Question about Electrolux Vacuums
My Model G electrolux works great until one day it
Won't turn on. could it be more than the switch? my firend tested the switch and said it isn't getting juice to it. so should I replace the switch?
  • 32 Answers
Use a multi meter and use checking continuity, from one side of the switch to the other. If you have continuity, the switch is good. It is also likely that the power cord could be bad, again checking continuity put one probe on one prong of the plug, and the other probe on the black, white, or green wire (thus checking the continuity through the cord)
It is common that cords get pulled out of the wall socket incorrectly, or accidentally when you run out of cord as you word away from the power source, stretching and eventually breaking one of the wires inside the power cord.
Posted on Jan 20, 2009
Vacuum cleaner won't turn on
Check the cord first to make sure you are getting power to the switch. If not replace the cord, if so test the switch to make sure you are getting power through the switch. If still not solved follow the power down to the motor and make sure you're getting power to the motor. If so and still wont' run test the motor.
Nov 05, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hoover spirit 900 canister wont turn on?
see this causes and fix it. God bless you
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
Sep 27, 2012 | Hoover Vacuums
Beater bar motor quit, now the main motor quit. Replaced the on/off switch. still nothing
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Vacuums
Power is not coming on
Sep 27, 2012 | Wagner Spray Tech Wagner 915 1,500-Watt...
Head won't work on dc 11
1) test the outlet wall with another devide such LAMP, if work is o.k
2) the problem will vacuum power : a) test the switch b) motor itself repair or replace.
God bless you
Sep 27, 2012 | Dyson DC11 All Floors Bagless Canister...
Dyson dc25 off button won't turn off, brush button won't engage brushes
Hi ... did u get this fixed cos mine is the same hve to switch off on the wall?
Sep 22, 2012 | Dyson DC25 All Floors Bagless Upright...
Bristles quit rotating and smelled like something was burning. It isn't the belt that turns the bristles. Can't afford a repairman, can you help me fix it?
Belt can reamin intact but still jam and burn. It won't necessarily break. I suggest you remove the bottom of the vacuum where the bristles spins and where the belt is located. You may have something jammed in there. You may need to remove the bristle to get the belt out. Inspect the belt and replace after clearing the obstruiction.
Sep 21, 2012 | Bissell 6594 PowerForce Bagless Upright...
I cant find fuse on my kirby sentria. Any suggestions?
there isn/t a fuse if not turning on probably a bad switch or power cord
Jul 18, 2009 | Kirby G6 Bagged Upright Vacuum
Vacuums Logo
60 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
