Question about Five Star TPN535-BGSW Dual Fuel (Electric and Gas) Kitchen Range
Five star gas oven won't unlock
Oven wouldn't heat up. I put it into "Clean" to see if that would work and it did. I stopped the clean, and the cellenoid unlock button now doesn't buzz, i can't ulock the door, and it still doesn't heat up.
5 Suggested Answers
bigg t
  • 640 Answers
SOURCE: Five Star Dual Fuel Range Issue
make sure the gas pressure is correct.get a small torch and heat up the flame switch (it sits above the glow bar)and see if the burner lights.
Posted on Aug 26, 2007
farfield
  • 462 Answers
SOURCE: Oven won't unlock after cleaning
You could try unplugging or turning off the breaker and try opening the door. If it still refuses to open a tech will have to be there to decide what to try. Either the lock is out or the board is still sending a signal to stay locked. that's why I thought unplugging it might work.
Posted on Mar 23, 2009
TheMobilian
  • 8220 Answers
SOURCE: My Five Star Oven will not ignite and has NEVER
You can remove the oven knob and inside the shaft is a small screw to tweak the temp. Ain't got no idear what type system you have so check these PAGES out.
Posted on Oct 30, 2009
KevinWhite
  • 1902 Answers
SOURCE: I have a Five Star
Hello & Welcome to FixYa
You are correct that the problem is with the valve that needs replacement, unfortunately there is no simple fix. Please get back to me if you have any other questions.
Kevin
Posted on Jun 19, 2011
Kenmore Electric Oven won't bake after using self-clean!
The oven temperature is regulated by a temperature sensor when placed in self clean the sensor is removed from the circuit and full power is applied to both the bake and broil elements causing an the temperature to exceed in some some models up to 1,000 F. I would recommend against using self clean for the simple fact that no oven cavity to this date has been designed to withstand that high of a temperature and therefore excess heat is passed upward resulting in damaged lock mechanisms, control boards, and other electronic components. The most common complaint I have had with built in ovens besides the element burning out, is the oven door locked shut. When I get to the house and I ask to tell me a little bit of whats going on the story always starts " well, I was using the self clean option" or some variation of the sort. Now comes the bad news, you fall under the catagory of damaged electronics. The control has been damaged and I wouldn't doubt if the sensor as well.The part number for the control is WB50T10056 and cost about 108.20. The sensor part number is going to be WB21X5301 and cost about 94.00 On the second part I would call my local parts distributor and as if there is a sub part for it and self yourself about 50 bucks or so. Sorry, and good luck.
Apr 28, 2012 | Kenmore Ovens
Ge gas oven ran self clean door won't unlock door locked flashing lock motor running continuously
if your motor is running continuously, the door is locking and unlocking. catch it when unlocked, and unplug the range. then disconnect the power wires from the lock motor. this will allow you to use the oven while you get a new lock assembly and replace the one you have. should be fine after that.
Feb 04, 2012 | GE 25 in. GSC3200GWW Free-standing...
We have a Magic Chef gas oven (model # CPL1100BDW) without electronic ignition. The oven isn't working. The oven pilot is out, can't get it to light, and the oven will not light - (obviously)....
If the pilot is clean and still won't light then the problem is with the safety valve that won't open and so needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 14, 2011 | Magic Chef Ovens
Model: JDS8850AAS -- Oven won't preheat above 150
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
Hope this helps
Gene
Aug 02, 2011 | Jenn-Air Ovens
We have a Five Star gas oven and attempted to use the self cleaning process to clean the oven. We started yesterday and it appeared to complete the cleaning cycle. This morning, however, the locking...
There are two reasons for the lock to remain locked. One: the thermostat/wiring failed. This results in the oven's control still believing that the oven is too hot (over 450 degrees) and thus will not unlock. The other possible problem is that the unlock mechanism failed.
You can try to unlock the oven manually. (For some ranges, you can do this from the back of the range.) Please add a comment with the model of the oven/range for more assistance.
I hope this gets you started on solving the problem.
Jul 06, 2017 | Five Star 48 in. TTN045 Gas Cooktop
Right oven won't light. it has power...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 25, 2010 | Five Star FiveStar 48'' All Gas, White...
MY OVEN WAS WORKING FINE THIS MORNING THEN WENT
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 09, 2010 | Tecnik TKC1285 Dual Fuel (Electric and...
Five Star TPN535-BGSW Dual Fuel (Electric and Gas) Kitchen Range Logo
78 people viewed this question
Top Five Star Kitchen Ranges Experts
Dan Webster
Dan Webster
ray gallant
Tom Chichester
Are you a Five Star Kitchen Range Expert? Answer questions, earn points and help others
