Question about Refrigerators
Norcold rv fridge keeps shutting off after being reset tried on electric only propane only nothing is working
  • 159 Answers
SOURCE: rv fridge not working on electric
the element can be broken or the thermostat
Posted on Aug 13, 2009
  • 415 Answers
SOURCE: freezer works ok but the fridge doesn't
are you running gas to oper the frig in the rv or electricty if only using the heating element for the frig RV STYLE ONLY maybe starting to make and break causing intermittent cooling or not enough cooling in frig but at all thing concerned try to increase you temp setting higher if you have that option
Posted on Aug 19, 2009
SOURCE: RV freezer cools, but fridge section doesn't
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
motor1258
  • 6674 Answers
SOURCE: I have a Norcold 9000. It works fine on electric
Have you tested for 12 vdc at terminals where element is connected to board? If yes, and 12vdc is present, then I'd pull element out and bench test it carefully. Just let it cool down, and attach 12vdc from a battery or other source to it and see if it heats up. Careful not to burn your fingers or hand when feeling outside of element for heat. If no heat felt, replace it.
Posted on Jun 04, 2010
motor1258
  • 6674 Answers
SOURCE: I have a Norcold gas/electric Fridge in my rv. The
Shut it down, level it up and wait 24 hrs before turning it back on.
Posted on Jul 09, 2010
Norcold fridge berps and display says No flame
check for a gas shut off inside the fridge cabinet as well. You may have to bleed all the air out of the lines before the fridge will get gas. either keep trying or run stove burners to make sure gas is working. Also look for debris inside the burn chamber near the thermocouple/pilot light.
I had rust fall from the exhaust tube and block the burner area. Cleaned it up and it works fine now.
Mar 25, 2013 | Thetford Norcold DE0051 Refrigerator
I have a Norcold 9000. It works fine on electric & propane, but will not keep cool on battery power.
Jun 01, 2010 | Thetford Norcold RV Cooler/Freezer
Norcold 682 is 0 in freezer and 50 in fridge cranked all the way up over 48 hrs now where do i look now
How about checking the R12 charge? Or you can run the fridge on propane and see if it gets colder. Which might mean your compressor is going bad.
Apr 15, 2010 | Thetford Norcold RV Cooler/Freezer
Norcold Model 682 problem
no these units run on 12 volt aswell check your fuses or and be sure u are getting atleast 10.5 volts to that fuse
Sep 27, 2009 | Thetford Norcold RV Cooler/Freezer
Sep 09, 2009 | Thetford Norcold RV Cooler/Freezer
Refrigerator doen't work on electric
check the fuse on the back of the board on the fridge itself
Sep 01, 2009 | Thetford Norcold RV Cooler/Freezer
Was camping all weekend... frigerator was fine, brought it home and plugged it in and all electrical works fine, but frigerator is dead. none of the lights come on (auto, off, gas) no cooling. How can we...
This can be a problem on the control board or in the control switch, you better check this first..
For clarification may I know what model/maker that you have?
Thanks
Aug 31, 2009 | Thetford Norcold RV Cooler/Freezer
Rv fridge not working on electric
Aug 11, 2009 | Refrigerators
My norcold frig(RV) freezes food in lower level
in your refridgerator there is an internal thermostat on the cooling fan u can move up or down it should be placed on the last finn to the right looking at the fridge
thanks
cruz
cruz's mobile rv repair
Dec 16, 2008 | Thetford Norcold RV Cooler/Freezer
Refrigerators Logo
257 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
