Question about HP LaserJet Pro 400 M401N Laser Printer
HP LaserJet Pro 400 M401n
Printing envelopes with HP LaserJet Pro 400 M401n
  • 25 Answers
SOURCE: My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Posted on Aug 14, 2008
POCBM
  • 121 Answers
SOURCE: envelopes get wrinkled while printing
The problem is likely the envelopes.
OK, I'll explain what is happening first.
If you think about it this way: The envelope has air in it, not alot but some, as it moves into the fuser "the heater" the air heats up and expands. If the envelope does not have enough "leaks" for the hot air to escape it creates a bubble in the envelope that gets squashed as it moves thru the fuser giving you the wrinkles.
Does that make sense?
Most envelopes (if you have ever looked closlely at them) have small openings in the corners that let the air escape.
Sometimes the opening are to small or not there at all.
Yes the heat can also seal the envelope. Usually not if you are using laser specific envelopes.
Now that was a long winded way of saying try new envelopes made for laser printers.
Hope this helps
Posted on Mar 15, 2009
SOURCE: Driver for HP Laserjet 6L Pro
Your problem could be either due to the malfunctioning of the driver or you may have installed a wrong printer's driver.
This can be rectified by reinstalling the printer;s driver. Please find the proper driver in the following link.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=21878&prodTypeId=18972&prodSeriesId=27724&swLang=8&taskId=135&swEnvOID=228
~regards,
Jegan
Posted on Jun 03, 2009
  • 72 Answers
SOURCE: How do I place the envelope in the printer to
Step one: Load the envelopes NOTE: The exact steps for loading envelopes in the product might vary by product model. Please see the User Guide or the product manual for specific information about your product.
  1. Remove any paper from the input and output trays.
  2. Extend the paper tray, and then slide the paper-width guides to their outermost positions.
  3. Place several envelopes in the tray, and then slide the paper-width guides toward the stack of envelopes. Make sure that the paper-width guides touch the edges of the stack of envelopes without bending them.
  4. Slide the paper tray into the product.
Posted on Jun 16, 2009
SOURCE: how to print an envelope on the officejet pro
You have to remove the stack of paper, and then bring the "guide walls" to the center. Just found out. I haven't tested it but it should work.
Posted on Jul 01, 2010
HP LaserJet 3050 All-In-One Printer blank pages after attempting to print second envelope from same document - turning off and back on solves temporarily
If the same fault occurs with different printers it is almost certainly caused by the document.
"...second envelope from same document" suggests you are using a mail-merger. Is that right?
What happens if you start again from scratch? Mke a new document and try to print it a a single entity, without using mail merge?
Feb 05, 2016 | HP LaserJet 3050 All-In-One Printer
I cannot install laserjet Pro 400 4001n on my desktop
Do you mean the HP LaserJet Pro 400 M401n? If so, start here: http://h20566.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=5254078&lang=en&cc=us and select your OS. Expand the section labeled Drivers. In order to use all of the features of the M401n, download the Full Software and Drivers.
If you have connected the printer via a USB cable, make sure to uninstall the printer from the Printers control panel (in Windows - the location name varies with the version of Windows) and disconnect the USB cable before reinstalling the printer software.
I hope this helps.
Jan 15, 2015 | HP LaserJet Pro 400 M401N - CZ195ABGJ
Lite up blank screen
Shut off for at least 10 minutes with power source disconnected to clear any memory banks of this problem.
Sep 23, 2014 | HP LaserJet Pro 400 M401N Laser Printer
Hp laserjet m401n 52 scanner error
You have a scanner. It is the laser/scanner which writes the image to the drum. It is located under the top cover in the center. It is a black box and most times the issue is the scanner motor has become dusted up and does not turn to the correct speed. Not sure if yours can be repaired but on older models I have repaired them by opening the laser/scanner assembly and removing the little circut board with the motor and chrome spinning shaft. If you can remove the chrome piece from the motor you do so and then place a very tiny drop of synthetic oil down the shaft, install the chrome piece and spin a few time by hand and put everyting back together. You can download the service manual by doing a google search.
Apr 04, 2014 | HP LaserJet Pro 400 M401N Laser Printer
Laserjet pro 400 is offline
Use led panel and switch smart function off under settings,.
Sep 19, 2013 | HP LaserJet Pro 400 M401N Laser Printer
Blue dots
That is to prevent counterfeit money printing.
May 31, 2013 | HP LaserJet Pro 400 M401N Laser Printer
HP LaserJet Pro 400 M401N Laser Printer Logo
570 people viewed this question
Seeker5211
Seeker5211
