Question about Lenovo Computers & Internet
My Lenovo ideapad z370 keeps shutting down and booting up for no reason?
My ideapad keeps shutting down and booting up again on its own.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 82 Answers
Dude .,, its due to overheating caused by busted heat sink... maybe you should replace it to fix this thing...
Posted on May 04, 2013
florin_decad
  • 203 Answers
SOURCE: My web camera isn't working.
Check the driver if is still at hes place , if is not there go to manufactor website and dowload the driver
Posted on Jan 16, 2009
myjosh007
  • 530 Answers
SOURCE: my lenovo it keeps shutting down
hi im josh in cebu phils. may i help you? Friend i encountered the same problem of yours before.and i was able to solve it. Friend the rechargeble battery/supply of your notebooks is the problem.change that with the new one. or before you do it try to see first if the connections are ok like loosening connection may cause these problem. dmage power chord may aslo cause or the socket of your note try to check if not loosen or weak or detached. good luck!
Posted on Feb 21, 2009
KingDWS
  • 1606 Answers
SOURCE: Lenovo S series ideapad will find my dlink router no network addr
Generally if you can see the D-Link then everything is trying to talk. Would have to know if the d-link is new out of the box or is part of an existing setup. If the d-link has been part of the network I would suggest that you don't have the security settings correct. If you right click on the network icon and look at the send received numbers. If received is zero then your problem is you don't have the security key (WEP or other type)) setup. If you are getting recieved numbers you may not have the DHCP setup in the d-link. DHCP assigns the numbers to the computer but the d-link has to have this turned on in some models others it is by default.
If both your laptop and dlink are not new and specifically about a year old then I would also suspect that the dlink has died or is dieing on you. If you have had periods of disconnects or slow jerky network acess then these are signs of the dlink having problems. The wireless part tends to go after a year or so while the wired portion probably still works. When they go they are annoying as they work then they won't and so on.
That is you next step to try is to plug in your laptop direct to the wired connection on the dlink to test if the problem is the wifi portion of the dlink. If it connects your problem is the wifi and you probably will have to replace the unit. Next plug it into the cable modem and see if the problem was in the dlink itself.
Posted on Jul 09, 2009
  • 66 Answers
SOURCE: Lenovo Y510 Vista turns on, does not boot, does not turn off
Try hitting the F8 key and reboot in safe mode.
Posted on Feb 16, 2010
SOURCE: Lenovo Ideapad Y510 won't turn on or off
try removing the battery and removing the adaptor press and hold down the power button for 5-10 seconds then let got this will power drain your system board noy turn the system on using the battery only without any adaptors to charge or power the system, try turning the system on if the system turnes on leave it turned on for a couple of hours then conenct your sysem adaptor monitor if the battery light and the battery indicator on the lower right of the screen in windows woll indicate that the system is chargin if it is then I believe everything should be fine the blue indicator is for your system if it is blue then your system is turned on and has power if it turned orange and blnking then the battery will be more likely be almost out of juice or may need charging.
Posted on Jun 24, 2010
How to go to Bios in Ideapad Z500
Usually one of the F keys will get you into the bios. Try F8, F10 or F12. Reboot the computer soon as it starts booting up keep tapping on the F8 key if its the right one the bios screen will appear, if its not it will just boot up in windows. Shut it down and try it again using the F10 key, etc, until you get the bios screen to come up.
Aug 09, 2014 | Lenovo 3000 Computers & Internet
Boot not working
Check the boot configuration in the BIOS. It could be that the battery of the BIOS needs to be replaced (if this is an older PC)
May 25, 2014 | Lenovo Ideapad S100 Atom N455 1.66ghz 1gb...
My netbook wont turn on
  • check wether there is any battery problem...
  • Or else if netbook shows booting screen before shutting down. try safe mode log in... (mostly keep pressing "F8" key, it will show menu..)
Oct 18, 2012 | Lenovo IdeaPad S10-1208Uw Netbook
I have lenovo z560 (ideapad).it got off automatically,,,
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Oct 05, 2012 | Lenovo IdeaPad Z560(0914-3NU) NoteBook...
Lenovo z560 cpu overheating problem solved
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jul 24, 2012 | Lenovo IdeaPad Z560 Laptop
I have a Lenovo U350 ideapad. When i rebooted it, it keep coming up Windows Error Recovery. I tried all the options (Safe Mode, Safe Mode with Networking, Safe Mode with command Prompt, Last known good...
Welcome to Fixya
Looks like the Windows OS is already messed up. You should be able to boot the computer to safe mode to troubleshoot the issue. In your case, it is not booting up to safe mode then the only way to use your computer again is to restore it from the factory default state. If you want to do that, just turn off the computer then press the ONE KEY button located beside the power button then follow the on screen instructions.
Thank you for using Fixya!
Sep 05, 2011 | Lenovo Ideapad U350 Laptop Notebook
'blank sceen appear on my lenovo ideapad S10 but lenovo and the windows manage to appear after tunning it on and blank afterward
Hi licah,
It seems that your computer is not booting into windows properly at all.
You mentioned you see Lenovo and windows appear then the screen goes Blank afterwards, you can try to Boot directly into the Hard Drive manually just to get everything working or I mean Booting up again but this is a small shot from what you are experiencing but is also worth the try.
turn your S10 machine OFF then turn it back ON and keep on tapping f12 on the keyboard you should see Boot menu on the list Select HDD then press enter this should boot into the Hard Drive, if it does not then you may need to send the system back to Lenovo for a possible reinstallation of windows or on most time we also have the Hard Drive replaced in many cases.
I hope that this Helps.
Have a nice day,
mvincentc
May 27, 2011 | Lenovo IdeaPad S10 - 42312BU Notebook
My lenovo ideapad z560(core3i,2gb ram) keeps shutting down automatically.... havent been able to identify any specific reasons for it.. sometimes its stuts down just after bootin...or jst in d middle of...
I suggest try to check these things on your machine.
->Check if the machine is Overheating.
->Check which part of the machine is Overheating.
->See if the Fan of the machine is Running(Feel if the air vent of the machine)
Cause of Automatic Shutdown:
-Memory
-Hard Drive
-Fan is not working
Most likely those are the cause of the machine keeps on shutting down unexpectedly.
Apr 12, 2011 | Lenovo IdeaPad Z560 Laptop Computer -...
My ideapad Y530 doesnot boot up. The lights come on the board and shut down immediately
I'm hoping you can't see Motherboard display screen or BIOS during startup,then Remove the RAM and place it again.It will solve your problem.
Dec 28, 2009 | Lenovo IdeaPad Y530 PC Notebook
Computers & Internet Logo
218 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
