Question about Epson Stylus C82 InkJet Printer
Trying to print black only document
I have a Epson c82 printer and have just installed a new black ink cartridge. I want to print a document that is black text only, now my monitor is saying that I need to change the other 3 colours.It is now 10pm and cannot purchase new ink until tommorrow at the earliest I have set to black ink only in printer settings but document does not print and I am still getting "ink out " warning. Any help would be appreciated
    President:
  • 2,961 Answers
The problem with this printer is that all the inks have to be at a usable ink level, if any one of them are below the acceptable amount it will not print in any colour at all not even black.
Posted on Jun 25, 2007
SOURCE:
I have an epson NX400 inkjet printer, all ink cartridges are full and are installed correctly. When trying to print, the black ink is not being printed. I have tried doing several head cleanings,...
hey friend,
This should be the problem of print head ink nozzle block.The nozzle for the black ink cartridge got dry.So the ink getsdried state.It won't allow any inks passing through the micro nozzles.Head cleaning won't help with the heavy nozzle block.So try replacing a new black cartridge or else bring the printer to the nearest service center.It'll help so.
Mar 06, 2011 | Epson Stylus NX400 InkJet Printer
New ink but want print letters printer type epson c82
Hi there follow the steps below.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope thats start working , if no luck then un install the printer driver & restart the PC & Printer both again. NOw install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
May 24, 2010 | Epson Stylus C82 InkJet Printer
My Epson cx7450 ran out of ink a while ago. I
Did you remove the cartridges when it went out of ink? If so, the printer head is clogged. Anyway, If you didn't remove the cartridges and the "a while ago" means "Long time ago", is more likely the printer head is clogged. You may need to run the "cleaning printer head" feature from the printer or replace the printer head.
Inkjet printers should be used frequently to avoid this issue.
Sep 06, 2009 | Epson Stylus cx7450 All-In-One InkJet...
Black and white not printing correctly, color is fine
If you are not using Epson ink, your printer will do this. Epson printers hate knock-off ink. Always use Epson ink if you want to keep your printer working properly. To solve the problem you are having, try cleaning the ink tubes. Make sure you re-install them properly. Hope this helps. Charlene
Feb 10, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Epson Stylus C82 InkJet Printer not printing
In view of the original poster's lack of interest in this problem, I think we can post it as "Solved by Poster"
Nov 16, 2008 | Epson Stylus C82 InkJet Printer
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Printing without color?
Im sorry to inform but yes, Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
May 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Epson C82 & C84 Printers will not laydown any ink!
Sorry but It uses Durabrite ink which tends to turn into hard gel if not printed at least once a week. Its less painful and expensive to just throw the printer out and buy a new one. I recommend the canon PIXMA ip3500. It lets you remove the printhead for cleaning unlike the Epson. If you want to try your luck at unclogging the printer heres a link to a unclogging kit but be warned that results are not guaranteed!
http://www.fixyourownprinter.com/kits/Epson/K89
The C82 in addition to clogging also has a problem where the waste ink hose which is supposed to remove excess ink (so the printer dosent get clogged) gets disconnected and so the printer clogs even more. The C84 had this glitch fixed but alot of good that did!
Thanks for reading!
Apr 10, 2008 | Epson Stylus C84 InkJet Printer
PRINT
Should be option on print driver ie Control panel/printer and fax's right lick on epson driver, properties.
Still needs a colour cart installed.
Nov 16, 2007 | Epson Stylus C82 InkJet Printer
New black ink, but wont print any black ink
Epson Printers are terribly designed. There is a known issue with them related to clogged ink wells. Below the cartridge the ink dries in the well and makes the printer unusable. I have seen this many many times and will NEVER recommend an epson printer. Most of the time I will have people go out and buy a new printer only because of the fact that you will be paying 50-70/hr labor for someone to FIX/Clean your printer. If you want to try to clean it yourself go ahead. I have done it in the past with varying success because it is more trouble than its worth to remove the inkwells and clean them properly. Buy an HP printer. The difference is that the HP cartridge is what contacts the paper directly. There is no inkwell inbetween to get clogged. When you buy a new HP cartridge you will replace everything between the ink and the paper. Epson is just a poorly designed product. Hack
Jul 09, 2007 | Epson Stylus C82 InkJet Printer
Epson Stylus C82 InkJet Printer Logo
232 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
