luck!!! Jim
Sep 07, 2007 | Dryers
Frigidaire  Electric Dryer Logo
18 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
