SOURCE: lg french door refrigerator new house no instruction book.
Press and hold the filter indicator pad for at least 3 seconds to reset.
SOURCE: how do I reset the lg water filter indicator light
i fixed the problem by asking my son. he has more patience than i and just held down the button longer and it worked.
SOURCE: I have a LG 3-door french refrigerator that will
the most be a chunk of ice stuck since this refrigerator cool way much it freezes the water in the dispenser area i have cleared wit a bit of hot water and emtying the ice bucket
SOURCE: LG refrigerator won't dispense water any more
The water line is freezing in the door due to deteriorated insulation. The only fix I have found to work on my fridge was to defrost the inside door with a blow dryer. Then place a weedeater replacement line (the orange 10" or so size you find at Lowes' or Home Depot) up through the dispenser nozzle, If the line only travels about 3-4 inches up the nozzle, then ice is still in the tube. Blow dry it until you are able to get water to dispense. After the tube is ice-free, place the weedeater line up throuth the dispenser nozzle leaving about 1/8" sticking out. The dispenser will still work with the line stuck in it. The dispenser will probably freeze again in about 8 hours, But all you need to do each time this happens is to pull the weedeater line out, dispense the water to unclog the ice, and place the weedeater line back in the nozzle. I have been using this method for about a week now and it works great. My GE Side-by-side is also 4 years old and this seems to be a problem with all of them. There is a part you can order to fix the problem, but I have heard it may not work.
SOURCE: French door LG refrigerator with freezer on the
It might be something simple like the water faucet is not open all the way
LG FRENCH DOOR SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
