Question about Toshiba E05A100PBU3XS Canvio 1TB USB 3.0 Portable - Black/Silver USB 2.0 Hard Drive
Format Toshiba - Canvio Basics 750GB External USB 3.0 for Mac
2008 Mac Book Mac OS X 10.6.8
  • 50 Answers
Salam,
It depends on which machine(s) you want to use your hard drive for! If it should works on PCs (Windows and Linux) you have to format it in exFAT but if will use it only on MAC, it would be better if you use hfs+ (AKA: Mac OS extended journaled - not case sensitive).
And to do dat you need to open Disk Utility (type it in spotlight (use small magnifying glass icon in upper right corner of screen)). In Disk Utility's window, select your External Hard Drive itself (not its partition), go to Partition tab and change its format to anything you want, then click on apply button and wait for progress to be down.
If you want to use hfs+, you may need to chang partition table format to "GUID", and for exFat it needs to be "Master Boot Record"; to change that, use options button down in the same tab that I mentioned above.
PS: No need to say that formatting a drive will erase all data from it, so you need to copy them somewhere else before that.
Posted on Mar 25, 2016
  • 69 Answers
SOURCE: Toshiba 500 GB External Hard drive cant be detected by windows xp
yes you could simply format the harddrive in Fat32 using your macos that would be the best solution but don`t forget to backup your data by copy pasting the files on your mac or something else and after that to move them on the external hdd again to be available on the windows machine
Posted on Mar 11, 2010
Testimonial: "It worked... I never thought it could be that easy... Thanks a lot!!!"
SOURCE: I pluged my Toshiba Canvio Plus 750gb External HD
Download and Install SwissKnife!
(Unzip the file you just downloaded)
Plug in the external HDD ,run SwissKnife and select the format option!
Posted on Dec 15, 2010
Crankstart
  • 696 Answers
Sounds like a 2 part question.
Part 1, how do you use the drive on the computer to watch recorded shows from you DVR, simple install EX for windows which will allow your computer to access Linux formatted drives.
Part 2, how do you retrieve the files that were on it before, that depends how many new files you've put on it since. When the DVR formatted the drive it didn't erase the old files and they could easily be found again with a very inexpensive program. Each show you've recorded since will have overwritten some of the files. I will give you a link below for a review I wrote of such a program. Don't buy it right away, download the trial and scan the Toshiba, the program will show you a list of files it can recover then if you think it's worthwhile for the files it shows, only then pay for the program and recover the files.
Link for EX?
http://www.fs-driver.org/download.html
The author provides this driver for free but asks you donate to show your appreciation.
Data recovery software:
http://www.aitsavemyfiles.com/reviewfilerecoverybypctools.php
Hope this helps FixYa,
Chris
Posted on Dec 23, 2010
  • 65 Answers
SOURCE: My girlfriend purchased a Toshiba
When the drive is plugged in, right click on "My Computer," click "manage" and then in the left hand pane click "Disk Management." You will see a few drives on the right, find your USB drive. Look at the size to make sure it is the right one. Also, of course, it will not be labeled "C:". Right click the drive and click "format". Follow the prompts, and if asked for a format choose "NTFS".
Posted on Feb 28, 2011
  • 7 Answers
SOURCE: How to format a Toshiba
Just make sure you have any and all data that you want saved moved elsewhere before proceeding.
Posted on May 06, 2011
My macbook pro doesnt recognize my toshiba canvio 3.0 external hard drive
When have you bought you mbp ?
Your External HDD is in which format, Do you have an app like NTFS for mac osx, or Tuxera NTFS on your MBP if your HDD is not formated as MAC OSX drive. .....
Nov 30, 2012 | Toshiba E05A100PBU3XS Canvio 1TB USB 3.0...
How do you remove a file from the external hard drive
Hello tyearms
First, are you on mac or windows system?
Thank you
Nov 19, 2012 | Toshiba HDTB103XK3AA 320GB Canvio Basics...
How i can reformat toshiba canvio 320 g on my macbook pro
To totally reformat the hard drive which will delete everything off it. Go to your applications folder and then to the utilities folder and double-click on disk utility. In the left hand column select your drive then select the erase button once on the erase section select the format you want to format the drive in (if you are only going to use it on a mac select Mac OS Extended, if it is going to be used on both macs and PCs select MS-DOS (FAT)) then choose the name you want to call your drive and then select erase.
REMEMBER THIS WILL WIPE ALL THE FILES ON YOUR HARD DRIVE.
Hope this helps.
Sep 15, 2011 | Toshiba Canvio Plus 320 GB 2.0 Portable...
I purchased a Toshiba Canvio 3.0 500 GB portable hard drive, and plugged it into my MacBook with Mac OS X Tiger. The icon for Toshiba EXT came up on the desktop but wouldn't do anything. The box came...
1 . Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
2. Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
3.
Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
4. Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs.
  • 5. Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
  • 6. Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
    Aug 30, 2011 | Toshiba Canvio 500 GB USB 20 Portable...
    My girlfriend purchased a Toshiba an E05A075ABU2XY canvio plus but didn't realize that it was for a OS MAC. Can i reformat the external drive to work with windows? If so, how do I do it? Thanks,
    Feb 28, 2011 | Toshiba Canvio 750 GB USB 20 Portable...
    How to format removable toshiba PX1395E-3G75,
    Install it any windows OS and R click my com>manege>disk manegement >format your ushb HDD.
    http://www.ehow.co.uk/video_4992400_format-hard-drive-windows-xp.html
    http://www.mahalo.com/how-to-format-a-hard-drive http://lifehacker.com/157578/geek-to-live--how-to-format-your-hard-drive-and-install-windows-xp-from-scratch http://www.buildeasypc.com/sw/hddsetup.htm http://www.whitecanyon.com/format-hard-drive.php Hope this helps.
    If you are helped you can rate on the 4 thumbs and post a short comment,because,
    this is the free side and I can get the chance, to help people like you .
    Thanks for using fixya .
    Jan 19, 2011 | Toshiba Canvio 750 GB USB 20 Portable...
    How do i format Canvio 320 2.0 to be compatible with mac
    i dont do macs much but macs support fat32 and you can just format it on your mac
    Jan 17, 2011 | Toshiba Canvio 500 GB USB 20 Portable...
    I work with OS X (mac) , I can not copy a file bigger that 4 GB into my WD my book. I 've tried to change the format, but i can just chose between : Mac OS Extended ( Journaled) ,Mac OS Extended, case-...
    Although Macs are designed to Read NTFS, they aren't designed to write to them and therefor cannot format a windows drive. If you are simply moving files onto the Mac from a windows PC you can format the drive using a PC and the Mac will be able to read and copy the files from the drive. If your goal is to have both windows and Mac read and write to the drive, your best bet is to use Mac OS Extended, then to buy and install Macdisk on your Windows PC. This will allow both to fully utilize the drive.
    Any file size limitations you're running into at that point would have to be dealt with through compression or you may need to set up a NAS server that uses either NTFS or Linux format and copy files across the network rather than through a direct port like USB or FireWire.
    Feel free to respond back and pick my brain if this advice only gets you half way solved.
    Chris
    Dec 23, 2010 | Western Digital My Book Essential Edition...
    Toshiba E05A100PBU3XS Canvio 1TB USB 3.0 Portable - Black/Silver USB 2.0 Hard Drive Logo
    173 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
