Question about Acer Aspire 5552-3691 Laptop Amd Athlon II X 2 2.2ghz, 250gb, 4096mb,
I dan't get my start up to load
    Problem Solver:
  • 11 Answers
Switch on laptop and straight away press f 8 key this should take you to a black and white screen asking which mode to start in so choose safe mode then go into my computer then control panel and choose system restore. this will start your computer from an earlier point in time when it was running fine. give it a try.
Posted on Jan 02, 2013
How do I instal MS Office 2010 on a DELL laptop that already has it 'loaded' in the programmes when purchased but there is no product 'key' to allow operating to start. DELL cannot he
If you have original cd kit, don't worry remove all current methods office software , restart computer and reinstall. It will work fine.
Apr 08, 2012 | Computers & Internet
What's the best way to hook up 2 Hifonics hdl12d4 subwoofers to a mono amp
Ok, your post has two different models listed. Let's start with something you need to know about your amplifier. Is it one ohm or two ohm stable. This will make a difference. Also, whether your subs are single voicecoil (HFI12s4) or dual voice coil (HDI12d4).
Let's start with the easy scenario. Let's say your amp is two ohm stable and you have two single voice coil subs. It's simple. You go from the positive of the amp to the positive of both subs and the negative of the amp to the negative of both subs. This will provide a 2 ohm load to the amplifier, thus pulling all the power out of it.
Unfortunatley, if you have two dual voice coil subs, you won't be as efficient. You will only have the options of a 4 ohm load or a 1 ohm load.
This is where having a one ohm stable amp would come in handy. If the amp is one ohm stable, hook the positive of the amp to all 4 of the positives on the subs, and hook the negative of the amp to all 4 negatives of the subs. This produces a 1 ohm load.
WARNING!! If you have a 2 ohm stable amp DO NOT use the last wiring scenario. It will fry your amp.
Now, the last is a little trickier. This is for two dual 4 ohm subs. Follow closely. Hook the positive of the amp to one of the positives of each sub. (do the next step to both subs) Go from the negative of the voice coil that you hooked positive from the amp is hooked to, and hook that to the positive of the unused voice coil. Then go from the negative of that voice coil and hook to the negative of the amp. Make sure this is done on both subs. This will give you a 4 ohm load.
Hope this helps
Aug 31, 2011 | Hifonics HFI 12S4 12 DVC Subwoofer 600...
I have a near new McCulloch M T325 cls line trimmer that will not start. Plug is OK; fuel is clean & correct mix. Suspect Carb. setting is incorrect but user guide does not tell how to correctly set....
Try turning the mixture screw all the way in and then backing it out about one and a quarter turns. Try to start it and then if it doesn't start, just turn it out 1/4 turn at a time and keep it up until she fires. I just did the same with a Weedeater I rebuilt. Once she's running, you can adjust it for optimum performance. Good Luck.
Apr 23, 2011 | Garden
Nokia n73 saya ad masalah..bila sya sedang sms ...ga pernah sampe akhir pasti ad tulisan MENUTUP APLIKASI dan selanjutnya ad tulisan MEMORY TIDAK AMAN KELUARKAN KARTU MEMORY DULU
Sobat nokia,,,ak awan dr jkt,,, ada mslh di n73me pny ak nh mnt bntuan'a y!file foto & video nampak di xplore namun ketika m'buka galeri foto & vidoe tidak da satupun yg nampak?bgmn y,,,,
Mar 01, 2011 | Nokia N73 Cellular Phone
Can cpx 900 be bridge @4 ohm?
The short answer is no. This amp was designed to be bridged with an 8Ohm load not 4. That being said, the unit will work, but get very hot and possibly get damaged should you provide it too low an impedence load. DO NOT conenct this ti a 4Ohm load in bridge mode.
Dan
Oct 27, 2010 | Crest Audio CPX-900 Amplifier
Convert a 4 om amp to play w/8 om speaker
Connect the two speakers in parallel. That will present a 4 Ohm load to the amp.
Dan
Sep 14, 2009 | Adcom GFA-5400 2-Channel Amplifier
My teac ref500 amp switches its self now and then and will not switch back on for 5-20mins, can you help
This is a good indication that the amp is geneating too much heat. There are protection circuits inside that will shutdown the amp if it gets too hot. You will need to determine what is causing the excessive load on the amp to make it generate that heat. Look for crossed wires or problems in the speakers. This amp is designed for 4 ohms (I think) and a load less than that will still work, but cause the amp to work harder and generate excessive heat.
Please keep us posted.
Dan
Sep 04, 2009 | Teac Reference DR-H300
We have a roof top mount cetral heating & air unit and its a day& night unit it will blow air out but not cold air .went on top of roof to check condencer and it is hot and coils are normal...
sounds like the compessor over load is cliking on&off compressor not starting could be a capacitor or compressor or if your lucky a contactor dan
Jul 13, 2008 | Heating & Cooling
Power interuptiions
The unit is most likely getting too hot. Check your speaker cables for frayed wires that may be touching each other. The amp will continue to work, but work much harder into a lower impedence load. Over time this will damage the amp. If the cables are OK, try running the amp with the speaker wires disconnected. If the unit still behaves the same way, there is a problem internally with the output section that should be corrected ASAP.
Dan
Mar 31, 2008 | Yamaha HTR-5990 Receiver
Acer Aspire 5552-3691 Laptop Amd Athlon II X 2 2.2ghz, 250gb, 4096mb, Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
