Question about Hotpoint Refrigerators
Damper to refrigerator closes but won't open
SOURCE: I have a Kenmore refrigerator/freezer model #
What you didnt state was whether you had cold air blowing when the damper opened up. If you did, then the problem will be with the damper assembly itself, or the control board, which is what you would adjust to change temperatures. This microswitch you mentioned, was this on the control board? then the control board is the problem. If you did something with the damper assembly, then that might be the problem.
If you dont have any cold air blowing when you opened the damper door, then airflow is your issue, and you will have to include more symptoms for a refrigerator repair diagnosis.
Posted on Nov 27, 2010
  • 5 Answers
SOURCE: Maytag MZD2666K Side by Side Refrigerator Problem
The Damper is broken. Replace it. It is relatively easy. You can get the part online.
Posted on Nov 28, 2010
bobicehouse
  • 1524 Answers
SOURCE: I have a GSL25JFPA BS that the frig side will not
Unplug the refrigerator and then plug back in. Using multimeter check between J3-1 and J3-4.
Must be done within 10 seconds of starting. You should have 6 VDC. If you do replace damper, if not replace motherboard.
Posted on Jul 06, 2011
  • 5370 Answers
SOURCE: Kenmore Freezer works, Refrigerator doesn't
As per the problem, it does not indicates towards compressor problem.Because idf compressor stops working, then freezer section will not freeze.But in your case the freezer is working properly, so this clears that compressor is working properly.--------- As per your problem, its defrost problem.--------
The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site.------------ As you mentioned that defrost heater and defrost thermostat both are working good.Then problem indicates towards defrost board.------------------ -------------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.---------------------
NOW read this point carefully. When the freezer reaches its cooling level the defrost cycle starts functioning.---------- But when freezer section reach the set temperature, then thermostat senses the temperature and give command to defrost board that , now start the defrost heater.So defrost heater gets hot and melts the ice.The ice melting water in the freezer section, drains from the drain line to the pan above the compressor.This drained water gets dissolved in air when compressor gets hot.---------- But in your case most probably the thermostat is not sensing the freezer temperature, so the defrost cycle is not starting and if defrost cycle will not start, then cool from freezer will not get to the fridge section.--------- So most probably its thermostat, but if thermostat checks ok, then its faulty defrost control board.--------- For getting thermostat testing instructions,click the link below:--- http://howtobyme.blogspot.com/2011/07/how-to-test-defrost-thermostat-on.html --------- This will help.Thanks.Helpmech.
Posted on Jul 18, 2011
Macmarkus
  • 2605 Answers
SOURCE: THE REFER SIDE IS FREEZING
Hello, welcome to FixYa.
Based on your post I understand you have a problem with a refrigerator, Frigidaire model:FRS23R4AQ7, correct ?
If that's the scenario and If it is indeed a Frigidaire side by side, what do you have the said controls set at ? These have a history of irratic cold controls/thermostats.
The other thing that could manifest in this manner is a clogged condensor coil assembly. Have you blown it out with compressed air or vacuumed it out recently ?
I'll watch and look forward for your reply and we can go forward from here if you need any further assistance. Good luck.
Regards,
Macmarkus :)
Posted on Sep 08, 2011
GE Profile Arctica fridge running too cold
You may want to check your damper assembly to see if the door is broken. If the door is broken it will air to migrate to the refrigerator compartment causing freezing issues. Also check to make sure that the damper door is not staying open. When you take the cover off with the door open the damper should close. If the damper is open then you need to replace the damper. Here is the damper to order.
Dec 05, 2012 | GE Refrigerators
Frigidaire refrigerator temperature problem
Hello - From what you have describes it sounds like the damper door might be open causing the temperature to be too cold. Use a mirror to look at damper door at the rear of compartment and use a hair dryer on damper door to deice for 5 to 10 minutes. Allow 24 hours and if the temperature is still too cold, then I would have a professional look at the damper door or thermostat control for replacement depending on the diagnostic.
