Question about Husqvarna Sewing Machines
I have a Husqvarna Topaz 30 Sewing machine that the thread cutter will not retract
The thread cutter will not retract and makes it impossible to use the embroidery feature of the machine. Does anyone have a solution ....I am frustrated
    Scholar:
  • Husqvarna Expert
  • 104 Answers
A work around would be to remove the thread cutter mechanism completely. You can manually cut the top thread when spool changes are reqiired and would only have to deal with the bobbin thread when the hoop is removed. Moreover, I suspect when the cutter mechanism is removed the source of the problem will reveal itself. Depends on how skilled you are whether you tackle this yourself or take it to a sewing machine repair person. I suggest the latter.
Posted on Jan 30, 2013
pgmadhav
  • 145 Answers
SOURCE: Husqvarna 1 Embroidery software
Use program compatibility wizard and you'll be able to use the same program in Windows XP also.
  • To start the Program Compatibility Wizard, click Start, click Help and Support, click Find compatible hardware and software for Windows XP, and then, under See Also in the navigation pane, click Program Compatibility Wizard.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Posted on Dec 20, 2008
kent581
  • 87 Answers
SOURCE: Husqvarna Vikinge Designer I thread cutter keeps going out
there is the temp fix-epoxy when putting it on (actually can work well, just dont epoxy it on the bottom and freeze it or the permanent fix -new hook cover complete where the cog is'nt going to come off on the new part
Posted on Mar 18, 2009
  • 371 Answers
SOURCE: How to thread my sewing machine? Husqvarna Classica 95
Suggest you contact an authorized Husqvarna Viking dealer. They can order you a user manual. Authorized dealers can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Brief description of probably how to thread from looking at a picture of a Classica 90 machine which should be similar -
Thread sits on spindle on backside. Pull thread straight across to upper left backside and fit in the metal guide. It should pull easily with only a little resistance. Pull thread forward across top toward you. Let thread fall between the metal disks (doesn't matter which one if more than one) and pull thread straight down. Pull thread slightly to the left to fit under a hook of some type and back up to fit through the large hook that moves up and down when the handwheel is turned. Come straight back down to needle and thread through eye of the needle. Just above the needle should be a thread guide (sideways hooking looking metal piece), slip the thread through it to hold thread close to needle. Hope this helps. Otherwise a local authorized Husqvarna Viking dealer will be glad to help you. Good luck.
Posted on Sep 25, 2009
SOURCE: I want to use a
Three things to check:
1.You need to use a needle specifically made for metallic thread. I believe the eye of the needle is square and the thread will pass through it easier, and will not be shredded which can be a cause of breaking.
2. Be sure to check your tension to make sure it is not too tight on the top. Test your stitches, checking both top and bottom tension.
3. The thread should come off the spool straight, not twisting. The thread cone should be standing up straight and the spool should twirl to release the thread. If the spool is not moving and the thread unwinds from the stationary spool, then the thread is twisting and that can cause the breakage as well.
Posted on Dec 07, 2010
  • 192 Answers
SOURCE: Husqvarna embroidery diamond machine not cutting
If the cutter is not moving when the cutter motor runs, there is probably a gear loose in the cutter mechanism. Take the machine to the dealer that you purchased it from, or the nearest authorized dealer. http://webservices.us.vsmgroup.com/DealerLocator.aspx?Brand=Viking
Make sure that you have your warranty card and purchase receipt. If a gear has broken, the mechanism is warrantied to the original owner for 20 years.
If you are the second owner, or the machine was purchased online instead of through an authorized dealer, an authorized dealer will give you an estimate for parts and labor and repair the problem for you.
Posted on Dec 01, 2011
My Husqvarna Opal thread cutter is not cutting the thread from the bobbin.
Huskies are excellent machines. Guessing this is a serger? Doesn't matter. Very likely you could ask Husqvarna.com. Likely, something is a bit out of sync. Or - all sewing machines are 'picky' about being threaded correctly. You might check that.
Jan 23, 2018 | Husqvarna Sewing Machines
Husqvarna viking sewing machine
If the machine was just recently serviced and the thread cutter stopped working after the service, take it back immediately! They should be able to fix it for you.
Aug 25, 2016 | Husqvarna Sewing Machines
Poor tension on a Viking Topaz 20
Is the thread coming off the Thread Take Up? That will cause issues. Another thing would be to take apart the bobbin area and clean it thoroughly. If you have one of the sewing machine vacuum attachments that would be the best way to clean it. Good luck.
Apr 16, 2014 | Sewing Machines
My topaz 50 keeps birdnesting when trying to sew fmq
Hello
Please re-thread sewing machine from thread spool to needle, making sure that all thread paths are engaged; especially the take up lever and tension area.
Check that the correct bobbin is being used and that it is properly positioned in the bobbin case. Double check that the bobbin thread is in the thread patch and has "clicked" into the spring.
Happy Stitching
Sewingirl/
Jan 27, 2014 | Husqvarna Sewing Machines
The thread is tangling in the shuttle on my topaz 30 sewing machine & stopping the material to feed through
Are you absolutely certain you have the top thread routed correctly? If so, check the timing of the needle to the hook. Take out the bobbin assembly parts. Turn the handwheel counter-clockwise to position the needle in the downmost position. The needle should just barely clear the hook as it rotates. If not (hitting or way loose), it needs adjustment.
Mar 02, 2013 | Husqvarna Sewing Machines
How to put a thread cutter in husqvarna viking desinger se sewing machine
I believe the plastic cover (gray?) toward the end of the arm (left of the needle plate) is removable by prying (gently) on the front edge and sliding toward you. Unless the cutter is broken, you should be able to figure out how itall fits back together.
Dec 21, 2012 | Husqvarna Sewing Machines
The selective thread cutter not cutting thread.
You need a new blade in the cutter. It is a simple repair job, but needs to go to the repairman for it to be done.
Feb 28, 2010 | Husqvarna Designer I
Jan 20, 2009 | Husqvarna Viking 1
Sewing Machines Logo
588 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
