Question about Boston Acoustics VR965 Speaker
Install binding post for VR 965
Looking for the VR 965 speaker diagram, need to replace the binding post
Hi,i hear alot about bi wireing could someone explain what it actually is used for and what's it meant to do could I'm thinking bout trying it on my speakers?
It's a big job, but the results are great. Bi amp-ing is where the tweeters and mid range speakers are separated and connected to separate amplifiers. You'll need to have the correct gear before messing inside your speakers. You'll need to have another amplifier. Not knowing what amp you have now, getting a stereo signal into the second amp may be a problem since you'll need a line level signal into the second amp. An external crossover is best. Technically, you could use the ones in the speakers, since you'll be removing them anyway. Now for the speaker mods: On the panel where the posts for the speaker wires are you'll need to install another set of binding posts. We're assuming you have separate subs. Open the speakers and remove the cross over. The wires from the original posts should now connect to the mid range speaker. Add wires from the second set of posts and wire it to the tweeters. Now connect the output of the amp to the removed cross over and wire the mid range out on the cross over to the posts that connect to the mid range speaker. Do the same for the tweeters.If you have three way speakers, you'll have to run a 3rd set of wires from the crossover to the woofers in the cabinet using another set of binding posts. Controlling the volume on the second amp will be difficult since you'll have to adjust it manually. Remote control volume level will be lost on the second amp.
Aug 08, 2015 | Audio Players & Recorders
My Yamaha RX-V563 receiver displays "Check Speaker
Look closely at the rear connector panel of the receiver and look for pieces of stray strand wire that may be touching the speaker A binding post and the receiver chassis. If you are not using strand wire connection to the binding post then check whatever connector type you are using such as banana plug or spade plug for breakage or corrosion, the same goes for the speaker cable itself which isn't always so easy to detect. A few broken strands can cause a problem.
If it is clean, turn off the receiver and disconnect the speaker cable. Check the binding post for tightness; if you can wiggle it then it is broken and needs to be replaced.
Oct 03, 2011 | Yamaha RX-V563 Receiver
I have 2 good qaulity heybrook speakers and have tried everything to connect them properly such that both play sound when the tv / dvd is on. Both speakers work perfectly one at a time and both work...
You're guessing. That is exactly the wrong thing to do. Get the manual.
http://www.retrevo.com/support/Kenwood-VR-205-Receivers-manual/id/480ci174/t/2/
"[D]vd 6 channel input" is for a 6-channel analog input as the name implies. I doubt you even have a source that HAS 6 analog channel outputs.
Speakers are OUTPUTS of the amplifers' speaker posts. Any one can work ANYwhere.
And that bi-wire capability, IF the speakers have it - pretend it isn't there.
Jul 31, 2011 | Kenwood VR-205 Receiver
Console says replace belt unit even though I have minimal copies on the printer. Dell 3115 color laser
Hi
Try and reset the power to the printer and re-install check the toner cartridge. If this doesn't help then please try and reset the printer to default factory settings. Y?? ??n reset ???r Dell printer by using 'Reset Dell Printer' icon. Y?? ??n g?t t? th?? icon in folder 'UAN'--> 'Logic Utilities' -->Reset Dell Printer. Hope this helps... Please post back if you need more information.
Daniel
May 28, 2011 | Office Equipment & Supplies
I cannot find a diagram of how to wire a boss audio phantom p128dc dual voice coil subwoofer with there being 4 binding posts on each side of the woofer.
I will assume that you mean four posts total and not four on each side. It's a dual voice coil and you will need a jumper. Take a small strip of speaker wire and connect the positve and negative of one coil together. Take a close look, there is a dot on one positive and a dot on one negative. Jump these two together. Now wire the other positive and negative to the amp's positive and negative.
May 24, 2011 | BOSS AUDIO SYSTEMS P128DC Car Speaker
Where can i get mission gold plated binding posts from ?
I am assuming that you are after gold binding posts for a Mission speaker.
You could look on eBay for a used pair, and salvage the necessary part.
Also you can purchase aftermarket binding posts, which come in all shapes and sizes. Partsexpress.com is a great resource. Here is the specific link for their binding posts:
http://www.parts-express.com/wizards/searchResults.cfm?srchExt=CAT&srchCat=107&CFID=19252773&CFTOKEN=54594512
Mar 16, 2011 | Audio Players & Recorders
I need some replacement binding posts for my MS 100 center speaker. Where can i buy them?
Try one of the oldest DIY stores
https://www.madisound.com/store/index.php?cPath=404_119
Mar 08, 2011 | Mitsubishi MS100 Speaker
My kenwood av surround receiver vr-209 is turning on then turning off right away. what could be wrong and how do you fix it?
Disconnect all speakers at the receiver, then turn it on. If it still cuts out, it's a power supply, capacitor, or transister issue and will need to be serviced. If it stays on, re connect speakers one by one and turn the receiver back on until you find the problem wire or speaker. Once you find the wire or speaker that's causing the problem, disconnect the speaker wire at the speaker and turn it back on again. (Make sure wires are separated) if it still cuts out, check the entire wire or replace it. if it stays on, check the speaker with a meter for a short. If your not comfortable with doing that, any electronics shop will generally do it for you for free. This is the most common problem among all brands of receivers. Wires get crossed and short, then short the power supply. Hope this helps. If you need further help troubleshooting, post a comment and I will be glad to help.
Oct 23, 2009 | Kenwood VR-209 Receiver
Boston Acoustics VR965 Speaker Logo
64 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
