Question about Garden
I have 2005 Cub Cadet 528 SWE snow thrower and have trhe following problem. last week when clearing snow I ran over a wooden hockey stick and had to dislodge the broken pieces. Since then the thrower has been acting up. It starts and the augers turn, howver, when i put too much of a load on it the impeller stops turning and i need to clean it out to get it turning again. My question is is there a shear pin or key for the impeller or does it sound like maybe the belt is slipping. If there is a key or pin wher might it be located?
  • 429 Answers
Http://www.manualslib.com/manual/34068/Cub-Cadet-Swe-528.html?page=20#manual
Check this page,
Two stage snow blowers all tend to have sheer pins
I would suspect that the holes seen in the picture are for the sheer pin, check with club cadet, figure same as auger pins, if so feel for the hole with your finger then inser a short nail till you feel a rough spot then tap with a hammer till it comes out, otherwise you have to take the mess apart completely.
Posted on Jan 06, 2013
2 Suggested Answers
  • 144 Answers
SOURCE: My MTD 10hp auger will
Yes there are 2 belts one for the drive and one for the auger. If you remove the cover on top that is located between the engine and the auger housing you can check the belts. The auger belt has come off the pulley or is broken. Hope this helps you out. Best regards and good luck.
Posted on Jan 09, 2011
How do l replace traction control cable on cub cadet 826 SWE
The following link shows how to replace your cable. The link shows a craftsman model , it will be the same procedure as your cub cadet. You can refer to your owner manual for adjustment procedures
Snowblower Won Move How To Replace The Drive Clutch Cable On Craftsman Or...
Download manual
Jan 25, 2016 | Cub Cadet Garden
Cub cadet 524. Why won't it propel itself and makes an awful ticking noise?
Sounds like the plastic gears in the self propelled gear box are stripped or out of mesh for some reason. The clicking is most likely the gears trying to mesh
Jan 24, 2016 | Garden
Cub cadet 528 SWE chute will not go up and down. Goes side to side with no problem.
cable or chute frozen
if cable is good loosen bolt on the side to give it alittle more play
Feb 02, 2015 | Cub Cadet Garden
I finally found the 190-341 snow thrower model that is spec'd for my Cub Cadet GT2542...I installed it and it went right in...but there is a problem with the tension pulley rubbing up against the front...
I went online to MYTRACTORFORUM.COM and posted my problem i was having and i recieved response with pictures that showed me exactly what was wrong...
Feb 11, 2010 | Cub Cadet Garden
Cub Cadet tractor choke problem
There is a web site called mytractorforum.com which has a subcategory especially for the cub cadet. I recommend referring the problem to that site.
Jan 26, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Garden Logo
165 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
