The Computer boots up, but nothing shows up on the screen.
Just curious if this could be a connection issue with the screen or internal hardware problem.
  • Computers & ... Master
  • 5,660 Answers
There is an easy way to find out, Jodie.
1) Laptop OFF, monitor OFF, attach a VGA monitor to the VGA port on the laptop.
This is an example of a VGA port, and a VGA Cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down for an example of a VGA Cable.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
(Now watch your laptop not have a VGA port. HDMI, or DVI.
This is why the manufacturer name, and model number of the laptop, needs to be posted.
The model number is located on the Bottom of the laptop )
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the external VGA monitor should show graphics.
If not;
There are at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down, and tap once on the Display Toggle-Over key.
(Ahem........nope can't tell you which one it is.
HP? Usually the F4 key
Acer? F5 key
Lenovo/IBM? F8 key.
Don't hold me to it, though )
Still no display on external VGA monitor?
Hold the Fn key down again, and tap once more on the Display Toggle-Over key.
NO display on external monitor means an internal hardware problem.
Graphics chipset.
Most of the time it is the mounting of the graphics chipset, TO motherboard. They are soldered directly to the motherboard, UNLESS it is an actual graphics card.
MANY a laptop manufacturer touts their laptops have a graphics card, when in reality that is a bunch of Hooey!
Just advertiser's license to mislead the public.
If that is the problem, it can be dealt with.
[Just for quick edification, the graphics chipset is mounted to the motherboard, via a BGA surface mount. Ball Grid Array.
View the following short video, and watch a BGA Rework Station at work, and also learn more about the BGA surface mount,
http://ersa.com/art-ir-pl-650-346-1472.html
Scroll down, click on the red - Take a few minutes to view the IR 650 demo video ]
Graphics show on external monitor?
Problem is the Video Cable, or inside the Display Assembly.
[ Display Assembly is the;
1) LCD screen,
2) Screen Frame: Metal frame which surrounds the LCD screen,
and holds the layers of the LCD screen in place,
3) Display Bezel (Thin plastic frame in front of the LCD screen)
4) Web Camera (If option)
5) Screen Inverter (If used)
6) Display Cover. (Top cover over LCD screen. The cover you look at when the laptop is closed)
7) Wireless Antenna
8) Backlight ]
A primer before we go on;
An LCD screen cannot produce light,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
(Click on the monitor image)
It needs an additional light source. A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
(Light Emitting Diode)
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height.
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
View the last 8 photos.
I do not know if your laptop uses CCFL for a Backlight, or a series of LED's. (Model Number, and I will)
A screen Inverter is used to convert the power, (Electricity), from the laptop; for the LCD screen, and Backlight.
SOME of the laptops that first came out, and used LED's for Backlighting; DID use a screen Inverter.
Most cases now is that if a laptop uses LED's for Backlighting; NO screen Inverter is used.
If the fault is found to be a bad Backlight, AND the laptop uses CCFL for Backlighting;
I ADVISE do NOT replace the CCFL Backlight yourself!!!!
They contain Mercury, just like their bigger 'cousins' used in homes, and businesses.
Mercury is a POISON to the human body. Can kill you QUICK!
Plus they are fragile, and are broken easily.
The laptops that use a series of LED's for a Backlight, have the entire LCD screen replaced. It is a unit. LCD screen, and LED backlights.
Primer over.
Laptop on, take a flashlight, and shine it at various angles on the LCD screen.
See faint images? Your screen Inverter is bad, (IF used), or your Backlight is bad.
Display Bezel removed, the screen Inverter is usually located at the bottom of the LCD Screen Frame.
To test a screen Inverter requires a sensitive multimeter.
Read fairly expensive,
http://www.fonerbooks.com/test.htm
Just drag the laptop down to the nearest computer repair shop, and have them test it?
Ummm, no.
A) Doubtful they will want to fool with a laptop partially disassembled. Too much 'litigation'. They could be held responsible for someone else's mistake.
