Question about Hoover Washing Machines
Hoover Nextra 1300 7.5+5kg HNWF 7137 stops working after approx 10 secs
After approx 10 secs the machine goes from the selected cycle to 'delay wash' and stops. The start arrow light and delay start light both flash for 11 times, then a pause, then flash again.
  • 1003 Answers
SOURCE: Hoover Hnwf 7148 washing machine
REPLACE POWER CONTROL MODULE
Posted on Feb 02, 2008
SOURCE: Hoover Nextra HNWF 3137 washer/dryer
I have the same problem exactly please send me the solution with confirmation of the exact part requested my machine is HOOVER HNL3137 1300rpm/7kg thanks
Posted on Jun 02, 2008
rylee_smith
  • 8619 Answers
SOURCE: Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 18, 2010
SOURCE: can anyone help my hoover washing machine modal
Hi, had same problem the filter was blocked again. It needs to be regurly cleaned out.
Posted on Jun 26, 2010
SOURCE: Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Posted on Aug 10, 2010
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Hoover Nextra HNWF 3135 door will not lock
1) test the switch door, you do not have error code.
see the video, and replace for defective switch, or loose wires or broken, or burn.
God bless you
Jun 28, 2012 | Hoover Nextra HNWF 3135 Front Load...
Water will not drain
Check the filter located behind the kick plate at bottom front of machine.
Thanks for using Fixya.
Feb 10, 2009 | Hoover Nextra 160 HNWF 3137 Front Load...
Hoover nextra energy saving washing machine
Click on Hoover model number above (below FIXYA) on this website & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you will hv your manual on line.
Rate me pl if helped.................
Feb 08, 2008 | Hoover Nextra 160 HNWF 3137 Front Load...
this is a condenser washer dryer so water should evaporate to condenser then empty!
Oct 31, 2007 | Hoover Nextra 160 HNWF 3137 Front Load...
Washing Machines Logo
97 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
