Question about Apple 22" Cinema Display Monitor
Wall mount apple 20" cinema display (acrylic)
I ve been trying to find a wall mount for this display. any suggestions? it seems that the mounts for this product have been discontinued... your help will much appreciated!! happy new year!
mattozan
  • 555 Answers
SOURCE: Apple cinema display 23"
Is the power light flashing at all? The Apple Cinema Dispays have error light sequences that can help you diagnose your problem.
Posted on Mar 03, 2008
SOURCE: Apple Cinema Display 23" HD - Dust on inside of screen.
Well, I pretty much knew that the display would have to be disassembled to clean the dust out. I should have been more specific by asking if the display "could" be taken apart to clean it out, especially since the dust is in between the image and light source layers.
Posted on May 29, 2008
SOURCE: Apple 23" cinema display
thats supposed to mean theres a faulty powerbrick, however i have the same problem on mine and replacing that didn't solve it
Posted on Oct 31, 2008
SOURCE: Apple 23" Cinema HD Display went off
Hey - I just got done with 30 minutes of trying my cinema HD on my macbook pro and plugging and unplugging. When I plugged it into an extension cord in another socket the monitor started right up. I've had this configuration in my office for years with no problem...until today. Did mac send us a system upgrade that caused a problem with the monitor's power source???? Good luck!!!!
Posted on Jul 20, 2009
  • 35 Answers
SOURCE: Apple 20" display black screen
I've read that aftermarket DVI cable adapters don't work well with this set-up. You might try the Apple DVI to ADC adapter. It's expensive but I see them on eBay or craigslist from time to time at less than half the normal $99 cost.
Posted on Aug 17, 2009
Replace broken stand (acrylic portion)
Try clear epoxy glue. It will come in two tubes that you mix together. You will need to have a way to hold the parts in place until it reaches full strength ~ 24 hrs. Available at Harbor Freight online or HF stores.
Apr 15, 2014 | Apple Cinema Display 23" HD Monitor
Hello!
Please do and verify any fuse blownout in the inlet of the power from the wall, if it is not visible then maybe you open the the back cover and try to see any parts that has error or blown. you should replace it with genuine replacement parts. however it hard to do this by a novice tech, My suggestion is to bring the unit to the nearest service center maybe the unit got warranty service or else maybe its a cheap or resonable cost.
may this help!
best regards, melnavz
Mar 03, 2008 | Apple Cinema Display 23" HD Monitor
Remove mount
CINEMA DISPLAY VESA MOUNT ADAPTER KIT IS sold at Apple Store please do contact them for the Product.
Feb 10, 2013 | Apple Cinema HD Display30" Flat Panel...
Crescent rod installation into a acrylic walled shower/tub unit. instructions say differant hardware needed but not included,consult contractor or hardware store for installation.
You will need to seal any holes made in your acrylic walls inside your bath unit. When installing the brackets to the wall, try using a piece of rubber (pre-cut for a custom look) between the acrylic wall and the bracket mounting hardware. Be sure to seal everything with a clear latex caulk that is designed to resist mold.
May 08, 2010 | Crescent Rod The Rod - 5' Curved Shower...
Apple cinema display has interference
Check your DVI cable for breaks. If that's not the problem, then you'll need a new IP board. Not sure of the part number for this monitor, it's printed on the circuit board. It starts with 820-XXXX or 620-XXXX in some cases.
Nov 24, 2009 | Apple Cinema 20" LCD Monitor
Dim 20" Apple Cinema Display
Double check you power cord and try switching plugs.
sounds like its not getting enough power or a CCFL is going or is out and you need to get it serviced if thats the case.
Do not attempt to repair this your self Monitors usally have there own power supply built ind can store massive amounts of energy and will cause serious injury or death.
Jan 30, 2009 | Apple Cinema Display Flat Panel Monitor...
Aug 26, 2008 | Apple 20" Flat-Panel TFT LCD Cinema...
Jul 28, 2008 | Apple Cinema Display 23" HD Monitor
Open Questions:
Apple 22" Cinema Display Monitor Logo
67 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