B) They will just want to sell you a new/used laptop.
Most just replace the screen Inverter, due to the low cost, and ease of access to replace. ($10 to $20 bucks)
The Video Cable connects to the motherboard, and usually under an area under the Keyboard, or Switch Cover.
(Switch Cover: Cover that contains the Power On switch {Button}, and LED indicator lights. Under the LCD screen, and above the Keyboard)
It then routes through Latches, and Tabs, over to the left Hinge.
From there it goes up into the Display Assembly.
It then connects to the LCD screen, and screen Inverter; if used.
(Or up to the series of LED's used for a Backlight)
Due to just the normal opening, and closing of the laptop; the Video Cable may be pinched; and pulled on.
This can cause one of two things, or both;
1) Video Cable connection at motherboard may be pulled loose.
Video Cable connections at screen Inverter (If used), or LCD screen; may be pulled loose.
2) Damage to the tiny wires inside the sheath of the Video Cable.
(Stretched/Broken)
This makes the Video Cable the 'problem child'. It, and the screen Inverter, are on the top of the list with display problems.
(However 90 percent of the time, the fault can be attributed to a bad screen Inverter)
ALL power is removed, AC adapter (Charger), and Battery.
Laptop is disassembled far enough, to access the motherboard connection of Video Cable.
You have to PHYSICALLY check to see if the Video Cable, is plugged in tight. Visual inspection will NOT do. (Try to plug it in tighter)
Still no?
Disassemble the Display Assembly. You have to go far enough, that you can tilt the LCD screen forward, and check the connections on the back. With the Display Bezel removed, you check the screen Inverter connection. (IF used)
Still no? All Video Cable connections are tight?
You HAVE to rule the Video Cable out, as the problem.
This means taking a multimeter set to OHM's, (1K), and check EACH, and every wire in the Video Cable for continuity.
Makes sure there are no broken wires in the Video Cable.
No multimeter? Suggest take the Video Cable down to the nearest small computer shop, and have the resident tech check it out for you.
Should just be a few bucks.
Video Cable is good? Go on.
Screen Inverter is next.
Video Cable, and screen Inverter check out OK? (Replaced screen Inverter)
Then the problem is the LCD screen.
Video Cable? Varies. I have seen them from $9 bucks, up to $40.
Usually $9.
Screen Inverter? As stated, $10 to $20.
LCD screen? $60 to $240.
This is why it pays to go through a flowchart, and not buy an LCD screen needlessly. Would Bl-ow if the problem is a $9 Video Cable, and you bought a $240 LCD screen; and that wasn't the problem.
Please post in a Comment for additional questions,
Regards,
joecoolvette
[ With the model number I may be able to give you a link, to a free Service Manual, and perhaps pictorial guides too.
With them the above won't seem like so much info, it drags the brain down.
For example,
http://www.insidemylaptop.com/disassemble-hp-pavilion-dv7-notebook/
http://www.insidemylaptop.com/replace-cracked-screen-dell-inspiron-14z-laptop/
http://www.tim.id.au/blog/tims-laptop-service-manuals/
HP has most laptop Service Manuals listed on their HP Support website.
So does Dell.
http://www.irisvista.com/tech/
Posted on Jan 02, 2013
2 Suggested Answers
nate6556
  • 103 Answers
SOURCE: Acer Aspire One, blank screen
if you've only had it 5 months send it back to acer, there is a hardware problem with your screen, it sounds like something may have came unhooked, possibly if it was dropped? I'm not sure but they always give 1 year warranty on things like that
Posted on Jul 25, 2009
Sony vizio wont boot up
The most common reason a computer won't start can be a piece of hardware has failed or is causing a problem but that hardware isn't usually a hard drive, the part of your computer that stores all of your files. To fix such kinds of issue, you can take the following steps.1.create a bootable usb or cd ,there are kinds of software for you to complete this step, you can choose Fix Boot,EasyBootDisk or Windows Boot Genius. I suggest you to use Windows Boot Genius, it is easier and more effective.2.boot your computer from the created disk3.fix the issue after run the softwareBy the way, before any further steps you should make sure the power supply is good. Any hardware issues such as pc power and cable,motherboard corrupted should be troubleshooted.I don't suggest you to try the solution above until you are sure there is nothing to do with the hardware.
