UMC TV suddenly stopped working -no sound or picture when switched on
5 years old Freeview HD Ready tv suddenly failed to give picture or sound. Makes slow clicking noise only, when switched on.
SOURCE: my 5 year old samsung flat tv will not turn on
probably the power supply and could also be the L-main board
Posted on Jul 19, 2008
SOURCE: No Picture in my 1 Year Old Polaroid FLM-2632 LCD TV
had the same problem. if you take out the power supply in the back of your tv ( easy to get to just a few screws in back to get to the box then a few more to get into it and some quick disconnects) you can take it to a local tv repair shop and they can remove the two green capacitors in the upper left of the circuite panel and place in 16v ones that can actually handle the power needed. do not try to do it yourself although the new capacitors only cost 2 dollars one wrong move and you burn the wires on the board. the repair man only charged me 54 dollars well worth it considering polaroid wanted to charge me 500 to fix a 2 dollar part that should have been recalled. they are in the busines to make money but if any of us did what they did wede be considerd con artist. final note since ive replaced the capacitors my tvs worked better than when i bought it
Posted on Oct 08, 2008
  • 6 Answers
SOURCE: sound but no picture
check out input for video, make sure your color code is right, and if you using a receiver check your inputs and color code
Posted on Feb 04, 2009
SOURCE: tv comes on and goes right back off
IT GAVE OUT A LOUD BANG AND NOW I HAVE NO PICTURE OR... Mosfet Transistor blow out.  Transistor K3316 or replace the Power unit supply. This problem was caused by a low power voltage. SONY SONY KE-42TS2U
Posted on May 29, 2009
SOURCE: tv keeps disconnecting from digital tv, returns within 5 seconds but highly annoying! pictue goes blank and sounds goes aswell , almost like the tv has turned off only to restart itself
It sounds like it is loseing signal, check your connections, and make sure you have the correct cable
Posted on Jun 01, 2009
When a overhead light is switched on,the tv sound goes and picture breaks up
sounds like distortion from this overhead light you are turning on.
try TV else where in another room for example.. see if it reacts to other equipment being turned on
Jun 02, 2013 | Panasonic TX-L32C4B 32-inch Widescreen HD...
I have an rca 61" dlp tv that is about 4 years
More than likely you have a power board that is failing. Since the TV is so old I doubt it is under warranty still. I estimate it would cost you anywhere between $300-400 to repair that problem so it may be time to switch to a newer LCD TV.
Feb 28, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Could you please tell me if my LC-32GA5E tv can work with sky HD.The manual tells about switching to hd mode,but there seems to be no where to connect hd to the set.The tv is about 5 years old. thanks...
This is an HD ready TV and can definitely be used with Sky HD, but ONLY if the Sky box is connected to the TV with an HDMI cable. It will not work if connected with a scart cable.
So you need 2 things. Firstly, you need to buy an HDMI cable (see picture) if you haven't already got one. Secondly you need to locate the HDMI sockets on your TV and Sky box. The sockets will have the HDMI logo (see picture) next to them.
Oct 16, 2010 | Sharp LC-32GA5U/LC-32GA5E 32 in. HD-Ready...
Sound but no picture on Vizio WS42L TV
did you ever get it resolve? I am having the same problem. my tv is a year and and 1 week old. I am so upset.
Jul 19, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
No sound when watching freeview on Samsung 32" LCD TV
I`ve got the same problem, sound with analog but not digital?
Dec 12, 2007 | Televison & Video
Digital TV not working
i had same probs tv 4 monts old new tuner fitted
and yet one more new tuner fitted when 8 months old
it now turns pick off at randod but sound stays on have to unplug mains for temp fix
now warranty has run out philips are not interested
Oct 31, 2007 | Philips 42PF9966 42 in. HD-Ready Plasma...
No sound
If I remember correctly, this model can only have sound from either the SCART or the standard input. The solution for this set is to have all the devices work through a common A/V switch box.
The best solution is to update the set to one with more active inputs that are adequate for your needs.
Jerry G.
Nov 19, 2006 | Sony KV-32S26 32" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
