Question about Dryers
Estate by Whirpool EED4300VQ0... my husband turned the dryer on (not to an actual setting but just into the gray area) and the dial stayed there for two hours without moving. Now the dryer will not turn on at all. We've tried flipping the breaker, unplugging and plugging it back in... we know nothing about dryers and I need some help before my husband decides he's a handy man!
  • 61 Answers
Sounds like you may have burned out the thermal fuse this is an easy repair unplug dryer remove back cover there is a small oblong fuse with two blue wires on in replase that and you should be fine.
Posted on Jan 21, 2009
It heats up but doesnt stop after the clothes are dry
IT is the timer. If electronic needs to replace the board. If dial type, needs the timer
Sep 15, 2014 | Dryers
What is this feature-"Wringle Prevent"
What the wrikle prevent does is after cycle is done if you dont go take clothing out right away is will tumble the drum without heat for 30 seconds every 10 minutes till the door is opened so the clothing doesnt sit there and wrinkle but gets tossed around lightly so wrinkles dont set in.
Gene
Aug 08, 2011 | Estate TEDS840JQ Electric Dryer
Estate TGDS680EQ3 gas dryer blows cold
The timer is stripped inside and needs to be replaced. The cogged teeth are made of plastic and a tooth or two has broken off keeping the timer from moving while running
Jul 16, 2010 | Estate TGDS680EQ Dryer
CANT FIND MODEL OR SERIAL NUMBER ON DRYER
There should be a nameplate along the door opening. This is normally where Whirpool puts their information. Just open the door and look along the door or door frame opening. The nameplate data can also be located along the back of the operator console on some models. Let me know if you still can't find it. I hope this helps.
Nov 11, 2008 | Estate TEDX640JQ Electric Dryer
My Whirpool Estate dryer does not heat.
A tester... read the link I found... It will help you most....
hope this helps...
Aug 19, 2008 | Dryers
My whirlpool estate dryer tub will not rotate
which pulley came off the one on the motor, or the Idler wheel that keeps tension on the belt. You probably will need a belt
May 26, 2008 | Estate TGDS840JQ Gas Dryer
Estate Dryer Model TEDS680EQ1
check the thermostats and see if your belt is still there if not put a new belt in
Mar 25, 2008 | Estate TEDS740JQ Electric Dryer
Dryer will not start
Could be a defective starter button, door switch, and/or timer.
Oct 19, 2007 | Dryers
Dryers Logo
137 people viewed this question
Top Dryers Experts
