Question about Makita 10" Dual Slide Compound Miter Saw with Light LS1013F
Saw stops at predetermined stops but wont lock anywhere else
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 142 Answers
If the handle wont lock down the linkage could be out of adjustment. Look under it and you can see how the linkage works pretty easily or if it's broken. You can view a breakdown and makita.com or call Makita direct at 1-800-462-5482. they can direct you to tech from there.
Posted on Jan 04, 2013
Product just arrived, saw is stuck in cutting position
There is usually a safety or transit lock or pin which is engaged to lock the saw down for safety and for a more convenient way or transporting it.
The ones on my saws are a simple ball-headed pin sited close to the hinge of the saw which can be easily withdrawn once enough downward pressure has been applied to the saw to overcome the return spring pressure.
Mar 15, 2015 | Dewalt DW713 NA 10" Compound Miter Saw
Changing the blade on the 3540 wetsaw
Blade should be secured to motor. Make sure bolt is tightened while holding blade with a pair of channel lock.
Nov 07, 2012 | Skil 3540-02 7-in Wet Tile Saw
How do unlock mitre saw mastercraft 7-1/4-in mitre saw with laser its in the lock postion and wont release
There is a lever or push button by the hinge (where the saw pivots).Just push down on the top of the saw and release latch.To lock back down , just push down on the saw and put lever back in the lock position.
Jun 04, 2011 | Garden
10 inch lest tilt Unisaw will not tilt to complete verticle --only goes to 88.5.
There is an adjustment under the table top. It usually is a bolt with a lock nut that allows you to adjust the table to a predetermined angle every time. You can adjust the amount that the table will go by unlocking the lock nut and then turning the bolt the correct direction allowing the table to come to a full 90 degrees. Once you have the table a 90 degrees lock the bolt down with the lock nut. This will aloow you to change the tilt of the table to something other than 90 degrees and then come back to the 90 degrees by turning the adjusting wheel until it bottoms out against the locked doen adjusting bolt.
Mar 17, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
My LS1216 slide compound miter saws mitering table is stuck at 0 degrees it appears jammed although I've looked for something jammed stopping the plate from moving and see nothing, the handle locking...
Hello stella....... There is a locking mechanism on the miter saw to lock it on whatever setting you require. loosen that locking mechanism and the saw should move for you. Here is a schematic of the parts so you can see exactly which parts are involved
http://www.searspartsdirect.com/partsdirect/part-model/Makita-Parts/Saw-Parts/Model-LS1220/1339/0744300/P8100100/00002?blt=06&prst=&shdMod=
Joe
Thanks for choosing Fixya!
Feb 06, 2011 | Makita 10" Dual Bevel Sliding Compound...
Wondering how to tighten the blade on my circular saw. the motor wont break.
remember most circular saws are a reverse thread. First step is to make sure the saw is unplugged. If your saw does not have an arbor lock than stick a medium sized screwdriver in one of the teeth of the blade near the base of the saw, this will lock the blade in place so you can tighten the blade.
Oct 10, 2010 | Craftsman Saws
Rear wheel always locked. wont go anywhere
Have you check your brake pads, cable (brake system) are they in neutral. If not hen you drum pads are locked onto your drum. Check it first.
Mar 22, 2010 | 2003 Yamaha TT-R 125
Forgot unlock password
hmm so easily she LOCKED ur phone??? and U need to UNLOCK IT ?? this is done in case where u put a sim card and put on password By ur own self, when some body steals it and they try to use theirs it wont let them start phone without password. so IF YOU put the password YOU should know it! or ask some one who used ur phone earlier, and beware with samsung, if its NOT ur phone and u unlock it any ways( electronically) it send a message to predetermined phone about ur IMEI and sim reg no.
Nov 30, 2009 | Samsung Gravity SGH-T459 Cell Phone
I need the outer flange/blade clamp for my skil model 77 type 16
The replacement part is 1619X02969. And you can get it from directly from boschtoolservice.com ($3.75).
Oct 11, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Finding the lock button..changing a circular saw blade? "skill saw brand,usa" cannot seem to find it anywhere
older model of circular saw dont have a spindle lock.wedge the blade on a bench vise & make sure ur not clamping the teeth of the blade & then turn the blade screw clock wise.
Jul 03, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Makita 10" Dual Slide Compound Miter Saw with Light LS1013F Logo
57 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
