Question about JVC HR-J692U S-VHS VCR
No power When I plug the vcr to a power outlet, it does not turn on. There is no noise, no lights turn on; it's completely dead. I opened it to see if I could see something burnt, but everything looked fine. I closed it again, because I just could not find any problem with it. I had it stored and hadn't used it in almost a year, and now when I tried plugging it, it does not work.
    Novelist:
    Champion:
  • 254 Answers
This likely indicates a dead power supply, or a blown fuse in the power supply, and if the fuse is blown, this usually indicates a serious problem with it. If you have a voltmeter and some tech savvy, you could check for proper voltages produced by the power supply circuit. A normal power supply will produce: +5 volts, +12 to 14 volts, & a -40 volts or so. The latter is to power the LCD display, if present. If these voltages are missing, or way off, then you have a defective component in the power supply circuitry. Incorrect voltage values are usually point to a defective electrolytic capacitor. Replacement caps. can be found at Digi-key Corp.-- their Panasonic FC series is what you will want. Or, Mouser Electronics has suitable. If there is no voltage at all, then you may have a blown switching transistor, and perhaps a few other small parts bad. Tech savvy is a requirement here, as these kind of failures are frequently caused by a problem elsewhere, and a repeat poof is almost certain unless the other problem is found & repaired. Otherwise, if this is a low dollar VCR like most of the last 10+ years, repairs might not be economical.
Posted on Jul 03, 2007
SOURCE:
Wont turn on
It is always good to give some information about the case with your question, like if there was a power out, strange noise from the computer or anything that might suggest or assist helping you.
try this:
1. Unplug the power cord
2. Press the power button several times
3. Plug the computer back in to the power outlet and try again.
If it fails, try to open the side of the computer,
Check to see if when connected to the power outlet, you can see a led on the Motherboard turning on.
It might be that your PSU is dead.
May 18, 2014 | Dell Vostro 420 Desktop Computer
My sharp LC-46SV50U wont turn on
get the service manual and then open it up and do a voltage check on the 5v standby.
if it's not showing anything, then you need to hunt down if it's the ic, cap, or diode or a combination thereof.
Nov 24, 2013 | Sharp LC46SV50U - Lc46sv50u 46in Lcd Ccfl...
Fisher & paykel washing machine has no power
it was probably the pump shorting / overheating, and running it has caused it to blow the fuse in the motor controller.
Nov 08, 2013 | Fisher Paykel EcoSmart GWL15
XPS M1330 is dead, no lights and complete silence.
can you put a volt meter across the ends of the power - where it plugs into the laptop
should have 18-22 volts same as written on the PSU
I think the pSU has blowen
Nov 11, 2009 | Dell XPS M1330 Notebook
Zvonko jelusic from belgrade
The print carriage is stuck.
Solution
  1. Open the top access door on the printer.
  2. Remove the print cartridges.
  3. Close the print cartridge flaps after removing the print cartridges.
  4. Turn the printer off and then on again.
  5. Replace the print cartridges.
  6. Close the top access door.
If the resume light continues to blink after the print cartridges are released,
OR
the print carriage is stuck or makes a grinding noise, follow these steps.
Solution
  1. Lift the top cover to the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cord from the back of the printer when the grinding noise starts. Unplug the power cord from the wall outlet.
  4. Move the print carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
  5. Take out the print cartridges and close the top cover.
  6. Plug the power cord into the wall outlet. Plug the power cord into the back of the printer.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover
Solution
  1. Open the top cover.
  2. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet. Wait a minute or so.
  3. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 22, 2008 | HP DeskJet 5550 InkJet Printer
Samsung v5600
be sure that have a power in your outlet. if fuse is good try to check the diodes on the power supply, some diodes may be open.
Jul 01, 2008 | Samsung DVD-V4600 DVD Player/VCR
Problem
If the AC power source (outlet) is ok and the line cord and fuse are ok but the unit is completely dead, you may have a problem with the internal switching power supply.
Locate the switching power supply and see if there is a fuse on its circuit board.
Completely dead units are typically caused by a failure in the power supply section.
Please let me know if I can be of further assistance to you.
- Jim
Mar 06, 2008 | Sony SLV-D360P DVD Player/VCR
No power
I assume you unplugged the unit for several minutes and tried plugging it back in to reset it. Is the outlet ok? Did you try plugging something else into the same outlet and it worked?
If the cord is ok and the fuse isn't blown and the VCR is completely dead, I would say that you have a problem in the power supply section. This could be a bad transformer, rectifier or regulator module. Unfortunately you'll need to take it to be serviced.
- Jim
Feb 11, 2008 | GE VG4040 VCR
No Power
you need to open up the cover to check the fuse ,normally can found inside the PCB near to the AC pwr cable .hope it help.
Aug 10, 2007 | Hitachi VTFX624A VHS VCR
JVC HR-J692U S-VHS VCR Logo
267 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
