Question about Zebra Symbol Technologies MC909X-G Series Barcode Scanner
Backlight I have equipment MC9090 having backlight setting as 1minute. if i change the settings it is not permanent. it is changeing back if i restart. Can i change through registry file.?
  • 1 more comment
  • poorna Jan 02, 2013
    i am unable to find settings for backlight time make it as .reg file.
    Image of Backlight setting
  • poorna Jan 04, 2013
    i want to do registry setting for the above backlight setting to 3mins
How do I change the language settings on a Motorola MC9090?
In order to get more assistance about how to change the settings on your Motorola MC9090, you can visit the website:
Jun 27, 2014 | Motorola Computers & Internet
Permanent Desktop icon removal for Symbol MC9090 scanner
Right click the icon. Hold the shift button while left clicking the delete option in the menu. Click ok on the permanent delete.
Oct 19, 2012 | Symbol MC9090 Barcode Scanner
How do I get Symbol / Motorola MC9090 wireless settings to be
This is an old post but I'll give my solution anyway!
I anticipate that you're not exporting the connections:
Open the Wireless Menu icon on the task bar (Close "Manage Profiles" if it is open, select "options".
Select from the drop down "Regulatory" and select your country of operation (e.g USA), de-select "Enable 802.11 d", click Save.
Select from the drop down "Export", click "Export Options", click OK top right, click "Export All Profiles", click OK top right.
Now if a cold boot is performed the device will retain the added network profiles.
Cheers!
Apr 27, 2012 | Zebra Symbol Technologies Mc9090 Moble...
I am trying to manually change the ip address in my Zebra6m printer but it gives me no option for "ip configuration" in any sort or sub menu
First set I/P protocol to permanent and save. and then go back in and you should be able to see and change the IP , Subnet, and Gateway.
Jul 03, 2010 | Zebra 203DPI Printer
Using an upgraded MC9090 gun...connexion broken in standby mode
This could be 2 thinks. First check to see if under your wireless profile that the card is set to CAM (Constantly Awake Mode). This doesn't help you battery life, but stops the radio card switch off and closing any open connections.
Next you could see what you power settings are. In control panel open up the power settings. You can change the time when the terminal goes into standby when running on battery power and also the CPU power mode.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL +44(0)1202 620955
May 05, 2010 | Zebra Symbol Technologies MC909X-G Series...
How to change the display settings for MC9090-G RF Scanners
Hello, if you go to support.symbol.com and download the mc9090-g users guide, it will walk you through changing your display settings
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=7221506apdf&sliceId=&dialogID=165472011&stateId=0%200%2019451184
if you need assistance please let me know
Kim Ganoe
800.933.2839 x251
Jan 31, 2010 | Zebra Symbol Technologies MC909X-G Series...
How do I change the sleep timer settings on a Motorola MC9090
A - From the Windows Mobile user interface:
1. Tap Start (the Windows Logo), then Settings.
2. Tap the System tab.
3. Tap the Power icon.
4. Tap the Advanced tab.
You can change the number of minutes before power is turned off when on battery and when on external power from there. You can also uncheck the "Turn off device if not used for" check box to disable the timeout entirely.
B - From the registry (useful for deploying the setting as a .reg file to the device, in case you have many MC9090 guns you are supporting or you are wanting to set it to a value the user interface does not support):
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Power\Timeouts]
"BattSuspendTimeout"=dword:00000000
"ACSuspendTimeout"=dword:00000000
The above values are in hex and represent the number of seconds before timing out when on battery or AC power. For example, to set the BattSuspendTimeout to 180 seconds, you would set it to dword:000000B4. To disable it entirely (the equivalent of unchecking the checkbox in the user interface), set the value to 0.
Thanks,
Brad Radaker
Radicomm, Inc.
(makers of QuickTalk - push-to-talk over WLAN for MC9090)
www.radicomm.com
May 12, 2009 | Zebra Symbol Technologies MC909X-G Series...
Display backlight problem
i have the same problem, i thought it completely blacked out, but i realized it was just the main backlight. i can see it if i hold a flashlight to it, but i tried everything to fix it, and ive had no luck.
Sep 21, 2007 | LG VX8300 Cellular Phone
Zebra Symbol Technologies MC909X-G Series Barcode Scanner Logo
178 people viewed this question
Top Zebra Computers & Internet Experts
Mike
 steve
steve
justwinwin
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
