Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
Dishwasher does not complete cycle
My dishwasher will start, "washing" light on, when draining to begin rinse cycle, the soap has not drained from the washing. The rinse cycle continues with soapy water. I have run it through the rinse cycle over and over (a wast of water) and it is still soapy. I tried placing a tiny amount of cascade in the dispenser, and it is still too much soap. Seems like it drains, but comes back in, or something. The drying time has diminished to 4 minutes. The time on the panel was 85 min to continue the entire cycle, now, it is 50 min. I have had two service techs here, neither of them could figure out the problem; one said just try vinegar in the water, which I did, and it did not help, the other said that he was not certain, but would order a new motor, which would take care of any problem. This does not make any sense to me, seems that since it is not draining to rinse good and not drying, it would be the pump and the heating element (if that is what dries).
What could be the problem?
Thank you.
    Problem Solver:
  • 10 Answers
The solution i'm going to give you might sound weird but it should work. The drain hose should have a curve of about 36 inches up and then down to the drain. This avoids the water to drain on its own, the water has to be forced out by the washing machine. hope it helps.
Posted on Jan 19, 2009
Dishwasher suds up and leaks during wash
Suds in a dishwasher usually come from using too much soap or the wrong kind. Soap can build up over times causing problems. First start a cycle.Do not add detergent or any dishes.When it starts washing, pour a cup of vegetable oil directly into the tub. This will cut the existing soap suds. You may need to try this a couple time before the dishwasher will drain. After all suds have been removed, load you dishwasher and start a cycle filling the detergent cup up half way. If it goes through the cycle with no problems, you should be all set. Still have the problem? A rinse aid dispenser that dispenses too much rinse aid will also cause the dishwasher to suds up. You can remove the dispenser from the door, flush it out and reinstall. Make sure you turn the circuit breaker off before taking the door apart. After rinsing it out, do not add rinse aid. Try the dishwasher and see if the problem goes away. I've seen people accidentally put liquid dish detergent in dispensers too. A dishwasher that has suds is apt to leak. Fix your suds issue and you most likely will fix you leak
Dec 27, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher not draining completely-suds left
Dishwashers shouldn't have suds so somehow dishwasher liquid was introduced to the dishwasher. Vinegar, alcohol, or a small amount of cooking oil might help eliminate the sudsing.
Jun 20, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
My GE Adora dishwasher is not cleaning well and the detergent isn't completely disolving. What could be the problem?
Mine has been doing the same thing for about 2 months now.. I tried Finnish brand diswasher cleaner, but to no avail. Try this:
1) Empty your dishwasher, then take out the lower rack.
2) Start a regular cycle. Wait until you hear the jets turning, then open the door. Make sure there is enough water in the bottom - It should be just UNDER the heating element.
3) If your dishwasher is getting enough water, Reset your washer and allow it to drain.
4) Go to the store and get a gallon jug of white vinegar. Start your dishwasher on a regular cycle.
5) Once you hear the jets turning, Open the door and add FOUR CUPS (liquid measure) of white vinegar to the water in the bottom. Let the wash cycle complete.
6) When the wash cycle drains, the rinse cycle will fill. Once the rinse cycle starts, add ANOTHER FOUR CUPS of white vinegar to the first rinse cycle.
7) Allow the first rinse cycle to drain. Let the second rinse cycle complete normally.
I know this sounds too good to be true, but it REALLY DID work for me, this evening as a matter of fact! I also bought some hard water/soap film detergent additive from the store. It was kind of expensive, but I'm using it for a while just in case.
I hope this helps. Like I said, I couldnt believe it when my dishes came out clear again! Also, I turned OFF the heated dry cycle, and just opened the door and pulled out the racks when it was done.
Good Luck!
Mar 30, 2010 | GE Adora GHDA654LBG Dishwasher
Bosch SHU3036UC draining on wash cycle
it is probably going to be a grimy door thermostat between the inner and outer panel. its hooked into the back of the soap dispenser. someone would have to take the outer panel off then clean wipe away the caked grime from the thermostat and put it back in its place. if this doesnt fix it then it could be a heat assembly problem or timer problem. in that case you would need an appliance tech out
May 28, 2009 | Bosch SHU3036UC Dishwasher
Water won't go out of the dishwasher
Begin at your sink drain that the dishwasher drain hose connects to. Disconnect the hose and check both directions for anything plugging the connection.
Make sure the drain hose has not become "kinked"
(After you have emptied the water from the dishwasher) remove the lower spray arm and the filter in the sump area. Look for obstructions and remove all debris. Rinse the filter thoroughly and reassemble.
If you dishwasher has a timer on the front of the dishwasher that you can manually turn, start a quick cycle with no DW soap and empty.
Allow the water to run in for several seconds and then manually (slowly, gently) turn the timer knob until the DW should begin draining the DW. Listen closely for the sound of the pump motor running.Is water properly draining out of the dishwasher into the drain?
After you have done these things, please post back here and we can take the next steps. OK?
Apr 09, 2009 | Dishwashers
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Control Module?
Sounds like a dishwasher.. You didn't say or give a model number. Dishwasher that do not drain are usually caused by clogged up drain hoses, often right where it connects to the drain or disposer under the sink. In some cases, there's a separate drain pump that is defective, in other cases, there's a drain solenoid, and in others a drain impeller that's broken or clogged. All depends on the model.
Oct 24, 2017 | GE 24 in. PDW9880LSS Stainless Steel...
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
401 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
