Question about Dell Inspiron 630M Notebook
No audio devices are installed under recording tab
Running Windows 7 OS
  • Sam Kim Jan 02, 2013
    Thanks Joshua...I already downloaded the drivers for my computer and that did not resolve the issue. I have read numerous responses re: this issue but I have not found an answer yet. I will continue to research. Thanks again
    New Friend:
    Problem Solver:
  • 14 Answers
Insp 630M is designed to work with winxp, win7 will automatically take all the drivers if its not taking try installing manually the audio drivers.
Posted on Sep 27, 2013
3 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: is it possible to install
Yes you can have a dual boot operating system. For instructions on setting up this system go to this WEB site.
http://www.sevenforums.com/tutorials/8057-dual-boot-installation-windows-7-xp.html
Posted on Aug 12, 2011
SOURCE: There is no stereo mix on the recording tab on the audio devices
most audio cards in dell inspiron are mono not stereo unless you have a super duper upgrade do you??
Posted on May 22, 2012
My pc audio not mute working
Click start control panel on the left select Hardware and Sound then select manage audio devices then recording you should see a Microphone right click select enable Windows 7
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a Microphone right click select configure speech recognition then You will see earphones with a speaker among a list set up a microphone headset with Microphone then next and next again you should see your earphones with microphone being configured Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list Make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab Make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it b> Windows 7 right click on the speaker icon in the taskbar select either playback or recording devices you should see your microphone listed under the recording tab right click on it select properties at the bottom select use this device enable
Feb 18, 2013 | HP Computers & Internet
Laptop microphone problem
Feb 14, 2013 | Computers & Internet
Feb 13, 2013 | Toshiba Satellite L355-S7902 Notebook
Mic is not working.
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a Microphone right click select configure speech recognition then You will see earphones with a speaker among a list set up a microphone headset with Microphone then next and next again you should see your earphones with microphone being configured Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list Make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab Make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it b> Windows 7 right click on the speaker icon in the taskbar select either playback or recording devices you should see your microphone listed under the recording tab right click on it select properties at the bottom select use this device enable Hope this helps.
Jan 11, 2013 | Computers & Internet
Xitel Inport De luxe with window 7
The directions for using the Xitel Inport Deluxe under Win7 are the same as those for using the device with Vista. The drivers are built into the OS. You will need to set the audio input to the Xitel device. For most installs of Windows 7 (Aero capable), with the Inport Deluxe plugged into a USB port on the computer, click Start > Control Panel > Hardware and Sound. Under the Sound listing, click on Manage Audio Devices. In the Recording tab, right click on Microphone Input and select Disable. Right click on the Line INport and select Enable. Right click again on Line INPort and make this the default device. Click on the Playback tab and right click on Speakers INport and select Disable.
If Aero isn't available, it's Control Panel > Sound.
You can use any recording software that runs under your version of Windows 7. The LP Recorder software manual starts on page 8 of the Xitel Inport Deluxe manual. If you do not have the original disc, LP Recorder is available here: http://www.cfbsoftware.com/lprecorder/lprecorder.aspx . (Audacity, http://audacity.sourceforge.net/ , works much the same way as LP Recorder. However the drop down menus for the source and output are available from the main program with the default toolbars enabled.)
I hope this helps.
Sep 26, 2012 | Televison & Video
I can't find the drivers for my Olympus Digital voice recorder VN-2000PC. What can I do? I can't tranfers my audio files to my PC.
Do you need the software/drivers for the VN-2000PC or the VN-2100PC? The software for the VN-2100PC is available here: http://www.olympusamerica.com/cpg_section/cpg_support_downloads.asp?id=1270 . Select your OS and you'll find the software.
The VN-2000PC doesn't connect to the computer via a USB port. To transfer your files to a computer, connect the earphone jack to the line In (blue) jack of the computer with a 3.5mm to 3.5 mm audio patch cable. Use a program like Audacity to record the audio track during playback. Make sure to set the Audio input to Line In. (In Windows 7, click Start > Control Panel > Hardware and Sound. Under Sound, click Manage Audio Devices. Then select the Recording tab and set the input device.) Then set the recording device in the software as well. Click the Record button in the software and then start the play back on your VN-2000PC. You should see a flat line for a bit then see a wave form start. If the line stays flat, you haven't set the Line In device properly.
I hope this helps.
Sep 01, 2012 | Olympus VN-2100PC Digital Voice Recorder
Getting lidl silvercrest turntable / audacity to transfer records to computer
Assuming you've installed the Audacity software, first check your recording device. If you use Windows, first check the Audio Control Panel. For Windows 7, click Start > Control Panel > Hardware and Sound. Under Sound, click on the Manage Audio Devices link. In that window, click on the Recording tab. Select the USB option and make it the active device.
