Question about Vehicle Parts & Accessories
Car won't start without pushing the red connector on the battery
I have to push the red connector down every time I need to start my car. Once the car is running its fine, it continues running. I tried to tighten it but it seems as tight as it can go. Does it need to be cleaned or can I wedge a piece of metal in between the connector and battery?
  • Vehicle Part... Master
  • 14,333 Answers
You can got to Autozone and get a new battery cable,they are 2.99 and the guys there will install for free.
Posted on Jan 11, 2013
2 Suggested Answers
  • 134 Answers
SOURCE: Fiat Strade 1.6 2005 My 20 year old son's FIRST
Based off the fact that the car runs good when pushed I would say that you have a dead spot in the starter motor. These are typically swapped from the old motor onto the new motor so it is probably original. I've seen this quite a few times. If he installs a new starter motor the issue should be corrected. Based off what he already has invested in the car I would say it is certainly worth fixing. Hopefully he wont have any more problems after that. The starters typically run anywhere from $125-$175. I hope this helps your son.
Posted on Feb 17, 2011
Mazda 6 wont start
Ask one of your friend to come with his car to connect your battery for a boost! After that try to start the car without pushing the accelerator pedal! Let me know more details,please!
May 28, 2013 | Cars & Trucks
2003 Goldwing won't start...just one click when start button pushed
you may have blown the starter solenoid or even worst the starter motor
i cannot diagnose without seeing the bike properly
i strongly suggest you put in a workshop and get it diagnosed properly
Apr 12, 2013 | 2003 Honda GL 1800 Gold Wing
Alarm won't turn off
Turn key to on position, but not start it. Push red button on left of steering wheel twice, then start
Apr 05, 2017 | 2001 Toyota MR2 Spyder
2008 Lexus ES350 won't start after multiple times
You will need the dealer to look at his, diagnosis of this problem takes special equipment and skills.
Oct 22, 2012 | Cars & Trucks
Clicking noise in driver's side window
Your master switch is stuck in the running position and need to be replaced. Very simple to do. The reason your battery is running down is the switch is constantly activated and draining the system. Once you replace the switch everything will be good
Mar 29, 2017 | 1999 Oldsmobile Aurora
Car starts after taking foot off gas car shuts down 2001 mit 3.0 v-6 spider
For this problem, i suggest you to go through this help links.Click the link below to go through the troubleshooting procedure :----Car Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html-----------Car only starts when gas pedal is pressed? http://technoanswers.blogspot.com/2012/01/car-only-starts-when-gas-pedal-is.html
-----------Car won't start without hitting the gas pedal? http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-without-hitting-gas.html
---------Car dies when gas pedal is pressed? http://schematicsdiagram.blogspot.com/2011/12/car-dies-when-gas-pedal-is-pressed.html
------------Pushing on the gas pedal, but the car slows down? Gas pedal to the floor and the car slows down? http://technoanswers.blogspot.in/2012/02/pushing-on-gas-pedal-but-car-slows-down.html
-----------This will help.Thanks.
Feb 15, 2012 | 2001 Mitsubishi Eclipse Spyder
Car shut down when foot not on the accelerator
For this types of problem,there are few help links.I suggest you to click the link below and go through the troubleshooting procedure :-----Car only starts when gas pedal is pressed? http://technoanswers.blogspot.com/2012/01/car-only-starts-when-gas-pedal-is.html-----------Car won't start without hitting the gas pedal? http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-without-hitting-gas.html
----------Complete loss of brake pedal then all gets normal? http://repairhelpcenter.blogspot.com/2012/01/complete-loss-of-brake-pedal-then-all.html
----------Car dies when gas pedal is pressed? http://schematicsdiagram.blogspot.com/2011/12/car-dies-when-gas-pedal-is-pressed.html
--------------Pushing on the gas pedal, but the car slows down? Gas pedal to the floor and the car slows down? http://technoanswers.blogspot.in/2012/02/pushing-on-gas-pedal-but-car-slows-down.html
-------------Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html----------This will help.Thanks.
Feb 02, 2012 | 2002 Toyota Camry
I have a 2004 pontiac sunfire with a few problems. First, when I turn the ignition to start the car all I get is a fast-paced clicking sound from the dash area and the engine doesnt even turn over. This...
as fo the idle, there is a IAC ( idle air control to maintain idle. you may have to remove this and clean the carbon out of it, and the intake as well. as for the clicking there are 3 solutions to fix it. battery if it is ok, the solinoid is bad on starter or the starter itself. but it does sound like a bad starter solinoid, because a bad battery will make the same clicking from solinoid. but make sure battery is ok first. when engine is off voltage at battery should be at least 12.6 or better. when running and alternator is ok, it should read about 14.2 to 14.7 if lower then 14 volts alt. is bad. have a very good day !! hope this helps!
Jul 09, 2011 | 2004 Pontiac Sunfire
Vehicle Parts & Accessories Logo
35 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
