Question about Kenwood KDC-MP235 CD Player
What cause the display to go out on the kenwood kdc-235 cd player
Display will not show any data,other functions works.
    President:
  • 720 Answers
You could try reading my tip on repairing Kenwood faceplates.
How to repair Kenwood Faceplate
Cheers,
Posted on Mar 14, 2013
SOURCE: Kenwood in dash cd player
The protection function is activated when the speaker wire has a short-circuit or touches the chassis of the vehicle. Wire or insulate the speaker cable properly and press the reset button. (The reset button is that little pinhole button below and to the right of the volume control). If you do this and the "PROTECT" code doesn't disappear, you'll have to consult a service center. Further, if you had this professionally installed, they should be obligated to fix the issue for you (hopefully).
Posted on Aug 08, 2007
Hazardsneon
  • 100 Answers
SOURCE: How do i set the clock
If I remeber correctly, I did a bunch of these at the shop and you need to be in standby mode. Hold the menu button. a new menu will come up and you should be able to set the clock there also if you like the annoying beeps that it does you can also turn that off. And while you are at it turn off the DEMO mode unless you like it. I hope I could help.
-Andrew Hawkins
Posted on Apr 04, 2008
JeffOC
  • 30 Answers
SOURCE: aux in kenwood kdc 135
Read in the back of the manual in troubleshooting. It's the first FAQ there.
Posted on May 14, 2008
SOURCE: Kenwood KDC-3028 unlock code
TY TY TY..fixed this right on up. Only suggestion I could make is that a diagram of where the aforementioned buttons are. I did mine at night so the small words were hard to see. I just replaced my battery and cleaned off the cables connectors when this problem occurred. TY so much for this.
Posted on Nov 02, 2008
SOURCE: Wiring for a kenwood kdc 1020 cd player
if you have the wire connector it's easy.....give the negative conection to the body of the player..find the wire from the battery with has the power supply even when the switch is off..and connect it to the yellow wire.that is for the memory...find the wire which has the power when the switch is on ,and connect it to the red wire from the player....what i mean by switch is the ignition switch... u can easily find the speaker connections...most speaker wires comes as blue,ash,green,white...there are two wires from each colour......
Posted on Dec 09, 2008
Looking for a Kenwood KDC X397 owner’s manual? .
Yes of course. See the link
hard copy of this Google Search
KDC-MP238/CR KDC-MP208 KDC-138/CR - Kenwood
manual.kenwood.com/files/B64-3898-00_00_KW.pdf
Translate this page
2 ' KDC-MP238/CR/KDC-MP208/KDC-138/CR. Contents. Before use. 3. Basic Operation. 4. General functions. Tuner functions. Disc play functions. General ... Menu Operation. 10. Menu System. Activating Security Code. Deactivating Security Code. Manual Clock Adjustment. Auxiliary Input Display Setting. Receive mode ...
Kenwood KDC-138 CD Player User Manual - ManualsOnline.com
www.manualsonline.com > ... > Home Audio Kenwood > Kenwood CD Player Record the serial number, found on the back of the unit, in the spaces designated on the. warranty card, and in the space provided below. Refer to the model and serial numbers. whenever you call upon your Kenwood dealer for information or service on the product. Model KDC-MP238/CR/MP208/138/CR Serial number.
KENWOOD KDC-138 INSTRUCTION MANUAL Pdf Download.
https://www.manualslib.com > Brands > Kenwood Manuals > Car Receiver > KDC-138 View and Download Kenwood KDC-138 instruction manual online. Kenwood CD-RECEIVER INSTRUCTION MANUAL. KDC-138 Car Receiver pdf manual download. KDC-MP238/CR KDC-MP208 KDC-138/CR CD-RECEIVER INSTRUCTION MANUAL AMPLI-TUNER LECTEUR DE CD MODE D'EMPLOI REPRODUCTOR ...
Connecting Wires To Terminals - Kenwood KDC-138 Instruction ...
https://www.manualslib.com > ... > Car Receiver > KDC-138 > Instruction manual
Kenwood KDC-138 Manual Online: Connecting Wires To Terminals. To Kenwood disc changer/ External optional accessory (KDC-MP238 only) Fuse (10A) Wiring harness (Accessory1) Power control/Motor antenna control wire (Blue/White) TEL mute wire (Brown) Not Used (Blue) White/Black White...
Kenwood Car Stereo Head Unit Replacement Wiring Harness Plug ...
https://www.amazon.ca/Kenwood-Stereo...Wiring-Harness/dp/B005X273W8 Rating: 4.7 - ‎15 reviews
Kenwood Replacement Stereo 16 Pin Wire harness; Top quality all copper 18 gauge leads. Perfect Fit.Molex type 6 inch long black color; KDC KRC DPX KTS models see the descrition for model compatibility; Kenwood power harness plug 16 pin indash radio and video units; Allows for installation of an aftermarket radio ...
Mar 23, 2018 | The Computers & Internet
Display screen not working
Sounds like you might have a bad connection where the faceplate connects to the unit, or the faceplate is bad.
May 21, 2010 | Kenwood KDC-X590 CD Player
Cd will not play displays E4
Page 22 displays error code descriptions and suggested remedies for your Kenwood KDC-122 CD Player. This is a link to Kenwood site and instruction manual.
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/KDC2022.pdf
Yes, the KDC-122 is included in this document.
Oct 26, 2009 | Kenwood KDC-122 CD Player
Kenwood kdc mp336ax cannot get aux.to work or show on display ,only c.d, tuner,standby.so my mp3 player wont operate.any clues???
go to standby and hold the menu button. use fm and am to navigate until you see aux1 off. turn it on with the forward button then you are done.
Apr 14, 2009 | Kenwood KDC-322 CD Player
Is remote necessary to reset code on kenwood kdc 319
my CD player is Kenwood KDC-W3041 displayed protect and i can't turn it on. what can i do for that?
Mar 29, 2009 | Kenwood KDC-319 CD Player
I have a kenwood kdc-mp332 and it just show protect i need music now please help
My manuel says : Protect: The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated. Wire or insulate the speaker cable properly and press the reset button. I had the same problem with my stereo, but I took it to Geek Squad cause I still have warranty on it.
Dec 06, 2008 | Kenwood KDC-MP332 CD Player
Ok I had the kenwood KDC-MP235 installed and...
The front aux input is only capable of accepting audio signals and definitely won't display any track tags.
If you have an iPod, I think with the KCA-iP500 adapter it will display song info on the front as well as allow control from the Kenwood's controls.
As far as the song info on a CD - it should display if you've got a CD with CDTEXT info on it, or if you're playing an MP3/WMA CD. Most regular audio CDs won't be able to display song info.
Feb 21, 2008 | Kenwood KDC-MP235 CD Player
Kenwood CD player KDC-MP825
Some units have a reset button, have you tried to reset the unit?
Feb 10, 2008 | Kenwood Sirius KDC-MP825 CD Player
Kenwood KDC-MP235 CD Player Logo
219 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