In Audacity, you may also need to make sure that this is the recording device that is active. That should be the third drop down from the left in the Device Toolbar. (If it isn't visible, click View > Toolbars and check it.) The Device Toolbar is right above the recording trace section in my version of Audacity.
Now click Record (the red circle) and start your turntable. Do you see a change in the trace? You should see a flat line for up to 10 seconds and then see this change to a set of high and low values.
If you don't get this, check if your USB ports are working. If you use a USB hub, try a direct connection. Check the device manager under Universal Serial Bus for a triangle with a red x or a yellow triangle. Try updating the driver by right clicking on the device. Also check Windows Update (for an optional update) or your computer manufacturer site for a new driver.
Unfortunately with the USB, you can't hear the recording as it is made. Do a short recording and then stop it. Then play back the selection. Adjust the input volume level lower if your trace is hitting the top of the box. This is clipping and your recording won't include the full signal from your record.
I've used Audacity for recording cassettes through the line in port. You can do this with some turntables if you add a pre-amplifier and use RCA to 3.5 mm adapter. Connect to the line in on the back of the desktop (blue).
If you could not install Audacity, go to http://audacity.sourceforge.net/ to get a version that works on your computer's OS.
I hope this helps.
Jul 05, 2012 | Audio Players & Recorders
Microphone Not Working!
If this is a microphone that connects to the 3.5 mm microphone jack, check that your microphone is connected to the Mic port (pink on the rear of a desktop). Make sure that the plug is fully seated. If you are using a front microphone jack on a desktop, try using the rear port (or vice versa). Next, if you have Windows, check that the audio input is set to Microphone, instead of Line In. (For Windows 7, this would be Start > Control Panel > Hardware and Sound > Manage Audio Devices (under Sound) and the recording tab.) Microphone should be your default device.
Next try uninstalling the audio driver and letting Windows reinstall the driver. Use the Device Manager (under Devices and Printers in the Hardware and Sound Control Panel). Expand the section labeled Sound, video and game controllers. Then right click on the Audio driver. Click on Uninstall then reboot the computer after the driver is removed. The correct driver should be reinstalled. (I believe that you do not have a separate driver for the microphone under Windows but you should make certain of that.) Check for driver updates as well. The Windows Update may list these as Optional updates.
If you have a USB microphone, try a different port. Also check for drivers from the manufacturer.
If you have an Apple or Unix OS, check for similar issues with the connection or drivers.
I hope this helps.
(who had a similar problem with Audacity recording on the line in port last month; I fixed the problem by uninstalling the audio driver and then reinstalling it. Then changing the Recording Source to Line In finished the fix. The driver got changed by a computer tune-up utility (registry cleaner).)
Apr 13, 2012 | Labtec Audio Players & Recorders
Can't hear playback. Windows Vista - Playback device says usb Audio Codec
here is what ION is telling people (short version) this is for vista or win7
1. Visit www.ionaudio.com/ezvc to download the latest EZ Converter software.
2. install new software if needed,
3. connect ION Audio USB. make sure its ON (if it has a switch)
Setup Procedure
1. Start then Control Panel.
2. double-click Hardware and Sound.
3. double-click Sound.
4. At top select Playback tab. choose the audio output device.
Don’t chose “speakers-usb audio codec” (that’s your ION) don’t chose modem
5. click Set Default.
6. select Recording tab at top of Sound Control Panel. choose "Microphone – USB Audio Codec" as the default device. (that’s the ION)
7. Click Set Default.
8. click Properties. select Advanced tab
9. set the Default Format setting to 2-channel, 16 bit 44100 Hz (CD Quality).
10. Un-check the two boxes under Exclusive Mode. Click Apply
11. select Levels tab from the top of the Sound Control Panel.
12. Set the level slider to 4. Click Apply, click OK to close the window.
Have everything set up and running, if you have to call this number for help.
401-658-3743 ext. 1405
Jun 25, 2010 | ION Audio iTTUSB Turntable
To play my vietcong game i have to disable sound otherwise it crashs
I had the same problem and solved it by selecting "Disable front panel jack detection" in the Realtek HD Audio Manager "Connector Settings" dialogue box.
Running Windows 7 Ultimate 64-bit on an ASUS P6X58D motherboard w/ integrated Realtek audio chip.
Aug 02, 2009 | Jack Of All Games Vietcong for Windows
Dell Inspiron 630M Notebook Logo
59 people viewed this question
Alun Cox
