Whirlpool AWOE 9559 S, programme dial problem, no power activation on the first 3 programmes or their opposites on the dial, no error code or fault light indicated. I this a dial fault or is it someth
  • 22 Answers
Sounds like you may have dry joints on the circuit board, you will need to contact washing machine repairs, not something you can fix yourself
Posted on Jan 03, 2013
SOURCE: programme dial again
yes thats your problem,the reason it wont unscrew is because of things caught inside ie coins gunk you will have to take out machine turn on side,there are two sometime four screws at front of machine where black dail is remove these,when machine is on its side you can acess pump from underneath,there is a black rubber hose which goes from drum to pump which is held on with a circlip remove this at pump end you will need a vicegrip,remove all gunk coins ect, refit all back to machine ,,problem solved......the reason dail was turning was because it was looking for progam to release water which it couldnt because of blockage,after tou unblock you will find that black srew on cover on front can be removed(always better to check for blockages every few weeks hopes this helps
Posted on May 23, 2008
SOURCE: dhe fault code
condenser blocked
Posted on Dec 16, 2007
  • 1462 Answers
SOURCE: Indesit WIDL 102
almost certainly a new module and eprom. these modules have given a lot of problems.
not really worth doing
Posted on Jun 25, 2008
  • 5 Answers
SOURCE: Hoover SE230 Programmer rotating
Hi there, my washing machine was doing the same as the one you have mentioned.
I bought a replacement timer from the website highlighted below. It has done the trick and every programme works properly now.
A competent DIY person can change one of these easily and will take about 30 minutes to do.
The new part looks slightly different but it carries the same part number.
The price £24.99 + £4.98 delivery.
http://www.4hoover.co.uk/cgi-bin/product.pl?PID=723224&section=46246&brand=&model=SE230&path=45786,46246
Posted on Nov 08, 2008
SOURCE: whirlpool awm 8125/3 fault code FH
Probably too late, but here it goes:
FH means some cicle is taking too long time.
Replace the inlet electrical valve. It probably wont open enough and the water flow is not enough to fill to level in time. This should cost you 10€ and is easily done by anyone.
Just remove the top of the machine (two bolts on the rear and slide to the back), disconnect the valve (electrical and water input and output), push the lockers and twist the valve free.
Posted on Jun 02, 2009
How to reset zanussi jetsystem programme function board with error E40
E40 is a door lock fault code, you need to replace the door lock,
you cannot reset the fault code, this happens automatically when the fault is rectified. nice easy job though.
Sep 30, 2016 | Zanussi Washing Machines
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
Err code displayed and fails start
Turn the programme selector dial to the required programme.
The selector dial can be turned either clockwise
or counter-clockwise. The green pilot light of the button
9 starts flashing: the appliance is now switched on.
If you turn the programme selector dial to another programme
when the appliance is working, the red pilot light
of the button 9 will flash 3 times and the message Err is displayed to indicate a wrong selection.
The appliance will not perform the new selected programme.
• To switch the appliance off, turn the programme selector
dial to the position .
To cancel or change a running programme, switch the
appliance off by turning the programme selector dial to the
position
. Select the new programme by turning the selector
to the desired programme. Start the new programme
by pressing the button 9 again. The water in the tub will be
not emptied out.
Dado
Sep 25, 2014 | Zanussi Washing Machines
Errore f02 modello awoe 8104
open the bottom tray door on front panel 3 screws on bottom front.
clean out the trap
May 10, 2014 | Whirlpool Washing Machines
How to cancel programme once it is activated on Miele W502
Turn the machine off.
Turn dial to finish.
Turn power back on.
Select drain and start.
When drained you can begin again.
Nov 17, 2012 | Miele W4840 Front Load Washer
Error code E20
Turn the dial to off.
Press and hold the start pause and nearest option button to it.
Whilst holding them, turn the dial one notch clockwise.
The machine will beep or flash, let go of the buttons.
Now turn the dial slowly through each position, stop and position 10 (9 clicks after letting go of the buttons) and note the error code displayed.
Continue turning the dial until you get to off.
Now turn to any programme, then, turn to off again.
Finally, turn to a programme and try the machine.
(It is very important that you turn to Off, a programme and then Off again).
Let me have the error code you retrieved if the appliance still doesn't work.
Oct 14, 2012 | Electrolux Washing Machines
My Miele 1374 washing machine just had a fehler f63 error. What does this mean and is it fixable?
heres your problem..
3.33 Fault code F63, water path control unit In normal operation mode the display shows Technical fault. The Check inlet LED flashes rapidly. The programme is interrupted. The drain pump is activated for 120 s. Cause Water path control system faulty. The power-programme module (ELP) cannot register a valid position of the water path control unit within approx. 80 s of it being switched on.
Note: Water intake monitoring is not active if a valid position of the water path control unit cannot be registered.
Remedy Check the water path control system. tool1.gif?leaf=true Check the water path control system circuit for an open or short circuit, and correct insulation.
Jun 05, 2011 | Miele W 4800 Front Load Washer
The digital display jumps programmes wont empty or spin
Take the toe kick off of the machine. Reach in and up to the right. There is a "manual" which covers error codes and possible remedies but not much more. Hope your "manual" is still there.
G.
Apr 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code 07 on my Aqualtis AQXXF
Might be a bit complex but this is your problem and solution
REMEMBER TURN THE POWER OFF
F07: Heater relay stuck or element open circuit
This fault is only signalled when pressure switch is in empty position.
Check the efficiency of edge connector J3 on module.
Check wiring to heater and continuity of element (25 ohms approximately).
Check the efficiency of pressure switch connections and correct operation of pressure switch,
and the pressure chamber is not blocked with sludge.
Remove edge connector J3 and check wiring and contacts at positions 2, 3 and 4 on J3.
If all above OK replace pressure switch, module or eeprom as required.
Jun 10, 2009 | Washing Machines
Washing time & quality
Look for wash cycles in your users'manual. It is best the read the manual well before operation.
Apr 05, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Washing Machines Logo
447 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