Oct 30, 2012 | Frigidaire Refrigerators
Damper won't close
Depending on the correct model number found inside the fresh food section will help diagnose but it sounds like either a defective temperature sensor or the damper itself is the cause. If your model number is a USA model number I can look up what part number and tell you better by looking at parts manual. Let me know the model number and I will try to help you find the correct parts, Thanks Sea Breeze
Sep 15, 2012 | Electrolux Refrigerators
The refrigerator portion of my Amana ARB2217CW stopped cooling (the fan is still running), but the freezer drawer portion still works fine. What can
most likely you have a bad damper,go here to see it
http://www.repairclinic.com/PartDetail/Damper/67003410/1025326
all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air to the fridge section and it goes through the damper,when it gets cold enough in the fridge section the thermostat on the damper closes the damper door,your damper broke in the closed position,this is as long as the door wasn't left open or anything like that,if it was the air ducts could have froze up but most likely it will be the damper.go here and it will show you where it is up near the light in the back and it's part number 18.hope this helps
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-ARB2217CWPARB2217CW1/1268/0161000/M0403273/00003?blt=06&prst=&shdMod=
Sep 04, 2012 | Amana Refrigerators
Amana BR22VL refrigerator section stopped cooling.
is there any frost on your food packages or on the ceiling where the light is?if so the door was left open and the air vents are froze up or you have a bad damper or evaporator fan motor,open the freezer door,do you hear the fan blowing?if so the fan motor is good,check for ice on the ceiling and packages,if that checks good look at the back inside wall of the freezer,if that's covered with like snow or frost you have a defrost problem or also you have a damper in your model,it's closed and won't open to let the cold air in from the freezer.
http://www.repairclinic.com/PartDetail/Damper/R0161050/223353
go here,this is the part,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer up into the fridge section,in your model the damper door opens to let the cold air in,when it gets cold enough the damper closes and that's it,so if the door wasn't left open and the fan is blowing in the freezer you have a bad damper.
Aug 10, 2012 | Refrigerators
Refrigerator side freezing
you could have a bad damper,this is located in the fridge section,all it is is a door that opens and closes to let cold air into fridge,sounds like yours is stuck open.remove the bottom kick panel and look for the tech sheet,it will tell you how to put it into diagnostics,the board will open and close,if it doesn't you know it's bad.go here and look at part number 13
http://www.searspartsdirect.com/partsdirect/part-model/JENN-AIR-Parts/Refrigerator-Parts/Model-JBR2086HES/1266/0161000/M0610191/00008?blt=06&prst=&shdMod=
Jul 12, 2012 | Jenn-Air JBR2086HES Stainless Steel Bottom...
What would cause the freeze to be cooling normally and the refrigerator side to be at a temperature of 55 degrees?
all it does is the freezer gets cold,the evap fan blows cold air from the freezer into the fridge section so if the freezer is fine,check the air ducts in the fridge section,if a package or something is blocking the vent on the bottom it will get warm or also on your model you have a damper on the top where the air blow into the fridge section from the freezer,you have an electronic damper,there's a door that opens and closes to let the air in,when it's cold enough the door closes when it gets warm the door opens so either the damper is bad or the computer board that operates it is bad,also check the packages in the freezer,if you see frozen water droplets on the packages or ice on the shelves the door could have been left open and the air ducts freeze so no air can pass through,you can hit the air ducts with a hair dryer to melt them out but be careful,don't keep the heat on one spot for to long,you can damage the ducts,also when you open the freezer door you should hear the fan blowing,if not you could have a bad evap fan motor and the air isn't blowing over to the fridge section,the damper is like 45 dollars and the computer board is around 120 dollars,you can go onto the sears site,put your model number in and look at the controls and you can look up the parts.http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MCD2257HEB/3048/0165000/M0703130/00006?blt=06&prst=&shdMod= copy and paste.open the freezer door,listen for the fan no fan bad motor,if the fan is blowing either the air ducts are frozen or you have a problem with the damper or board that operates the damper,you might want to call in a tech for this if it is the damper,it's a little tricky to do this job but that's up to you.good luck and i hope this helps you out.
Sep 24, 2011 | Maytag MCD2257HE Side by Side Refrigerator
I have a GSL25JFPA BS that the frig side will not cool properly. Repalced the mother board. t stat in freezer and thermistor in frig. Freezer works fine. Damper will open when first plugged in but closes...
Jul 06, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Items in the lower refrigerator compartment arefreezing
Hi, Sounds like the damper or damper belt may be at fault. The cold air enters the refer compartment through the damper in the back. If that damper is not controlled to close/open as needed it is likely stuck fully open all the time. That will let cold air in no matter what the t-stat says. See if you can view with a mirror and see if the damper "blinds" are fully open. If the t-stat is turned all the way down the dampers should close, as less cold air is needed. Then, as the t-stat is turned up, the dampers open to let in cold air from the freezer compartment.
Take care
Jul 23, 2010 | Magic Chef CTB1922 Top Freezer...
Refrigerator side is freezing food and won,t hold at 37 degrees?
check the damper door that lets cold air from freezer to refrigerator and make sure theres no ice build up that can prohibit damper door from opening and closing its probably stuck open from ice build up
Dec 22, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Refrigerators Logo
26 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
