Question about 7701V Responder SST Remote
Reset 7701 viper alarm remote
Remote battery went dead. I need to reset system because remote is not communicating with the brain.
  • 899 Answers
SOURCE: viper remote stopped working 791xv
I have the same remote and it comes disconnected in the battery section from the battery hitting it and then the commands and speaker stop working
as shown here
Posted on Apr 05, 2009
  • 22 Answers
SOURCE: the battery was taken out
Put the key in the ignition turn in two clicks. Take the key out hold down the program/valet button on the remote start then hit the unlock button on the remote.
Posted on Dec 04, 2008
  • 50 Answers
SOURCE: Viper SST 7701. I replaced
Try to relearn the tach by cranking the car and holding the valet switch(small black push button) until the LED lights solid.The try it again
Posted on Aug 14, 2009
SOURCE: my viper 2 way pager remote will not arm or disarm
It could be set on car #2. Press function for 8 seconds and a light next to lock should come on. If the light next to unlock and lock (two lights) then it is set to #2 car (you can operate 2 cars with one remote). All you have to do is press function again to toggle between the two cars. You want to end up with only one light showing.
So, hold function for 8 seconds, then after a light shows, release and press function until you only see the one light.
Posted on Aug 19, 2009
MECP Guy
  • 344 Answers
SOURCE: viper remote car starter 479V
press and hold the ( P ) button until one long beep is heard, you now have 5sec to push the lock button to turn on or off the vibrate, wait another 5sec and it will automaticaly exit programming
Posted on Jan 28, 2010
Testimonial: "One word,AWSOME!"
1997 crown Victoria. viper alarm kill switch has turned all power to car. How do I reset
there is no override. Otherwise it would defeat the point of an immobilizer. I would find out why the alarm went off and deal with the rot cause rather than trying to bypass something made to be un-bypassable.
You may be able to reset the alarm by unplugging the battery from the car for a minute or 2 but I would start with the alarm manual to be safe. Possibly even remote the alarm and put the wiring back to stock.
Oct 16, 2016 | 1997 Ford Crown Victoria
I have a viper 5900 car alarm with the 7701 vpx remote and the lock and unlock are reversed. How do I fix this
according to Viper tech support (I emailed them your question):
Thank you for contacting Directed support!
You may need to reprogram the remote to your phone. Please use the following instructions to reprogram the remote:
To program the remote to your system please do the following:
1) open the driver door
2) turn the key to the "on" or "run" position
3) locate the valet switch (small black button under driver side of dash) and press once, release, then press again and hold
4) after the siren chirps one time press the lock button on the remote
5) the alarm will give you a unique confirmation tone
6) turn the key off (the same unique tone will be heard again)
Warm regards,
Nigel McGee I Customer Service Rep.
Viper Support
Apr 28, 2016 | Viper Vehicle Parts & Accessories
I have 2004 chev tahoe w/ a viper remote starter system,but no key fob. I replaced the car battery & now the cars computer won't let it start. How do I reset the computer?
The car's computer wont let it start?
Well, if you changed the battery and the viper alarm is the issue; locate the push button valet/programming switch. Turn the ignition on, press and release the switch. The alarm will disarm and you can start the vehicle.
To put the alarm in valet, turn the ignition on then off, within 10 seconds press and release the valet switch. The LED will illuminate solid to show that the system is in valet.
Aug 20, 2012 | 5900 SST 2-Way Security System / Remote...
I just purchased a 2007 Mazda3 S Sport Sedan and it came with a Viper 7701 intalled. I need to know where I can download the manual to help with turning off the alarm during thunderstorms and just general...
http://www.directeddealers.com/manuals/og/viper/G5301V_05-06post.pdf
the 7701V is actually the remote. The Viper remote start alarm system that it corresponds with is the Viper 5900.
Mar 21, 2011 | 7701V Responder SST Remote
My remote starter for my viper 5900 2 way trans isnt working...my battery went dead in the remote, than after i replaced it, it's not working properly
Try reprogramming the remote. Open the door, turn ignition on, press and release valet switch one time, then press and hold valet switch while pressing lock button on remote.You should hear a confirmation chirp from the alarm. Release both buttons.Turn off ignition. test.
Oct 03, 2010 | 5900 SST 2-Way Security System / Remote...
Viper remote cranks motor but doesnt keep running. Tried valet switch and still does not start. Just fixed anti-theft on car by leaving key in ignition. Did this cause the remote not to work correctly?...
did it ever work before?
A couple things here. It is best to have a "tach wire" and the system needs to be programmed to learn the tach signal in order to know if the car is running or high reving or dead. If it gets no signal of the sort the next option is voltage monitor, it monitors the voltage for an increase to show that the alternator is running. Either way that signal is not gettting to the viper brain or it has not learned that signal. You need an install manual, did you install the alarm?
Jan 10, 2010 | Remote Start System
Problem just started sunday...when the alarm is armed it would show the locked sign on the remote....now it doesnt show that its locked and beeps like its not getting signal...but the car did lock with the...
I have the same problem. The easiest way around it is to disconnect the battery for 10 seconds and reconnect it. This will reset the alarm system, and the remotes will start working again.
Take note of your radio stations as they will reset. :)
Dec 09, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Replaced the battery in my car need to reset my viper alarm
Alarms are not supposed to shut down the engine while you are driving if it was installed properly. Could be another installed accessory or the car itself has a problem. If it was in anti-hijack mode, you would receive a warning like honking horn. You may have to visit a repair shop and maybe your local Viper dealer to have them take a look. DC
Nov 04, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
7701V  Responder SST Remote Logo
101 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