Jan 18, 2013 | Vizio Ca27-ao
Hp compaq computer is showing a red light and stop booting
source:http://windows-8-password-recovery.com/computer-wont-boot.html
Jan 09, 2013 | HP Compaq d530 SFF PC Desktop
Acer Aspire One D255e shows blancco hardware report on boot and locks up, what is the problem here?
Problem:Your HDD has been formatted using a tool called "Blancco Erasure" which creates detailed IT hardware report after the erase process.
Solution:boot into dos from any bootable cd\dvd (or connect this drive as a slave with other master booting drive and format using this command "Drive letter:\ fdisk /mbr "
Mohammed Abd ElAziz Youssuf
Sep 02, 2012 | Acer Aspire One D255E13438 Netbook
Ihave ASUS M2N68-AMSE2 nmotherboard- on starting up, my computer shows ASUS green screen for ages and nothing happens, I press reststart, motherboard boots up and starts windows
hardware related issue, check your bios settings to see if halt on errors in enabled, also disable
the ASUS splash screen, you should be able to see the initial boot error..
Feb 19, 2011 | ASUS M2N68-AM SE2 Motherboard
Asus Eee pc 900. Boots up but after booting only shows black screen. How do I fix this?
If you are only getting a black screen and you are sure it's booting (how do you know?), then the problem would be the incorrect video settings in Windows. In this case, you might try starting in safe mode and resetting the video adapter.
If you see stuff on the screen as the system boots but then it goes black, then it's definitely a Windows issue.
If you see nothing at all but hear the system starting, then it's a hardware issue involving the video card.
Aug 06, 2010 | ASUS Eee PC 900 Notebook
When I power up my laptop the screen does not show anything. It is just white screen no windows log or bios when the computer is booting. I can connect an external monitor to the laptop and the see that it...
You've got a loose connection between the laptop and the internal screen. Take the computer to a qualified technician, tell him/her the symptoms, especially the part about the external monitor working fine, and pay the technician to fix it.
Oct 27, 2009 | Acer Aspire 4315 Notebook
Screen won't turn on
when the computer boots does the screen light up? if it does the first thing you need to try is when you turn the computer on is to option boot. That is done by holding the option key while turning the computer on. after it boots you will see the the hard drive listed on the screen it will be a icon, if there you should be able to boot up. If the computer does not boot and your hard drive is still listed you most likely have a logic board aka mother board issue.
Jan 11, 2009 | Apple iBook G4 Mac Notebook
When I hit power button on computer, power light doesn't come on...and the fan kicks on, but nothing else happens. nothing shows up on monitor except the test screen with 3 colors...the computer doesn't...
THis sounds like a power supply issue.. I had a similar issue with mine. my fan would kick on for about 2 seconds then shut off.
Hope that helps
Ciza
Oct 29, 2008 | Gateway (4000274) Motherboard
No boot
Things to Check When No boot...
1. Have you connected all the power cable?
2. Do you see any display?(including the power lights glowing)
3. Does the screen show you any blue screen error message?
4. Do you hear any beep noises?
5. Have you tried to install any third party hardware or software?
6. What do you think could have caused the issue?
Mar 28, 2008 | Dell Dimension 4600 PC Desktop
PLEASE HELP ME! Panasonic firewire connection won't work!
In short, many people have firewire issues such as missing motherboard drivers, or dead firewire ports. You have to show it working on some machine before you know to try to fix your machine. Did you try Movie Maker?
Sep 06, 2005 | Panasonic AG-185 Camcorder
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
