Question about Graco Spree 511 Holden Travel System Stroller
Removing an alternator from a vz commodore
I have loosened the alternator but when tried to slide it off, it hits the engine bay and i cant remove it? do i need to lift the engine?
    New Friend:
  • 3 Answers
Just Commodores is a great website.
http://forums.justcommodores.com.au/vz-holden-commodore-2004-2006/163904-how-do-i-get-my-alternator-out-my-vz-sv6.html
Posted on Apr 15, 2014
Check transmission trian on Vx commodore executive it had no fluid have filled it but keep getting that message is their a reset button
try this just commodores forum
on the VZ 2004-- 2006
Forum VZ Holden Commodore 2004 2006
I only know of engine service message
clearance using the mode buttons on a VT.VX
i hope you are a lucky person because
any commodore transmission man or auto
driven without fluid would have taken some internal damage
Jun 23, 2016 | Cars & Trucks
How to replace thermostat in 3.6 vz commodore 95 model
Not fimiliar with commodore engineering (im from the US, we dont have those!) but follow the upper radiator hose to where it connects to the engine, theres the thermostat. Remove everything thats in the way of removal, swap the thermostat then reassemble. Sorry if this is to vague to help, but for some people, this would be the only clue they need to just hop into it!
Nov 18, 2014 | Cars & Trucks
How to slide off the alternator from a vz commodore 2005
This website is great for problems and advice for all Commodores.
Just Commodores For All Your Holden Commodore Needs
Also have a look on YouTube for videos.
Nov 01, 2014 | Cars & Trucks
How to remove alternator on RX350
Follow the below steps to remove the alternator from RX 350.
1) Disconnect the negative battery lead from the car battery terminal and remove the engine cover to access the alternator and accessory drive belt.
2) Loosen the 14 mm bolt on the accessory drive belt tensioner pulley. Take the free hand and grasp the belt while pulling away from the tensioner pulley. This will release the tensioner pulley and allow the belt to be removed.
3) Disconnect the electrical plug connected to the alternator by prying the locking tab loose with the regular screwdriver.
4) Remove the 14 mm through bolt from the alternator using the 14 mm wrench or socket. Support the alternator with the free hand until bolt is removed completely. Slide alternator out of the engine bay.
If you do need to replace your alternator this site looks like it has cheap prices, free shipping and great reviews http://www.buyautoparts.com/autoparts/Lexus/RX350/alternator.html
Jun 25, 2013 | Cars & Trucks
Who nos how to chang altinator on vz comador
Go to Justcommodores.com.au and click on "FORUM" which is a forum covering all models of Commodore including the VZ. There is a section for the VZ model and there is information on that site on changing the alternator on a VZ.
Dec 28, 2012 | Cars & Trucks
Please advise me that how to change vz commodre inhibitor switch ?
Have your starter checked. Mine did the same thing. In the beginning it was slow cranking over. Then it just stopped turning over all together. Is it a stick or automatic? If stick get a push start from friends if it runs fine then you know it's the starter. Good luck hope this helped.
Oct 27, 2012 | Cars & Trucks
Where is alternator located in the engine compartment?
Are these guys SERIOUS??
The alternator is accessed from UNDER the vehicle LEFT SIDE facing the engine bay.
REMOVAL & INSTALLATION
1. Disconnect the negative battery cable.
2. Loosen, but do not remove the alternator adjusting nut.
3. Turn the front wheels completely to the right, then raise and safely support the vehicle.
4. Unfasten the retainers, then remove the plastic lower splash shield.
5. Unfasten the alternator field circuit wiring connector. You must squeeze the locking tab to release it.
6. Remove the B+ terminal nut and wire.
7. Loosen the alternator pivot bolt, but do not remove it.
8. Remove the alternator drive belt. The alternator spill shield does not have to be removed.
9. If necessary, remove the bottom pivot bolt and anti-rotation tab.
10. Unfasten the three mounting pivot bracket bolts, then remove the pivot bolt and bracket.
11. Holding the alternator in one hand, remove the adjustment nut then slide the alternator off the T-bolt. The T-bolt does not have to be removed. Lower the alternator and remove through the wheel well.
12. You may need to use a C-clamp to drive the sleeve into the mounting ear for installation clearance.
13. Position the alternator in the vehicle, sliding it onto the T-bolt. Install the adjusting nut.
14. Install the bracket and pivot bolt, then install the three mounting pivot bracket bolts. Tighten the bolts to 40 ft. lbs. (54 Nm).
15. If removed, install the anti-rotation tab and bottom pivot bolt hand-tight.
16. Install the alternator drive belt.
17. Tighten the alternator pivot bolt to 40 ft. lbs. (54 Nm).
18. Install the B+ terminal wire and nut. Tighten the nut to 75 inch lbs. (9 Nm).
19. Attach the alternator field circuit wiring connector, making sure the locking tabs are engaged.
20. Install the splash shield, then carefully lower the vehicle.
21. Tighten the adjusting nut.
22. Connect the negative battery cable. Adjust the alternator belt.
Thanks!!
Feb 07, 2011 | 1998 Dodge Neon
How do i change the alternator on a 1998 mitsubishi montero sport
Disconnect the battery negative cable.
Remove 12mm (3) and 14mm (4) bolts holding skidplate on and remove skidplate
Loosen the 14mm nut on the tensioner, then unscrew the tensioner adjuster bolt until the belt can slide off.
Unplug the alternator electrical connector.
Unbolt the alternator cable lug (12mm or 13mm depending on alternator manufacturer)
Remove lower 12mm bolt
Remove upper 14mm pivot bolt
Use large screwdriver to pry alternator off bracket, it pinches on when the pivot bolt is tightened.
Drop alternator out bottom of engine bay; helps to unbolt or bend transmission cooler lines out of the way.
Feb 09, 2010 | 1998 Mitsubishi Montero Sport
I need to find out how to remove the alternator from my 2002 Kia Spectra
The steps to replace an alternator are:
  1. Do the following through the passenger side of the engine bay of course with the hood up.
  2. First and most important is to disconnect the negative connection to the battery (driver side).
  3. Using a 12mm socket loosen the tension adjusting screw and bracket screw. Using a 10mm socket or open end remove wirings. Pinched other connector to remove.
  4. Using 14mm socket with 3/8 drive ratchet remove the big bolt on the lower side of the alternator.
  5. You might need some help from a pipe for extra leverage.
  6. Remove all parts that will hinder the removal of the alternator.For example the charcoal cannister on the firewall just slide up.
  7. Ease the alternator through the opening by turning the alternator untile it can pass through the opening.
Sep 19, 2009 | 2002 Kia Spectra
Holden commodore vz acclaim my06 remove front headrests
push in the button on the left headrest post and use a small piece of coathanger wire and do the same to the other headrest post. There is a small hole in the side of the plastic. Now pull up on headrest whilst doing this and it should come out.
Jul 08, 2009 | Baby Gear
Graco Spree 511 Holden Travel System Stroller Logo
341 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
