My technics sl-dv290 wont play cds dvds comes up h20 no play
Comes up h20 no play model number sl-dv290
2 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: I have a technics dvd stereo system. Model No.
If for some reason you would opt for user performed action, then pls try:
1. reset, unplug from the mains for at least an hour and try again;
2. check if there is a slide switch of some sort at the rear of the unit;
3. check if there may be a pinhole somewhere along the bottom of the loading tray where a blunted point safety pin maybe inserted;
4. open the top cover and manually eject the tray;
5. check internally if there is a mechanical problem such as a slipping/cut belt, gears that do not mesh correctly;
6. if the unit has been in use for some time, it may simply need cleaning and re-application of lubricant in the mechanical assembly.
The slider mechanism, depending on the age of the unit and , consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
Hope this may help;
Regards,
VOTIT
Posted on Jun 15, 2009
How do i connect technics turntable model SL-QD33 to technics stereo model SC-DV290 and what do i need to switch to on stereo to play records.
Have a look on the back input panel of the sc-dv290. Check for a "PHONO" input. If there is no phono input it will not play turntable. If there is: then plug it the turntable in and switch the SC-DV290 to PHONO mode.
Another way would be to purchase a "phono preamplifier" from ebay: Hook the turntable into the phono preamplifier, and the preamplifer into the SC-DV290 AUX input.
Feb 26, 2011 | Technics SC-DV290 System
I have a Technics SL-PG480A CD player. It won't play CDs down loaded from i tunes. These CDs will play on another newer Sony. The Technics plays other commercial Cds without problem both before and after...
This player will not play either MP3 or MP4 encoded CdRs. It is a good 18 years old now and such things were unforeseen back in the day. The newer sony may well be MP3 compatible. You could convert MP4 to standard audio types on your pc via any number of software applications.
Dec 23, 2010 | Technics SL-PG480A CD Player
Technics dv290 system
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
Sep 06, 2009 | Technics SC-DV290 System
FAILURE TO READ DISCS. TECHNICS SL-DV280 (SC-DV280)
if the disc starts to rotate when helped by hand then you definately have a weak spindle motor. dvds spin faster than cds which gives more wear & tear to the motor. i've repaired these faults numerous times. hope this helps?
May 08, 2009 | Technics SC-DV290 System
How do I switch off demo on a sl-dv170 technics?
got the sc-dv290 model, not sure but I'd asume they are all the same
PRESS AND HOLD [-DEMO] until "NO DEMO" is displayed
Feb 15, 2009 | Technics SC-DV290 System
No play
you most definately have a faulty spindle motor. this is very common on technics and panasonic dvd players. i've come across this fault on numerous occasions and after replacing the motor, all worked as it should. hope this helps?
Jan 25, 2009 | Technics SC-DV290 System
Re: sl-dv290
it looks like you have to change laser some of the them lasts for a 1000 hours ....take to repair shop only for cleaning in that way you get the end of the laser life...........................saludos
Oct 19, 2008 | Technics SC-DV290 System
SL-DV290 DVD player error message
sl-dv 290u meu refuza sa functioneze. Knd il aprind se aude un barait in boxe si se stinge. Ce pot face pentru a remedia aceasta problema?
Apr 03, 2008 | Technics SC-DV290 System
Technics sc-dv250
did you buy your system in adifferent region and moved with it to another? I heared something like some DVD players are region-locked. I could be wrong but google about region-lock... try this among others: http://dvd-player-software-review.toptenreviews.com/what-is-dvd-region-lock.html
Pikles
Mar 16, 2008 | Technics SC-DV290 System
Won't play cds or dvds
you need a new motor in yr dvd player i had same problem had new motor works now
Aug 04, 2007 | Technics SC-DV290 System
63 people viewed this question
 Grubhead
Grubhead
