Question about RME Fireface UCX 18x18 24/192 USB2/FW Intfc
Yellow led flashing
When I turn ON, the MIDI OUT yellow led keeps flashing all the time on my Mac. When I use my UCX on another pc (Win7) that does`t occur. Iplugged just my USB into the pc an nothing else
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
I can't open contacts and calendar in my mac pc
Shut down youre computer completely. Start again, but keep holding down the start button, until the white LED on the front flashes rapidly.
If this doesn't solve it, shut down your computer. Restart and hold down alt-cmd-p-r (4 keys) during startup until the computer has said boing three times.
Write again if it still doesn't work.
Mar 10, 2014 | Apple MacBook Pro Laptop Computer with...
Weird midi
A few things to try:
1) if your oxygen is connected using a midi cable instead of a usb cable it could be that the midi cable is damaged.
2) you may want to try changing the preset of your oxygen: use the buttons on the oxygen, near the two digits led, to selelct a program between 01 and 15, this will change the values assigned to the knobs
3) you may have some kind of midi loop going on, try going to the preferences in ableton and disable all midi controllers (remote, sync, track) both in and out; then enable only the oxygen for track IN and remote IN which is actually all that you need.
Jan 16, 2013 | M-Audio OXYGEN 8 USB Controller
The yellow LED on my Toshiba 32CV510U flash all the time and TV won't turn on
check some leak or bulged capacitors at the power supply board then replace it.
Oct 02, 2012 | Toshiba 32CV510U LCD TV
Install of usb midi interface driver on mac not working
make sure the cd driver is ok and has no scratch. other wise you have to down load ther driver from the net.
Aug 24, 2012 | Apple Computers & Internet
I have a broken Dell Precision 470 Workstation. The symptoms are as follows: Won't power up; Flashing yellow power LED on front panel; Blank STR_LED on motherboard; Yellow AUX_PWR LED on motherboa
Flashing front powerlight is often a result of a faulty powersupply, try another powersully on the pc and see if the problem gets solved. I've seen a few of these cases personally.
Jul 01, 2012 | Dell Precision Workstation 470 (204816690)...
Notes don't stop even after I release the key
The keyboard  is not sending a note off instruction after the key is released. Try checking midi preferences in reason.If your using a Mac check that the edirol is present by launching Audio MIDI Setup utility located in the utilities folder. You can download the latest Mac driver from Roland below: EDIROL PCR-300 32-key MIDI Keyboard Controller :: Download
Jan 18, 2009 | Propellerhead Reason 4.0 - Windows and Mac...
As soon as I plug in/switch on my midi keyboard, the USB LED flashes
dear sir,
your problem is very simple. please check the didi key board seriel pin.some time the seriel pin is broken. your goole problem is network problem.please check the network connectivity. otherwise operating system problem.sometimes while your installing the operating system some files missing. so first check your computer network and serial port.
thanks & records
sakthivel
Aug 09, 2008 | Lexicon Omega Desktop Recording Studio...
RME Fireface UCX 18x18 24/192 USB2/FW Intfc Logo
19 people viewed this question
Top RME Computers & Internet Experts
David Payne
David Payne
Are you a RME Computer and Internet Expert? Answer questions, earn points and help others
