Acer TravelMate 8210-6597 Notebook Logo
Peter Hlozanek Posted on Jun 25, 2007
How to open laptop?
Hi, i am looking for some kind of service manual for my laptop (trvalemate 8210) as it is overheating. I can see small silver block flying around. It seems to be a cooler for my graphics card. Anyone can help with this? Just need to know how to open it. I am able to unscrew all screws but i am not able to open it and i dont want to break it :) Thanks Pete
  • Anonymous Feb 27, 2008
    My laptop (trvalemate 8210) as it is overheating. I can see small
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jun 26, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
2637
Points
6
Dear Pete Icame to understand that your laptop is overheating. Dust on cooling fan may be one of the cause. You can try to open the laptop and clean the cooling fan . I am sending you some url which will help you to open the laptop. http://repair4laptop.org/notebook.html http://www.rigacci.org/comp/312T/disassemble/ Ty this . Kshitij
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
8910
Points
7
There is usually a screw or two inside the memory access panel, hard drive access panel and/or under the battery. Make sure you have checked/removed all of these. Does it appear to be loose for the most part? Even once the screws are removed there may be interlocking clips along the edges the hold the housing together. you can test one spot with a small flat screwdriver to see if it "pops" apart. Here is a website to find service manuals/info as well: http://www.eserviceinfo.com Good Luck
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 29, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
253
Points
The screws are sitting to hard. cant be opened
Anonymous
Level 1:
  • Posted on Feb 27, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
253
Points
My laptop (trvalemate 8210) as it is overheating. I can see small silver block flying around. It seems to be a cooler for my graphics card. Anyone can help with this?
2answers
My hp laptop is shutting downing while I m starting it with blue colour
hello , and greetings
what LT, what is the model, there are 1000s made from 1984 to now.
what OS, what operation system, ? xp, vista,w7,8/,or 10.?
in most cases blue means windows died.
black is different.
here are some causes, i can list 20
but will do a few, what we do is tests to avoid guessing 20+times .
  1. overheating, ever clean the vents and fan port so it stops that?
  2. memory bad. (RAM its called or DDR)
  3. someone change the OS and forgot the new OS drivers so now the video drivers are wrong and it crashes.
  4. Windows (X) is cracking and is corrupted.
  5. Bad HDD causes 4 above gut is TRUE casue.
  6. take that battery out yet, the big one, does it run ok now?
  7. and lots of other reasons, (huge list)
no blue screen photos posted in windows 10 there are over 50
blue screens now, each with different words... all matter.
ever seen this. this is your service tag
model on mine is 8540w
the product p/n is SK xxxxxxx
this tells the helper what you own.,
3answers
How do you replace the keyboard?
A step by step instruction is included in this service manual.
Service Manual
2answers
Overheating
clean your computer of dust using a fine air blower from a compressor making sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
hope this helps
2helpful
Drive shaft for rival 8210
You can check here...
http://www.rivalproducts.com/category.aspx?cid=1124
Or call Rival directly...1 866 321 9509
Here is a tip also, that may help you...
Ice Cream Maker Parts, Instruction Manuals and Recipes
http://www.fixya.com/support/r5322664-ice_cream_maker_parts_instruction
heatman101
My Equium A200-1V0 fan stopped working
The User's Guide is available on this page on the Toshiba website, under the User's Manual tab.
I have also compiled a tip for dealing with overheating issues on Laptops as that is a common issue.
You may please refer to this link for reviewing the same.
2answers
Acer Travelmate 8210 touchpad problem
Have you ran any spyware scans or antivirus scans? Check my (site) for this software. The Adaware 2007 is 2008 Link not 2007. Check the words files at the bottom of the page. I hope this helps. Spyware can do crazy things.
2answers
Service manual Ashton-Digital Excelente E515 A907 laptop
you could start by looking here.
www.laptoprepairparts.com/html/ashton.htm
these people are very useful in supplying spares and manuals, you may have to e-mail them.
Mike @ compurepair.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
